Twin turbo build fabrication/pics
Old Jan 8, 2011 | 06:27 PM
Boosted Performance's Avatar
Boosted Performance
Vendor - Former Vendor
Default Twin turbo build fabrication/pics
Well, the time has finally come for me to have a look at this idea. It is something I have been meaning to do for about a year now, but have not had the time. I really wanted to start it late last year, but with so many people wanting the single turbo kits I just have not had the time.
I have somewhat stocked up on the ST stuff, so I hope to have a bit more time to work on this project.
The idea of this project is to have a TT kit capable of producing some significant HP, but still be very easy to install and maintain. As far as I know, all the TT kits out there require engine removal for installation. I am not a big fan of that, as it can be costly and not DIY friendly. The $1500-$2000 a shop would charge for an install can go towards something else on the car.
At this time I have a Garrett GT2871R turbo, T25 .64 a/r turbine. I wanted to retain the internal wastegate, but it does not look like it will happen. It could be done, but the turbo does not sit the way I want it to (parallel to the engine/transmission). So I will end up using Tial MV-S V-band external wastegates.
If all goes well, and this project is a successes with good demand there will be a couple of turbo option. The largest would be a GT3076R with a T25 .86 a/r housing. I believe this is about the same as the JWT 800bb kit, correct me if I am wrong.
I did not get as much done as I had hoped today, but it is a start, and things look promising. This build may not be as quick do to the ST order, but I will try to make time for it. On to a couple of pictures:
Stocked up on the ST stuff:
Some polished goodness:
New power plant:
The air filter will go straight on to the compressor inlet. This should flow very well, as there is no piping all over the place in the engine bay for the turbo to work through.
Materials to start with:
This is not tubing, but rather pipe (thick):
How things should look with the turbo roughly in place, driver side:
Passenger side:
I think I will have to get a 2" cast elbow and weld it to the compressor outlet to have it shooting forwards towards the FMIC:
3" down pipes will be standard and will bolt up to the OEM Y-pipe, or any other true dual exhaust. Wastegates will be vented to atmosphere, unless re-circulating is requested. That will cost a few $$ though, as it will be a bit of a PITA to do.
The turbos will sit rather high, and there will never be a clearance issue. There will also be brackets built that will attach the dwn pipe to the transmission. This will take the weight of the turbos, so that there is no issues with stress on the headers
At this time (again if there is a demand) a rough price would be between $5800-$5900 for a complete tuner kit with the 3" down pipes. Like the ST kit I offer, this will be very DIY friendly.
Comments and suggestions welcome (good or bad)
Old Jan 8, 2011 | 07:22 PM
NNOCENT's Avatar
NNOCENT
quality craftsmanship, congrats on your success!
Old Jan 8, 2011 | 08:20 PM
Sylvan Lake V35's Avatar
Sylvan Lake V35
nice to see, i cant wait to see the finished kit
Old Jan 8, 2011 | 08:42 PM
grimm66's Avatar
grimm66
Do you plan to keep the front crash bar?
Old Jan 8, 2011 | 09:01 PM
Boosted Performance
No, it gets replaces by a large FMIC.
Old Jan 8, 2011 | 09:08 PM
nismonian's Avatar
nismonian
any HR love?
Old Jan 8, 2011 | 09:16 PM
kemps's Avatar
kemps
wow, thats nice.
Old Jan 8, 2011 | 09:35 PM
biggersNISMO's Avatar
biggersNISMO
Originally Posted by nismonian
any HR love?
If there was a donor car... Yes
Sasha has stated it before in previous threads
Old Jan 8, 2011 | 09:50 PM
ITOzann's Avatar
ITOzann
Sub'ed. I can't wait to see the results
Old Jan 8, 2011 | 10:32 PM
TRYNALIVEPRO's Avatar
TRYNALIVEPRO
interesting, sub'd!!!
Old Jan 9, 2011 | 04:40 AM
Glex25's Avatar
Glex25
I'm guessing this will be using a sump pump for the oil return?
Can't wait to see the complete product
Old Jan 9, 2011 | 04:47 AM
350zion's Avatar
350zion
Professional
Very nice! In for it all>
sub'd.
Old Jan 9, 2011 | 05:34 AM
str8dum1's Avatar
str8dum1
ya i always wondered why kits like my SFR or SP didnt use a little longer header to use the space a little further back. its rather cramped.
your kit will really take money outta the other guys pockets!
Old Jan 9, 2011 | 06:34 AM
Vas_Z33's Avatar
Vas_Z33
shhhhweeettt
this kit should spool or sell quick... pick one lol
Old Jan 9, 2011 | 06:46 AM
Boosted Performance
Correct, I use one on the ST kits as well. It will be an Exa scavenge pump:
http://turbowerx.com/Scavenge_Pumps/.../Exa-Pump.html
The best you can get, I have seen (many times) guys sell the $550 Weldon pump to get these, as they are rated at 10,000 hour life and can pump 350deg F fluid all day. Very well built unit using ball bearings instead of bushings.
Yes, this is true, the further back your go the better. The main reason for this in my case are the air filters. I just hate how some have the industrial vacuum hose being wedged between the frame and engine. IMO it looks like crap, and from what I understand is a real PITA to pull through. With the turbines sitting further back the down pipe will be almost straight out as well. Both of these reduce labor/cost as well, and there won't be a need to heat wrap anything.
I am ok with that I think I have been doing this with the ST for a bit already.
Originally Posted by Vas_Z33
shhhhweeettt
Vas, get that engine in there and you cant be the guinea pig for the GT3076r turbos.
Old Jan 9, 2011 | 07:21 AM
Vas_Z33's Avatar
Vas_Z33
mhaha... tease
Old Jan 9, 2011 | 08:47 AM
graffkid732's Avatar
graffkid732
Sounds good can't wait for final results of overall product.
Old Jan 9, 2011 | 09:08 AM
Boosted Performance
Well, I was goingt to put a few hours in today but we (wife and kids) decided to spend the day here:
It is 2deg F outside (-15deg F with wind chill factor), so it will be good to get away from it all for the afternoon. We also just got through a winter storm..so driving should be fun.
Old Jan 9, 2011 | 09:14 AM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
looks awesome congrats. Looks like im kinda glad im waiting for a kit. I was gonna buy next month but i think me buying a DD (2005 tahoe Z71) will prove to b a smarter purchase before a turbo kit
Old Jan 9, 2011 | 09:15 AM
IslandZavage's Avatar
IslandZavage
Damn.... now that's a water slide.... where is that?
