My FI story
Old Dec 21, 2011 | 03:42 PM
  #121
binder's Avatar
binder
Originally Posted by bjmax
Update.
after an other google sesion i found that the 03 Z/G can have a problem with the haltech firmeware later than V1.0
That problem was with version 1.06 and i never actually experienced it. I think rich was the only person that experienced it and it went away with 1.07.
In one of those pics the drivers bank secondary timing chain isn't lined up with the colored links. that doesn't mean it's off but it's not good practice to not use the colored links to guide you.
I know it's working now so that's good news. A bad connection at any of the connectors would explain any issues you had.
Old Dec 21, 2011 | 04:25 PM
  #122
supblkz's Avatar
supblkz
Great build story!! love the color and glad 2 see your issue is done and over with. Cant wait to see the numbers it puts out.
Old Dec 21, 2011 | 11:52 PM
  #123
bjmax's Avatar
bjmax
yep finaly
Old Dec 22, 2011 | 11:02 PM
  #124
bjmax's Avatar
bjmax
To bad... but after a night if got the nice P0300 and P0021 Back.. how nice is that.
cleaned the connectors again. no result again a new cam sensor.. no luck..
found a nice timing chian tester.. idon't think it is that but Pfff....
http://www.jimwolftechnology.com/wol...c_template.pdf
Old Dec 23, 2011 | 08:21 AM
  #125
bjmax's Avatar
bjmax
Again a new selenoid. And finally I can say it is solved. After turning it of I disconnected the ecu and haltech. Pulled and pushed all wiring just to make sure. Start and no problem. Back the old selenoid and the problem was there. So the first was totaly death, the second one half working. Can't beleve it. Tomorrow break in on dyno.
Old Dec 23, 2011 | 10:13 AM
  #126
binder's Avatar
binder
cam solenoid?
Old Dec 23, 2011 | 10:30 AM
  #127
bjmax's Avatar
bjmax
Yes intake Cam solenoid
Old Dec 24, 2011 | 07:34 AM
  #128
mgrotel's Avatar
mgrotel
Is that the deal that mounts on top of the front cam cap?
Old Dec 24, 2011 | 07:49 AM
  #129
bjmax's Avatar
bjmax
this is the one.
Old Dec 24, 2011 | 08:43 AM
  #130
bjmax's Avatar
bjmax
De eerste metertjes..
Old Dec 24, 2011 | 09:29 AM
  #131
mgrotel's Avatar
mgrotel
Sick!
Old Dec 24, 2011 | 10:58 AM
  #132
GreenGoblin's Avatar
GreenGoblin
Very nice, glad to see you got it.
Old Dec 26, 2011 | 11:44 PM
  #133
bjmax's Avatar
bjmax
An other vidio
Old Dec 27, 2011 | 06:58 AM
  #134
Boosted Performance's Avatar
Boosted Performance
Vendor - Former Vendor
Looks like all the hard work is paying off. Good luck with the final tune.
Old Jan 3, 2012 | 11:35 PM
  #135
bjmax's Avatar
bjmax
Smal update The engine is running fine. it had now 5 hours of dyno. this week we are going to put some FI on it...
What oil temp is normal on a TT setup??
Old Jan 4, 2012 | 06:20 AM
  #136
str8dum1's Avatar
str8dum1
oil temp should be the same as NA. 170-200 on the high end.
Old Jan 4, 2012 | 08:55 AM
  #137
binder's Avatar
binder
yep. just because it's more power doesn't mean you want more heat. Sometimes you get it, but you should keep it within normal temps best as possible.
I think mine got to 220* at one point doing back to back high boost builds on the dyno but the rest of the day it was down hovering around 200* and it's normally 180-190 on the street with better airflow.
Old Jan 11, 2012 | 05:14 AM
  #138
bjmax's Avatar
bjmax
connected the oilcooler with none leaking hose :-) and it stayes around 195 under load.
the car has seen now 7250 rpm and 10 PSI
oil change new filter and going for a final tune.. tomorrow.. will post a Youtube link later..
Old Jan 11, 2012 | 06:18 AM
  #139
bjmax's Avatar
bjmax
http://www.youtube.com/watch?v=NvJGwgxyQAA
Old Jan 11, 2012 | 07:17 AM
  #140
Total D's Avatar
Total D
Nice build Johan, very clean and well done. What numbers are you putting out?
Jeremiah
