A must for an FI kit that uses oem maf tube. Treadstone replacement maf bung and tube
Old Jan 16, 2011 | 10:42 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
Default A must for an FI kit that uses oem maf tube. Treadstone replacement maf bung and tube
For those that want to quickly replace their OEM maf tube and eliminate a potential leak location between the maf tube and the adapter the kit manufacturer provides.
http://www.treadstoneperformance.com...+Hitachi+Style
I got the 3" low for my Greddy TT kit. Fit well. The only downside is that the maf bung is now a bit lower than before. The pipe is 6" long. My greddy setup with gasket between flat surfaces was 6.4". The difference was negligible.
Reason why I got rid of the OEM setup:
1. OEM is plastic = weak. Feared I would crack it with t-bolt clamp
2. OEM has a small bead. Coupler/Clamp has a hard time sealing/holding onto the oem maf tube
3. Removes the flat sealing surface between the oem maf tube and flange provided by greddy. 1 less boost leak
4. I can powdercoat it to match
5. Both ends are beaded
Drawbacks:
1. Its only 3" while greddy uses 80mm piping here. Not a big difference but its not the same. Oem is also 3" though so its not a big deal.
2. Lowers the maf bung. Probably would have been better to have my welder weld in a bung to a piece of aluminum with an offset
Old Feb 5, 2011 | 07:37 AM
litoflow's Avatar
litoflow
Nice Find Cux, I'm definitely getting this.
Old Feb 5, 2011 | 08:13 PM
bbs350z's Avatar
bbs350z
+1 nice find.
Old Feb 7, 2011 | 02:50 PM
ADMAN's Avatar
ADMAN
Old Oct 16, 2011 | 05:52 PM
rcdash's Avatar
rcdash
Does anyone know where to source a plate that can block off the bung? I don't require a MAF sensor any longer (using MAF output table of Haltech to simulate a signal). Thanks!
PS. I don't have this exact piece but I have a similar bung. My MAF bung is welded into my JWT charge pipe, so I cannot just swap out a 6" section with straight pipe.
Old Oct 16, 2011 | 07:32 PM
Boosted Performance's Avatar
Boosted Performance
Vendor - Former Vendor
I can make one for you and send it out. You pay shiping and the plate is free... You helped me out with the Haltech a while back, I can return the favor.
I have these MAF sensors in stock as well, because I use them on the charge pipes for the turbo kits.
Old Oct 17, 2011 | 05:47 AM
str8dum1's Avatar
str8dum1
i'd buy one as well
Old Oct 31, 2011 | 09:05 AM
winNvegas's Avatar
winNvegas
Default selling my maf pipe adapter
erased
Old Oct 31, 2011 | 05:54 PM
Cass007's Avatar
Cass007
Originally Posted by winNvegas
Bought this exact part a week ago. Took my intake apart and tested for leak and there was none. I was thinking my rough idle was due to some air leaking around the stock maf pipe. So, since im a believer of "if it aint broke, dont fix it", i want to sell it. 50 bucks and you pay for shipping. PM me if interested. I did not even attempt to place this part on my car. I don't even think there are fingerprint smudges on the pipe. Let me know if you want pics. Thanks!
Start a real sale thread in the intake or engine section, follow the rules
Dr.Paulyy
Jul 29, 2019 07:45 AM
codek
Sep 28, 2015 03:03 AM
FromGtoZ
Sep 20, 2015 03:41 PM
juang20
Intake
Sep 7, 2015 05:37 PM
