GTM GT3582R twin turbo
Old Mar 19, 2011 | 04:55 AM
SmallTuner's Avatar
SmallTuner
Default GTM GT3582R twin turbo
hey guys
i dunno from where i should start, but here is the dyno runs and graphs.
http://www.youtube.com/watch?v=f4_7ZKKUoJY
after i did some tuning for the intake variable cam control with 16 psi Crazy power came in 648whp and 564TRQ
all runs ar DIN CF
and still using old spark plugs from last year
first graph - 515whp 13 psi with valve float issue.
all are pump gas runs
Attached Thumbnails GTM GT3582R twin turbo-img_0315.jpg   GTM GT3582R twin turbo-img_0427.jpg
Old Mar 19, 2011 | 07:27 AM
diablox1's Avatar
diablox1
very nice. ur gonna track this car or just have fun on your desert streets out there?
Old Mar 19, 2011 | 01:11 PM
SmallTuner's Avatar
SmallTuner
its a STREET car !!
im still waiting to get new spark plugs from injectedperformance, so i can push the car more wi th some C16
hope to see around 750whp 18psi.
Old Mar 19, 2011 | 02:24 PM
Alberto's Avatar
Alberto
Cranky FI Owner
Good strong numbers.
Old Mar 19, 2011 | 02:25 PM
Kuwait350z's Avatar
Kuwait350z
Congratulation on the dyno result (: looking great! good luck on your next WHP goals
Old Mar 19, 2011 | 03:00 PM
SmallTuner's Avatar
SmallTuner
thanks Alberto
still dont like the power drop after 6200RPM
looks like the stock intake manifold is not helping me with my big turbos and big cams, specially with a 3.3FD
Old Mar 19, 2011 | 03:02 PM
SmallTuner's Avatar
SmallTuner
thanks bro
Old Mar 19, 2011 | 05:19 PM
midz350's Avatar
midz350
Nice numbers bro.
I'm trying to finish my car ASAP so I can ship it to you.
Old Mar 20, 2011 | 05:31 AM
SmallTuner's Avatar
SmallTuner
Originally Posted by midz350
Nice numbers bro.
don't worry bro, just give me a call.
Old Mar 20, 2011 | 06:44 PM
dikspiel's Avatar
dikspiel
Chestons Toilet
maybe get a cosworth intake manifold
Old Mar 20, 2011 | 06:50 PM
350zion's Avatar
350zion
Professional
Very nice...
Old Mar 21, 2011 | 03:39 AM
SmallTuner's Avatar
SmallTuner
i wish !!
is there any cosworth intake in stock ?
Old Mar 21, 2011 | 07:08 AM
dikspiel's Avatar
dikspiel
Chestons Toilet
A few shops carry it, I don't think you will have a problem finding one and it will help with the upper rpms.
Old Mar 24, 2011 | 08:08 PM
Jtran Studios's Avatar
Jtran Studios
Vendor - Former Vendor
Originally Posted by SmallTuner
thanks Alberto
how much cam timing do you have from 6200 and on? might have a little too much and that might be causing your hp drop up top.
Old Mar 25, 2011 | 10:34 AM
SmallTuner's Avatar
SmallTuner
thanks, but its not the cam timing.
im sure its the intake, thom000001 have the same issue, im not sure but he dont have a dyno run to 7000 RPM with out hp falling down.
i allso searchd and found some cars have the same issue.
they all use stock intake manifold.
n e way
im searching for a shop that have one cosworth in stock.
Old Mar 27, 2011 | 08:42 AM
Jtran Studios
so how much cam timing do you have up top? even on stock intake manifold with cams we still have a constant pull to redline.
Old Mar 27, 2011 | 09:01 AM
graffkid732's Avatar
graffkid732
Nice hope you get everything sorted out.
Old Mar 28, 2011 | 11:35 AM
SmallTuner's Avatar
SmallTuner
its 0 degree from 6100 .
Old Mar 29, 2011 | 02:36 PM
meatbag's Avatar
meatbag
On both the intake and exhaust?
Old Mar 29, 2011 | 06:41 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Rev up Engine? If not...cam phasing on the intake only.
If with stock cam timing, you shouldnt see a huge drop-off in power. Bone stock, the intake cams go to low single digits towards redline. Cam phasing only improves midrange power and turbo spool, assuming the cams are actually phasing correctly. A bigger cam, and a better intake will definitely help the cause, however.
