Vortech plus Apexi VAFC
Old Dec 11, 2003 | 10:43 AM
g356gear's Avatar
g356gear
Default Vortech plus Apexi VAFC
I wonder if using an Apexi S-afc II will interfere with the function of the timing computer that comes with the kit. I know on some MAF equipped cars the AFC changes the voltage at the MAF to trick the ecu to think there is more or less airflow......then giving more or less timing advance combined with an injector pulse width alteration. I wonder if they would fight one another for timing control.
Old Dec 11, 2003 | 11:21 AM
azrael's Avatar
azrael
You can't control timing via injector pulse modification. Timing refers to ignition (i.e. spark). The AFC is not capable of altering timing.
Old Dec 11, 2003 | 01:09 PM
g356gear's Avatar
g356gear
But as an example.....the EVO 8 ecu changes timing when the MAS signal is changed by the AFC. If you lean out the AFC , this gives a lower voltage to the ecu corresponding to less air coming into the engine and a lower engine load. To correspond to the decreased load the ecu advances timing. So, the more you increase or decrease the voltage to the ecu.....the more or less the ecu will change timing to correspond to perceived load. I wonder if Nissan has a similar feature in their VQ.
Old Dec 11, 2003 | 01:32 PM
PhoenixINX's Avatar
PhoenixINX
Good questions... Good points made.
I don't have ANY damn clue though...
Keep this one going though - good reading!
Old Dec 11, 2003 | 01:57 PM
g356gear's Avatar
g356gear
Maybe technosquare has the answer for us........CHESTON where are you???
Old Dec 11, 2003 | 08:14 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
Not true. Fuel and ignition timing are calculated by the ecu as a relationship...as one changes, so does the other.
Old Dec 11, 2003 | 10:47 PM
AxionF117's Avatar
AxionF117
the s-afc2 controls the fuel maps, you can adjust the fuel curve with these.
A VAFC which the thread is labed does this put also controls the high and low cam, which allows v-tec to kick is sooner. A VAFC is made for honda's not G35's
Old Dec 12, 2003 | 05:31 AM
g356gear's Avatar
g356gear
A VAFC which the thread is labed does this put also controls the high and low cam, which allows v-tec to kick is sooner. A VAFC is made for honda's not G35's [/B][/QUOTE]
Sorry...used to have a Honda vtec......oops. Talking about the SAFC in this thread.
Old Dec 12, 2003 | 07:43 AM
azrael's Avatar
azrael
yeah, but the post I was referring to implied that you could change timing by altering the injector pulse-width signal post-ECU, which isn't true.
Old Dec 12, 2003 | 08:53 AM
g356gear's Avatar
g356gear
But the SAFC is pre-ecu
350Z_Al
Oct 29, 2020 07:44 PM
Dr.Paulyy
Jul 29, 2019 07:45 AM
seagrasser
Oct 11, 2015 03:27 PM
Calinismo350z
Sep 14, 2015 04:04 PM
