Another GTM Install
Old Oct 1, 2011 | 06:34 PM
  #141
f150intally's Avatar
f150intally
I haven't neglected it dik. Just deciding on a street tire. My post already said I have a second set of wheels on which I will run Mickey Thompson's. Just trying to figure out a street tire.
Old Oct 1, 2011 | 06:57 PM
  #142
0jiggy0's Avatar
0jiggy0
Look you need real tires to put the power that you want to make down and you can't fit much on the stock rims. Stop being stubborn.
Old Oct 1, 2011 | 07:20 PM
  #143
f150intally
You punk-a$$s are right.... I was just trying to get something hold me over...
Old Oct 1, 2011 | 07:25 PM
  #144
dikspiel's Avatar
dikspiel
Chestons Toilet
you need a 285 at the least in the rear..which means proper rims..i am running a 295x35x19 and would love to go bigger if BFG made a larger size for KDW2's but they don't
Old Oct 2, 2011 | 02:35 AM
  #145
Resmarted's Avatar
Resmarted
Something I really considered before my car got raped in a parking lot and by a bicyclist is having the oem rear wheels (perhaps even front) widened. The process involves cutting the wheel around the circumference of the dish and inserting a strip of desired width. Gives you a stockish look and doesn't cost a sh*t ton. There are debates on the safety of this, but if you get a good shop/worker to do it (someone who's done it many many times) you shouldn't have an issue.
I personally have some TSW Nurburgring wheels and love em. Just wished I bought them after I went wide-body so I won't be forced to run spacers. Affordable, durable and pretty stylish.
Old Oct 2, 2011 | 03:49 AM
  #146
f150intally
Please priority rank the following:
1. Wheels/tires
2. Brakes
3. LSD
For wheels I was thinking either Enkei RP03 18X9 +18 F and 18x10 +22 R, or 5zigen fnc01 18x8.5 +15 and 18x9.5 +22 in silver.
Brakes - Akebono
LSD - Quaiffe.
Old Oct 2, 2011 | 08:25 AM
  #147
ace32x's Avatar
ace32x
1. Wheels/tires
2. Brakes
3. LSD
Brakes - Akebono
LSD - Quaiffe.
1. Wheels rpf 1s
2. LSD
3. Brakes
Old Oct 2, 2011 | 09:11 AM
  #148
binder's Avatar
binder
The minimum recommended width is 9" for a 275. My wheels are 8.5". I bet it will fit. Anyone done it?
Probably not a wise idea to go against what the engineers that designed the tires say. I would think that is a quick way to an accident.
CCW widens rims. 150$ per inch per wheel. so i guess you could get to 9.5" with 300$ if you're willing to wait.
We understand you have track rims but are you just going to grandma drive the car when you're on the street? probably not. It won't be fun on tires that will have zero traction.
Old Oct 2, 2011 | 10:56 AM
  #149
str8dum1's Avatar
str8dum1
i've been running 275s on my stock 8" rims for a while now. Thats what i made 898whp with on the dyno for my 1st build and also drive on them with my current build.
The barely pillow and are just fine to mount. Way safer than that f'n stupid hellaflush sh`t.
Old Oct 2, 2011 | 11:06 AM
  #150
dikspiel's Avatar
dikspiel
Chestons Toilet
this is generally done with in drag racing, i wouldnt risk it on a street driven or track car. If its $150 ish per rim he can use that money + the money he makes from selling his stocks to buy some rims in the sizes he needs.
Old Oct 2, 2011 | 11:32 AM
  #151
binder's Avatar
binder
wow, i wouldn't have guessed those would fit.
Old Oct 3, 2011 | 02:33 PM
  #152
f150intally
Peer pressure is a bish. I didn't want to get overly aggressive so I ordered a set of Enkei PF01s 18x9.5 +15 on all four corners. Thinking I may run Nitto NT555s 285-40/18s in the rear.
Props to John at OAKOS Automotive. Wheels were in stock. Got them in silver. Thanks for the input guys. I will be safe now.
Old Oct 3, 2011 | 03:44 PM
  #153
str8dum1's Avatar
str8dum1
and why not? I think I make more than enough power to determine that weldcraft does an excellent job in widening rims.
Old Oct 3, 2011 | 04:21 PM
  #154
0jiggy0's Avatar
0jiggy0
Nice choice OP. Thx for the post str8. I always wondered how that process held up.
Old Oct 3, 2011 | 06:56 PM
  #155
f150intally
Just ordered the Nitto NT555 285-40/18s for the rear. Think I may run the same tire in the front so I could rotate (front to rear). Opinions?
Old Oct 3, 2011 | 07:04 PM
  #156
dikspiel's Avatar
dikspiel
Chestons Toilet
will that fit with a +15 offset in the front?
Old Oct 3, 2011 | 07:35 PM
  #157
ace32x's Avatar
ace32x
i dont think thatd fit in the front with that off set, im +26 with a 9.5 up front and any bigger than a 275 and id rub i think
Old Oct 3, 2011 | 07:42 PM
  #158
f150intally
So far just the two back tires have been ordered. Wanted to get opinions first.
Old Oct 3, 2011 | 07:56 PM
  #159
ace32x's Avatar
ace32x
im going with a 255 for my fronts soon as i get my car gets wrapped up here, gonna go with some kdw's
Old Oct 3, 2011 | 08:03 PM
  #160
dikspiel's Avatar
dikspiel
Chestons Toilet
ive seen people run a 275x35 but idk about 285x40 with a +15 offset
