Another Turbonetics dyno Graph problem.
Old Feb 11, 2011 | 03:01 PM
twitch579's Avatar
twitch579
Default Another Turbonetics dyno Graph problem.
Well got my o2 sensors changed and my AF straightned out and is not running 10's anymore. Its a steady 11.0 untill redline. Also got back some more power from the dyno last week where I maxed out at 323/343Tq at 9lbs lol.
I just cant figure out whats going on past 5500Rpms. The dyno gets all crazy and drops in power way to early compared to other TN dynos. Does anyone have any ideas what could be causing that?
Could it be im running a 4lb spring in the wastegate and its fluttering at high boost levels? I have a AEM tru boost controller.
The 3 runs were all at 3 different boost levels. First run was only 7bs, next 2 were 9lbs and 9.30lbs.
Thanks guys.
Attached Thumbnails Another Turbonetics dyno Graph problem.-dfasdfasdfas.jpg
Old Feb 11, 2011 | 07:59 PM
athens2jz's Avatar
athens2jz
who ever tuned your car is an idiot, take it to a good tuner and get that **** fixed. stop the nickle and dime **** and take it somewere that can tell the difference between a supercharger and a turbocharger.
Old Feb 11, 2011 | 09:11 PM
twitch579's Avatar
twitch579
I paid top dollar at a Uprev Pro Tuner. What makes you think its the tune thats screwed up? The place that tuned the car has tuned hundreds of cars locally that are all running fine.
Old Feb 11, 2011 | 09:32 PM
JS04's Avatar
JS04
Wow your numbers are pretty close to what mine were on a really conservative tune on 9lbs. 367hp/381tq.
Old Feb 12, 2011 | 07:25 AM
Vince@R/TTuning's Avatar
Vince@R/TTuning
Vendor - Former Vendor
smoothing on the graph is set at zero...so that doesn't help the sharp lil peaks and valleys....but it also looks like timing is a lil low up high. Torque on the TN kits drop off pretty good up high so usually you can ramp the timing up pretty good on them...smooth that out a bit..
Old Feb 12, 2011 | 08:25 AM
twitch579's Avatar
twitch579
I think we were having an issue with hearing knock in the upper rpms. So they backed the timing off alot up top untill we figured it out. I just also pulled my plugs and seen that there gapped at 45-50 so that could have been another issue.
I will post up a graph with the smoothing set at 5
Old Feb 12, 2011 | 09:16 AM
twitch579's Avatar
twitch579
ALso thanks for the fast shipping on the HPX maf sensor!
Old Feb 14, 2011 | 05:42 AM
Vince@R/TTuning
^^^ yea def... I thought i recognized the name...and at first i was like... "Another Turbonetics dyno Graph problem"... i hope i didnt tune this car...lol
The Plug GAP def isnt help the issue you may be having... we set ours between .028-.032...fix that gap and see it the car smooths out...
Old Feb 14, 2011 | 05:48 AM
ttg35fort's Avatar
ttg35fort
Professional
Why is it tuned so rich at 3k rpm?
Old Feb 14, 2011 | 06:36 AM
wannabuy350z's Avatar
wannabuy350z
^tip in enrichment too aggressive looks like it.
liqalu04
Jan 2, 2022 12:58 PM
AbrasiveRaysive
Sep 20, 2021 02:29 PM
Uriyo_
Sep 8, 2021 08:46 AM
3vilbunny
Jul 18, 2017 05:10 PM
