350Z OE Fuel Pump Assembly and Pump
Old Jun 13, 2011 | 10:13 AM
Chris@DW's Avatar
Chris@DW
Default 350Z OE Fuel Pump Assembly and Pump
Hey guys/gals,
While doing some test fitting of the DW301 pump in the OE 350Z assembly, I went ahead and did some flow testing so we could have some stock vs. DW comparisons.
The OE fuel pump @ 13.5 volts flows in the assembly -
40psi - ~150LPH
50psi - ~135LPH
51psi - ~130LPH
The OE assembly has a built in fuel pressure regulator that starts to open around 50psi and fully opens between 51-52psi.
The DW301 pump @ 13.5 volts flows in the assembly -
40psi - ~305LPH
50psi - ~290LPH
51psi - ~270LPH
Outside of the assembly, the pumps flowed 6% more vs. flowing through the assembly. The OE 350Z pump flowed ~100LPH @ 80psi.
I figured since I had to opportunity to do these flow tests, might as well post the results, too.
-Chris
Old Jun 13, 2011 | 02:58 PM
350z006's Avatar
350z006
Nice...any chance you can do one vs Walbro 255?
Old Jun 13, 2011 | 04:08 PM
midz350's Avatar
midz350
Old Jun 13, 2011 | 07:18 PM
GreenGoblin's Avatar
GreenGoblin
Thank you for sharing that info.
Old Jun 13, 2011 | 07:26 PM
SH Luciano's Avatar
SH Luciano
Originally Posted by midz350
obviously that chart isn't application specific, which is why i think he was looking for a test against a walboro 255.
Old Jun 13, 2011 | 08:06 PM
Vq.turbo.DremZ's Avatar
Vq.turbo.DremZ
Why would the application determine how much a pump will flow? The rest of the fuel system will be the limitation, and most people who will use it will upgrade to RFS anyway.
Old Jun 14, 2011 | 02:49 AM
tonyzS/C03's Avatar
tonyzS/C03
because the housing inside the tank will affect flow diff for each application. like the results Chris posted from the start, outside the housing the stock pump flowed about 6% more. The chart is probably just showing the flow of the pump itself with no housings or anything to restrict flow.
Old Jun 14, 2011 | 08:40 AM
mx594's Avatar
mx594
Originally Posted by Chris@DW
Hey guys/gals,
40psi - ~150LPH
50psi - ~135LPH
51psi - ~130LPH
40psi - ~305LPH
50psi - ~290LPH
51psi - ~270LPH
-Chris
Any idea why the sudden drop between 50 and 51 psi? I mean from 40 to 50 it only dropped 15 LPH, but from 50 to 51 it dropped another 20 LPH? Seems like bad data.
Old Jun 14, 2011 | 09:11 AM
Chris@DW's Avatar
Chris@DW
The internal fuel pressure regulator starts opening @ 50psi and begins flowing fuel back into the tank. It is fully open between 51-52psi. The OE assembly will not allow pressure to increase above that, and flow cliff dives when the pump is attempted to be pushed above that.
etkms
Jun 19, 2022 06:30 PM
bcoffee20
Nov 19, 2015 06:39 PM
TrackFiddy
Sep 24, 2015 11:40 PM
