Another HKs Supercharger build
Old May 16, 2011 | 08:32 AM
Ruthless18x's Avatar
Ruthless18x
I'm totally going to copy you now...
Old May 16, 2011 | 08:41 AM
Flo-ridaZ33's Avatar
Flo-ridaZ33
Damn it
Old May 16, 2011 | 10:05 AM
Ruthless18x
Originally Posted by Flo-ridaZ33
Damn it
What gauges are you going to run? I just picked up some Defi Advanced, pretty sweet.
I remember hearing about running a larger crank pulley, like the dampened one, increasing the boost but you have to becareful not to overspin unit. Just an idea incase GTM can't do anything to the older unit.
Old May 16, 2011 | 10:32 AM
ImWeeZzel's Avatar
ImWeeZzel
suscribed for the build, stay safe out there homie
one more thing
Old May 16, 2011 | 10:39 AM
binder's Avatar
binder
that's a lot of expensive aftermarket goodies for 370hp (meth, haltech, etc)
Old May 16, 2011 | 10:53 AM
Wu-Watt's Avatar
Wu-Watt
Look into Motordynes shockwave exhaust.. Has the nice tips and better performance than the Greddy SE.
Old May 16, 2011 | 11:47 AM
dikspiel's Avatar
dikspiel
Chestons Toilet
Are you just doing methanol to keep temps cool? It might be easier just to do water only if you don't want to deal with refilling your methanol.
Old May 16, 2011 | 02:45 PM
jran76's Avatar
jran76
Originally Posted by Alberto
The past 3 or 4 days I have been helping a friend install a GTM S/C on a 370Z.
Took a ride in it yesterday logging some things, and no BS, I was "satisfied" with the linear pull the car made. Its no drag king or highway monster, but if way more FUN is what you are after, the S/C will do the trick, keep a smile on your face, and hopefully not break the motor, or the bank.
Clutch?
Hmmm.... I have been considering the GTM S/C for my 09 G37 sedan for the last few months (vs. buying a M3 or S4), but I am just not sure if I will completely satisfied at 400 WHP on the G. It is good to see some positive feedback from a FI lifer.... I saw the 370Z roadster build, and he had mentioned you helped with the install. Decisions, decisions....
OP, sorry for the OT.
Old May 16, 2011 | 02:51 PM
ITOzann's Avatar
ITOzann
PM WEIBOY. He's had GTM's and Stillen's superchargers installed.
Old May 16, 2011 | 02:58 PM
Chebosto's Avatar
Chebosto
I think I'm going to upgrade the VSLD to a Quaife, Z1auto Poly tranny mount, and SPL the whole rear diff but that's a little later though. I don't race, I'd love to start tracking the car so this would be more for a "just for fun" set up.
dont get the Quaife if you want to track in the future.. mechanical gear type LSDs will spin a wheel if you lift on a burm, its no bueno... clutch type is the way to go.
Old May 16, 2011 | 05:27 PM
_ink's Avatar
_ink
removed
Old May 16, 2011 | 08:01 PM
Flo-ridaZ33
Originally Posted by _ink
removed
inserted
Ok sounds good.
I'm getting it b/c it's coming with the kit... I'm not sure if I'm going to run it or not though.
If its a true dual(which I'm almost certain it is) it wont fit with the diffuser installed... if I could run a TD, it would be a HKS.
The meth is coming with the kit but I ordered the Haltec from Z1auto about a year ago when I still had the Greddy Tuner. The Haltec is overkill but that's what people tune down here in Miami. After reading VTR's intro thread and watching the owner for the UPREV just jumping in all over his ****, just made me never want to buy anything that involves him.
one more thing
LOL Thanks dude...
I'm not sure about the gauges yet... they'll have to be amber and I'd like to install them above the steering wheels so they're out of site.
Old May 16, 2011 | 09:31 PM
dikspiel's Avatar
dikspiel
Chestons Toilet
If you decide not to run it i would still install it and just use filtered water since it wont really be a hassle to refill.
Old May 17, 2011 | 03:27 AM
Flo-ridaZ33
How effective is filtered/distilled water over meth? Aside from the obvious, I know you can't drive around with a gallon of Meth in the car but if I'm not going to run it... is water that effective?
Old May 17, 2011 | 06:44 AM
str8dum1's Avatar
str8dum1
water is what does the majority of the cooling. since you are stock block, the cooling from water is all you need as you cant bump the timing much anyhow bc of the physical limitations of the rods.
Old May 17, 2011 | 06:51 AM
NA&CH's Avatar
NA&CH
Goodluck with the build Joel. This should complete an already well rounded car. Can't wait to see the car again
Chris
Old May 17, 2011 | 11:11 AM
jran76's Avatar
jran76
Thanks. I have been following his saga (I guess that is a good word for it). I am really waiting to see what the stage 2 kit can do, and GTM just posted some results today....
Old May 17, 2011 | 12:31 PM
  #38
the3kgt2's Avatar
the3kgt2
I'm not sure with the HKS kit, but I was able to fit a Koyo 54mm radiator with my Vortech by trimming a small bit of fan shroud. Twice the capacity of the 36mm and they're both the same price.
Old May 17, 2011 | 12:47 PM
  #39
dikspiel's Avatar
dikspiel
Chestons Toilet
the 36mm would be better for his setup.
Old May 17, 2011 | 01:36 PM
  #40
binder's Avatar
binder
ah, ic. Haltech is great so i'm not saying don't get it. If you have it by all means use it. I think it's pretty easy to tune with.
