Vortech V3 install, what all do I need??
Old Jun 7, 2011 | 04:45 AM
RandyK1's Avatar
RandyK1
Default Vortech V3 install, what all do I need??
Next year I want to have a Vortech V3 installed so this year I am trying to pick up everything I will need for the install. I would like to make this as easy on my motor as I can as to not brake anything or blow up anything. I am planing on using the V3 kit and not upgrading pulleys. I also want to have a Snow Performance meth injection kit installed at the same time.
The questions I have are:
1. Would I be safer running meth injection or not?
2. What meth injection kit would I need, stage 1, stage 2 or stage 3?
3. Would I be better off running Uprev insted of the stuff that comes with the V3 kit?
4. Would I be better off getting an UpRev upgraded HPX MAF sensor or sticking with my stock MAF?
5. Do I really need any gauges, if so what gauges?
6. Do I need anything else that I didnt think of??
Thanks for your help.
Old Jun 7, 2011 | 05:22 AM
Flo-ridaZ33's Avatar
Flo-ridaZ33
A search button... some things aren't covered but 90% of your questions are answered here. Check it out.
Old Jun 7, 2011 | 05:25 AM
RandyK1's Avatar
RandyK1
I did search but I didnt find anything final about everything together. Thanks
Old Jun 7, 2011 | 05:31 AM
05Z33's Avatar
05Z33
Take a minute any read through this thread. It is very informative and should answer all your questions. Also I would consider the Osiris. I would have gone that route my first time around if it was available.
https://my350z.com/forum/forced-indu...questions.html
Old Jun 7, 2011 | 06:26 AM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
if it was me no
see above
uprev hands down
Stock MAF
covered 100x please search. a lot is preference
we dont know what all you have so this is a hard question to answer
Old Jun 7, 2011 | 06:28 AM
tonyzS/C03's Avatar
tonyzS/C03
^+1 read through there and then ask if you are still iffy on anything. IMO though you shouldnt need meth at all, I ran a Vortech V2 blower for a long time on the 3.33 pully with no problems and that was on just the FMU that came with the kit, if the Osiris stuff had been around though I would have deff gone that route.
Old Jun 7, 2011 | 06:37 AM
chrisjersey06's Avatar
chrisjersey06
1,2- You can run it if you want, but its not needed for safety if you're sticking with the stock pulley. I don't have it and I daily drive the car.
3- Yes, Uprev is a worthy upgrade.
4- Depends on the power level. The stock maf in my car got maxed out while tuning, so an HPX went in.
5- "Need" and "should" are two different things. You don't necessarily need any, but its a good idea so you can keep tabs on things. All I have right now is boost and an AEM wideband. I would like to get a couple others such as oil temp, but that's just me.
6- Some of your other supporting mods should include a fuel pump and injectors, and if you plan on daily driving and/or tracking the car I'd add an oil cooler.
Old Jun 7, 2011 | 05:31 PM
kartkid's Avatar
kartkid
I think you should also be asking what HP are you shooting for?
I would go with larger injectors and pump.
You will need to get a new MAF as the stock will me maxed out
but as far as keeping it in one piece go with the a good tuner and UP-Rev
Good luck
Old Jun 8, 2011 | 03:27 AM
tonyzS/C03's Avatar
tonyzS/C03
You will need to get a new MAF as the stock will be maxed outbut as far as keeping it in one piece go with the a good tuner and UP-Rev
Good luck
As a point of reference I was making 368hp/303TQ with a stock MAF so unless your shooting for more than say about 400ish the stock MAF should be fine. If your staying with the stock pully I would def do a larger set of injectors (I was running 440cc DW's) and an intank 255 Walbro, and with the Up-Rev tune you'll be just fine and you'll be able to beat it like a red headed step child with no worries
Old Jun 11, 2011 | 08:40 AM
RandyK1's Avatar
RandyK1
I am thinking that 380-400 HP is where I would like to be. The list so far is: Vortech V3, Snow Performance Meth injection (stage ?), DW 440 injectors, fuel pump and an Uprev tune. I should be able to make a safe 380-400 HP I would think. I dont know what gauges I will be getting yet. I also dont know what stage Meth kit I need. I am still reading the Vortech thread.
Old Jun 11, 2011 | 09:18 AM
Flo-ridaZ33
I'd be a little careful with the meth system... since the supercharger is always boosting you'll definitely need to keep an eye on the meth level. Is your car a DD? I'm doing the HKS Supercharger myself and pretty much have my whole build list bought... now I need to get home to install it.
Old Jun 11, 2011 | 10:32 AM
RandyK1's Avatar
RandyK1
I would also be getting this http://www.snowperformance.net/product.php?pk=16 Low level indicator. I am planing on using my washer fluid tank for the meth so I would be adding the low level indicator to that. The main reason I want to run the meth kit is for my motor to last longer (cooler and cleaner) reason 2 would be for a little extra power
Old Jun 11, 2011 | 10:39 AM
Flo-ridaZ33
Your motor lasting longer will not be dependent on using meth or not... you'll be able to have a more aggressive tune. Unless you drive with a gallon of meth in your trunk I'd be careful and if this is a DD, it's not recommended. More FI guys will comment on this but your logic is flawed.
Old Jun 11, 2011 | 10:47 AM
RandyK1's Avatar
RandyK1
So its better not to use meth? It is for my DD and my logic is not flawed, but I am a F/I noob and that is why I ask these questions to learn. I have not ordered anything yet and wont be till this winter. My main goal is 380-400 HP and to not blow up my motor. The only things I have so far is high flow cats, Borla exhaust and a 3/8 plenum spacer. Thanks for all the help so far. I am still learning
Old Jun 11, 2011 | 12:15 PM
ITOzann's Avatar
ITOzann
At those power level, meth seems pointless IMO. Also, if there is a problem with the meth kit, what would you do?? at least look more into it before you think about getting it.
For the power levels If I was you I'd get larger injectors, fuel pump, PMAS MAF if required, and a standalone or the Osiris tuner kit.
Blowing up your motor will depend on the tune. You shouldn't be worry about it if you have a good tune and supporting mods.
There is a HUGE dedicated Vortech SC thread. All the answers you are looking for can be found in there. So don't be lazy and re-search some more. There is practically so much info about vortech in our forums.
P.S. I'd also add a thermostat and engine oil cooler if it is within your budget.
Old Jun 11, 2011 | 01:56 PM
Cass007's Avatar
Cass007
Skip the meth and spend that money on an A/F and boost gauge, or an oil temp gauge or something useful. Meth is for guys that are pushing tunes to the edge or for brief periods of high HP use, these things usually require a full stand alone EMS and they have a DD or low boost map to drive on 90% of the time.
Best advice... KISS (Keep It Simple Stupid). You are not re-inventing the wheel here. Others are giving you good advice. If you want to have meth so you can be cool and feel fast than just say so and thats fine. Pick a solid tuner and seek their input for your build as well.
Old Jun 11, 2011 | 04:22 PM
RandyK1's Avatar
RandyK1
Ok the meth kit is out. I do plan on using a good tuner and uprev. I am reading the vortech thread it just takes me a while to get through all that info. As for the 440cc injectors, dont you think that will be enough to reach 380_400hp or will I need larger injectors? I dont want to go anymore than380_400hp. With the $$$ I was going to spend on the meth kit I will buy some gauges.
Old Nov 26, 2011 | 04:57 PM
moreboost13's Avatar
moreboost13
did u ever finish this project? i run a vortech with upgraded pulleys and impeller boosting 11 psi, running a 3 gal meth tank in the trunk but it only kicks in after 7 psi. i daily this car but don't get into high boost on a daily basis and the meth lasts me over a month. its also got 440 injectors and a few other mods. made 437hp on a mustang dyno. if u want meth call rodney at alcoholinjectionsystems.com tell him what u r running and he will set u up with what u need. and if you do use your washer tank u don't need a low level indicator, your washer low level indicator will do the job
Old Nov 26, 2011 | 08:20 PM
Resmarted's Avatar
Resmarted
You can setup your meth injection to come on only at a set level of manifold pressure. With a supercharger that would be at xxxxrpm as boost is very linear. If your tuner knows what he is doing it shouldn't be any kind of an issue to setup. I'll run it on my dd but my car's kind of an oddball. That being said, do gauge setup first, and I'd do the hpx upgrade now rather than later.
Old Dec 6, 2011 | 04:25 PM
moreboost13
i set up my meth to come on at a certain psi of boost. alcohol injection systems sells a great kit that u can set to different boost levels. as far as i know you cant really control it by rpm unless you go with a fully programmable comp like haltech which =$$$$. i got my entire kit through alcohol injection systems ready to go for 500. u can upgrade to the hpx but not needed at all. im boosting up to 11psi at 6600 rpm and been running the factory maf with an osiris tune. best and most reliable performance upgrades i have ever done to any of my cars
BEBO'S ZEE
Jun 7, 2016 07:48 AM
NissanZcrazy
Nov 2, 2015 06:03 PM
seagrasser
Oct 11, 2015 03:27 PM
