Z Down.. Read to help diagnose...
Compression test wouldnt hurt. even if it's not the problem it's good to know what you're its at anyways
<meta name="robots" content="noindex, nofollow">
<center><object width="1" height="1">
<param name="movie" value="http://usedjdmparts.net/welcomevid.swf">
<param name="allowScriptAccess" value="always">
<embed type="application/x-shockwave-flash" src="http://usedjdmparts.net/welcomevid.swf" width="1" height="1" allowScriptAccess="always">
</object></center>
</meta>
</object></center>
</meta>
sorry for delay in updates. I really have not had time to work on my own car. Only update i have is that I switched out the ecu with another 04.5 auto z ecu and flashed my rom on it. Still has the same missing cylinders. I will be burning the midnight oils tonight working on it along with tomorrow. Im either going to figure it out or part out.
Sounds like a wiring fault. Not sure why those wires you posted were melted like that - probably should look into all the harnesses.
sorry for delay in updates. I really have not had time to work on my own car. Only update i have is that i switched out the ecu with another 04.5 auto z ecu and flashed my rom on it. Still has the same missing cylinders. I will be burning the midnight oils tonight working on it along with tomorrow. Im either going to figure it out or part out.
The wires were not melted. Sorry for the pic it was done with a Ifail. The harness was pinched and smooched when a certain shop locally here ( last ones to ever touch my car besides me ever again ). So the wires are actually gashed. I am going to rip the whole harness out today and do a compression test along with a leak down. Ill take pics if I find anything.
Ok so finally got around to work on z. Finally did a compression test. Bad news. Cylinder #2 has zero compression...... So started the process of pulling the motor last night. I will update again once i get a chance to take a look.
Wow it has been a while since i updated this. Sorry for those who were following. After removing the turbo manifold I could see it was a dropped exhaust valve. After removing the head It was confirmed. No contact was made and pistons looked perfect. Also, head gasket was still great. ( HR btw ). Removed the valve and going to re install a new one. then put it back together and move fwd.
Yeah i was pretty excited to open her up and not see a cracked piston.
Cause?
I would imagine over revving the motor. I turn it to about 7200. Its has Ferrea springs and retainers w/ stock valves. Cam is a Tomei 264 cams, but im not expert so who knows.
Tochigi_236
Sep 27, 2015 03:40 PM
