turbo or NA?
Old Feb 11, 2011 | 12:18 PM
  #41
Blu_Blur's Avatar
Blu_Blur
Originally Posted by Nexx
i have to agree, how you drive it has a great deal with how long a stock block boosted lasts. but whats the point of babying it? i dont drive mine often but when i do i thrash it as much as possible.
Who said anything about babying it? This isn't just a white and black issue. There is a huge gray area inbetween where you can get in to boost and have that thrill without going WOT or going in to the last 1 or 2 thousand revs.
Old Feb 11, 2011 | 12:19 PM
  #42
Blu_Blur's Avatar
Blu_Blur
Originally Posted by ttg35fort
The stock block is not built to handle 600 hp. The rods won't hold up. Also, I'm not sure how well the stock bearings will do.
As others have said, even at 400 whp it may not last long if you drive hard. Some people who are gentle on the motor do get reasonable life out of their boosted stock blocks, but what's the point of going through all of this if you are going to be gentle with it.
Note the piston compression ratio. He plans to build it to get to that number or beyond.
Old Feb 11, 2011 | 12:22 PM
  #43
Blu_Blur's Avatar
Blu_Blur
What's the point of going through the money and time to boost the car then beating the crap out of your stock motor only for it to get destroyed a few months later?
Old Feb 11, 2011 | 12:23 PM
  #44
thatv35guy's Avatar
thatv35guy
I bent a rod on Friday on my 3rd down the drag strip, conservative boost pressure (4.5 psi), low power (360 whp), a good EMS and a conservative tune with AFR tuned in the 11’s, I had 6k miles with boost on the engine, lol. The car was running great prior to failure. It’s just a gamble.
It happened during this run (I’m the G35 coupe):
http://www.youtube.com/watch?v=RQOsuE9KeVg
Old Feb 11, 2011 | 12:27 PM
  #45
erichsherrill's Avatar
erichsherrill
Originally Posted by Blu_Blur
No. I don't drive like your grandmother. I just don't beat the crap out of my car. That will come when I do a full build.
so if ur only in boost a few seconds when a camaro porsche or corvette wants to race.. then your stock block will hold.. i wish i knew this before
Old Feb 11, 2011 | 12:31 PM
  #46
mgrotel's Avatar
mgrotel
The motor is still in the car. I have a complete spare motor sitting beside it that I am building. Either way, I am building the motor to withstand 600hp. The only difference will be compression and cams depending on which route I go. Sorry for the confusion, didn’t mean to confuse. I would love an ls2, but my gut tells me that will be the most expensive and biggest headache. Its not a dd, I have 3 vehicles, soon to have 4. I travel for work each week so its usually only driven weekend. The car will be used for canyons, autocross, and nice days around town.
If I could guarantee that 400hp would be reliable, id go turbo in a heartbeat, but its not worth it to me if ill have problems half the time, which im reading that I will likely. Thanks for the replies, prob going to stay NA .
Old Feb 11, 2011 | 12:34 PM
  #47
rh_334's Avatar
rh_334
Yea its a gamble, but im on the opposite end of the stock limits, 10.5psi making 484+rwhp and have had nearly 60 boosted 1/4mile runs, and almost 100 NA. Almost 100 boosted Dyno pulls and nearly 350 NA pulls. And im at 101k miles (6k boosted) and beat the living sh*t out of it everyday. So some are just stronger than others. I just hope mine says that way
Old Feb 11, 2011 | 12:38 PM
  #48
thatv35guy's Avatar
thatv35guy
Thumbs up
Yeah, I hate you, lol
Edit: your posts/tread prompted me to buy a boost controller last week; I wanted to take it the strip before I increased the boost so I went that Friday. I never even got a chance to use it, lol
Good luck though! I hope your engine stays together for a long time!
  #49
ttg35fort's Avatar
ttg35fort
Professional
By not being gentle, I don't mean beat the crap out of it, but I would not leave the block stock either, as I indicated.
Going through the time and expense of my build, I am going to push the motor. "That is why I am building it" (quote from Alberto's video). That said, I have alot of strengthening done to my shortblock - closed deck, billit girdle, billit main caps, etc. We'll see how well it holds up. It does not have to be my DD. It will mostly be used on nice days and weekends, and once a month on a road course. My Toyo R888s suck in the rain so, essentially, I'll avoid driving it in nasty weather and take the CTS on those days.
Old Feb 11, 2011 | 12:40 PM
  #50
erichsherrill
no dont go NA cause i wanna see the 600whp capable vq35de turbo that u produce well under 15k
Old Feb 11, 2011 | 12:42 PM
  #51
ttg35fort's Avatar
ttg35fort
Professional
The compression ratio he selects should be based on how he will use the motor. If he is N/A, go with high compression. For 400 whp, 10.3:1 probably will be fine on premium. For 600 whp, I would go 8.5:1. On my last motor I was 8.8:1, and we were pushing the limits of 93 octane at 600 whp (Mustang dyno). 9:1 probably would be fine if running meth/water injection. As others have said, a lot has to do with the tune.
FYI, I overreved my first motor and destroyed a rod bearing. I was doing a WOT shift with a borrowed EMS. It's a long story. The rods and pistons were still in good shape, though.
Old Feb 11, 2011 | 01:00 PM
  #52
Blu_Blur's Avatar
Blu_Blur
Did you blow your motor? I see in your sig that you're built now.
Old Feb 11, 2011 | 01:02 PM
  #53
Blu_Blur's Avatar
Blu_Blur
Yeah I know all that. I'm just saying your response to him cited he was going ona stock block but in the first post, he mentioned a dramatically different ratio from stock implying he is going with aftermarket performance pistons for an engine build.
Old Feb 11, 2011 | 01:04 PM
  #54
Blu_Blur's Avatar
Blu_Blur
Right right. That's what I said in another post was that it isn't white and black and ther eis a huge gray area in between.
Anyways, I see how you use your Z is simialr to mine as I have another car.
Good luck with your car and I hope it holds-up for a long time.
Old Feb 11, 2011 | 01:09 PM
  #55
mgrotel's Avatar
mgrotel
what the hell parts would force the build to be that much?
600hp pistons/rods $1200
cams $1100
valvetrain $1000
machining & bearings $1200
gaskets and oil pump $500
random other things $1000
and thats top end pricing on those for a total of $6000. Absolutely TOPS!
where are you getting $15k? or did you just read that somewhere
Old Feb 11, 2011 | 01:19 PM
  #56
usingthejohn's Avatar
usingthejohn
There's also fueling, cooling, drivetrain, ECU, etc.
RFS 2k
Drivetrain 700-2000, depending on your choice, or if bought used or not
Radiator and fans: 700-100(?)
ECU: 1-2k
cams $1100
valvetrain $1000
Old Feb 11, 2011 | 01:29 PM
  #57
ttg35fort's Avatar
ttg35fort
Professional
Thank you. It's a G35.
It's a high performance motor that is going to be pushed. It's 4.0L with 8.5:1 compression, so should be between 650 and 700 whp on 93 octane, and I'm hoping for 750 whp with meth injection. I'll consider myself lucky if I get 30k miles out of it before I need to re-build. We'll see. I have the rods, pistons and crank from my first 3.5L build. I may use those to build a backup short block to have ready when it is time to re-buld the 4.0L.
Old Feb 11, 2011 | 01:43 PM
  #58
Blu_Blur's Avatar
Blu_Blur
Oh, it's a G35? Then I hope it blows up in yo FACE!!!!!
Old Feb 11, 2011 | 02:54 PM
  #59
superchargedg's Avatar
superchargedg
Damn Noobs
I agree with what you said as Bert says i drive like an old grandma too.
Old Feb 11, 2011 | 03:37 PM
  #60
mgrotel's Avatar
mgrotel
RFS 2k
ECU: 1-2k
rfs is only needed with FI so i consider that part of the cost of the turbo option. ive done some diy tuning and actually pulled fuel so far.
im confused why you list drivetrain as part of a built motor, what i have is fine anyway. would likely be around 4500, maybe 5500 if i throw in a 3.9FD
you have a point, ill add a radiator for $350
already have a utec,
so still at only 6350$, but that is a very high estimate
