My FI story
Old Nov 30, 2011 | 01:12 PM
  #101
bjmax's Avatar
bjmax
Bank 2 is 14.3 and bank 1 is 10.6.
Old Nov 30, 2011 | 05:58 PM
  #102
binder's Avatar
binder
That's too vague for us. What load cell and rpm and where does it change, etc. Since a/f is constantly changing it's hard to pin it down with just one reading.
Unless you are saying it is pegged there continuously. That's a little more variance than mine. I see in my -18inhg area at low rpm sometimes a 10-15% difference but it's transient so no big deal.
Old Nov 30, 2011 | 10:03 PM
  #103
bjmax's Avatar
bjmax
Iam going to the shop tomorrow and give you an update about the rpm and a/f settings.
I know when I pulled the sparksplugs all 3 where wet. So 1 malfunctional injector that's not the case.
Thx all for thinking with me
Old Dec 1, 2011 | 04:24 AM
  #104
rcdash's Avatar
rcdash
Free reving the engine is not a good way to test for balanced AFRs. There is so little fuel being injected that lopsided AFR is not at all unexpected... Test it under load (on the dyno or on the road) and I'm sure the AFRs will be perfectly balanced.
Old Dec 1, 2011 | 07:26 AM
  #105
binder's Avatar
binder
ah, i was suggesting based on just bank a/f and didn't realize that all 3 plugs were wet.
1 stuck injector on my room mates turbocoupe caused 9:1 a/f but of course when we pulled plugs we easily found the culprit.
The upstream air leak explains a whole bank issue. if there is an air leak then the o2 corrections would be overcompensating thus pouring fuel into that bank to fix the fake lean condition.
Old Dec 4, 2011 | 03:47 AM
  #106
bjmax's Avatar
bjmax
Solved the problem changed the cam timing sensor and the O2. But now we have a P0300 error.
Old Dec 4, 2011 | 02:01 PM
  #107
binder's Avatar
binder
check to make sure all injector and coil wiring connectors are tight.
Old Dec 4, 2011 | 10:31 PM
  #108
bjmax's Avatar
bjmax
Ill do that. I have 6 spare coils I'll put them in and see. If that is not the problem I'll see if the voltage is oke. Can it be also the CPS?
Old Dec 6, 2011 | 12:47 PM
  #109
bjmax's Avatar
bjmax
Changes the sparks, coils and CPS to be sure that tats working fine. Still the nice 300 error misfire...... Started the engine toke the connector off an on the 1,3 and 5 almost no change in running.. 2, 4 and 6 direct rpm drop.
I have looked at the power to the coils all have 12v
Anny suggestions? Can it be an other sensor?
O2 and CPS are already changed on tha bank.
Old Dec 18, 2011 | 09:59 AM
  #110
bjmax's Avatar
bjmax
OKe. after changing everything including the wirering Harnas. I still have the P0300 code. Puting the engine piston 1 on DC taking a cam i found that cilinder 1 is closed at compresion and number 4 was open at the exhaust site... so it is a timing issue..
at installing i had the same issue as
https://my350z.com/forum/engine-and-...-question.html
look my setting below..
I turned the crank a little bit so the markings comes out ok it seems that i messed up there. I have to open the VQ and change the chain.
Do i have to turn the crank couter clock 1 teeth and don't let the marking match?
Old Dec 19, 2011 | 02:32 PM
  #111
tollboothwilley's Avatar
tollboothwilley
Verify the markings from the secondary timing chains are accurate with the timing marks. The markings of the secondary chains are not visible from front view so it is a little more difficult to verify in the picture.
Particularly pay attention to the bank that was having issues with AF ratios while running as that is your likely culprit here. It explains why only half the engine had AF issues, whereas the crank being off would have thrown the whole engine AF out of whack.
Old Dec 20, 2011 | 07:51 AM
  #112
mgrotel's Avatar
mgrotel
what tollbooth said, and why dont your secondary chains have colored markings on them? good luck
Old Dec 20, 2011 | 09:59 PM
  #113
tollboothwilley
The secondary chains should have the color on the back side I believe
Old Dec 21, 2011 | 06:41 AM
  #114
mgrotel's Avatar
mgrotel
my secondarys had the color on the front side
Old Dec 21, 2011 | 10:12 AM
  #115
bjmax's Avatar
bjmax
Update.
Walked tru the timng. thats ok. so mgrotel the timing is ok.
looked at the nismo inlet cams and time points all ok.
flywheel timing compared to stock. same there.
after an other google sesion i found that the 03 Z/G can have a problem with the haltech firmeware later than V1.0
so i took out the haltech... started it. again the F# P0300......
The haltech back in the car.......... WTF..... It runs perfect....
turned the car off, waited 5 mins stated again.. No problems and no P0300 all cilinders running perfect.
I think it was somthing in the connector. but after 3 weeks of searching we can go on the the Next step....
the breakin on the dyno....
Old Dec 21, 2011 | 11:21 AM
  #116
mgrotel's Avatar
mgrotel
awesome! great news for the both of us! do you have a breakin tune for it?
Old Dec 21, 2011 | 11:29 AM
  #117
bjmax's Avatar
bjmax
First on vacum
Old Dec 21, 2011 | 12:30 PM
  #118
mgrotel's Avatar
mgrotel
then on boost! drool...
Old Dec 21, 2011 | 12:47 PM
  #119
f150intally's Avatar
f150intally
congrats on moving forward.
Old Dec 21, 2011 | 02:07 PM
  #120
suprasam's Avatar
suprasam
progress!!!! HUH ZAAA!!
