New SARD Fuel Pump Arrived a day early
Old Dec 30, 2003 | 05:11 PM
  #41
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
hmm
Whats weird though is Walbro USED to ahev a high failure rate. We once sold them, then stopped becuase of it. We switched to the Denso unit from a Supra TT, never had any issues, though it was a bit more involved to install (not hard though). This was for many cars we worked on, from Evo's to Subaru's to DSm's, over the years. The we started hearing good things about Walbro about 2 years agao again..that they had fixed the previous failures, etc. We took a chance and in the last 2 years ahev sold damn near 1000 fuel pumps, and used many in our own shop cars, and have not had one come back.
They are noisier than the Denso's though.
Old Dec 30, 2003 | 05:54 PM
  #42
12SecZ's Avatar
12SecZ
Well Adam,
This is the exact reason why I don't like to speculate on parts I haven't used and stayed quiet.
Also due to PM overload I am posting a pic enlarged and zoomed in on my SARD pump so some certain people can look at it.
test link to pic still having upload problems
http://tinyurl.com/32lbb
Old Jan 8, 2004 | 08:39 PM
  #43
RBMotoring's Avatar
RBMotoring
Originally posted by 12SecZ
Have you read about the Denos Iridiums cermaic cracking lately on our imports?
I was leaning towards them till reading that.
I never shift past 6500, the raised rev limiter was part of the program, I went there for the timing, fuel and shift points. I would never rev my engine to 7k. I shift in manual mode at 6500 and it's screaming at that rpm saying shift, shift!
We have seen them crack on RB26DETT engines (in fact we have a real live example at our shop). What happened to the one we have at the shop was that the ceramic insulators in the plug fragmented off and fell into the combustion chamber, thus causing damage to the pistons and quench pads on the cylinder head of where the piston shoved the ceramic bits in the head.
Maybe the Denso plugs do not like any kind of detonation. I've personally had some experience with them on a Turbocharged 2.3L 4-Cyl putting down close to 700 wheel HP (drag car setup), but then again, that engine was running methanol race fuel, which does not allow any kind of detonation whatsoever.
I put them on a Honda motor recently that was running close to 11.5:1 compression, and so far, no bad news yet. Hard to say...several possibilities of what could make it happen, however, it's interesting to me that I see others having the same problems with the Denso plugs. The Denso irridiums we have are SARD units.
Old Jan 8, 2004 | 09:10 PM
  #44
RBMotoring's Avatar
RBMotoring
got me man
I guess I will find out lol.
Victor said the kit "includes the wiring you need."
I pay people to do stuff lol, if I didn't I would be rich!
I know this thread is long, so I figured I'll start replying post by post as I see fit. =)
First off....thank you Max for the kudos. Your support is greatly appreciated. The "wiring" is present because this pump, as with any fuel pump, relies heavily on it getting at least 13.5 volts for it to perform the way it needs to. The pump Max got will support up to about 500cc worth of injectors on a 6-cyl engine. With more voltage, it can support up to about 800cc or so...but that's with more voltage. To give you an idea of what I'm talking about, this pump at 16V will pump close to 340L/Hr.
...but you know, Max, the one thing that I honestly wasn't thinking about was the "returnless fuel system". Hmmmm..... I can't count how many times that dilemma has screwed my line of thoughts and reasoning up. Your returnless fuel system -might-not like that wiring setup............
But anways, back to the topic... So, with 380cc injectors the SARD 280L pump is easily capable of flowing up to 70psi of line pressure, so that means that it'll support up to 30 psi of boost provided that you have a base idle pressure of 40psi. With all said and done, only one other in tank fuel pump outflows the one that I suggested for Max to use, and that would be the Nismo pump we use in our GTR's. However, I thought that the Nismo pump will be too much pump and will also cost more than what he needed.
...k, back to reading! =)
Old Jan 8, 2004 | 09:14 PM
  #45
RBMotoring's Avatar
RBMotoring
Originally posted by Z1 Performance
Just as a follow up to this...
I would disagree with the above. Fuel pressure most definately should NOT remain constant. At idle, it should be in the low-mid 30 psi range (with the vacuum line connected to the regulator. At "0" psi, it should be in the low mid 40 psi range (it should also hit this same psi number if you disconnect the vacuum tube from teh stock fuel pressure regulator).
Under boost, pressure should increase 1 psi for every psi of boost you are seeing (again, assuming you are not using the DFMU...I am not really familiar with how it works so the above is assuming you are using a traditional means of enrichment).
In any event, can anyone post he diagram of the factory fuel delivery system from the owners manual...I am waiting for mine to come back after lending it out Looking at it in depth will tell you exactly where any potential weak links are.
Thanks!
Agreed.
Old Jan 8, 2004 | 09:18 PM
  #46
daking350's Avatar
daking350
according to the Nissan service manual, you should see EXACTLY 51psi @idle...
Old Jan 8, 2004 | 09:22 PM
  #47
RBMotoring's Avatar
RBMotoring
Adam,
Do you have a flow bench? I have the stock stuff.
Maybe they are over rated numbers or JDM spec numbers?
Like 287HP, it's just a number, none of us are seeing it at the crank are we?
Let me know.
Kinsler Fuel Injection (www.kinsler.com) is where my source got the Denso pump info that I used earlier.... Maybe with enough speculation (or maybe they already did it...) they will flow it....and flow it at different voltages. =)
Old Jan 9, 2004 | 04:16 AM
  #48
Guru's Avatar
Guru
I've had two cases of breaking also. Not the ceramic portion but the actual metal tip is very fragile and have had it break on both a high compression NA motor and a boosted motor. Neither car mas making more than 400 HP so very mild cars. I just use Blitz/NGK Platinum now as they always work, come pregapped and have never had a failure yet (knock on wood).
Old Jan 9, 2004 | 08:15 AM
  #49
Z1 Performance
Former Sponsor
thats weird......I cannot even count how many times I ahve used Denso Iridiums, and not once had a problem (have used HKS plugs too..same thing, at the customers request, and also have not had a problem). But thats the thing..everyone's experiences vary.
Old Jan 9, 2004 | 09:21 AM
  #50
G3po's Avatar
G3po
Default denso Iridiums
A definately possible cause of electrode and/or ceramic damage
could occur pre- plug installation. Due to the very hard electrode and thin ceramic (by design to improve spark energy to the chamber), these plugs can really easily be "stress fractured" during installation.
I have used them on a blown 4.7L B8 and not had any issues, but then again I really , really was careful to inspect and baby them durin installation.and I inspect them at each oil change. For example if, the Gap needs adjustment you need to follow the Denso recommended guidelines very closely.
I am still debating if I will use them when I FI my G35.
Old Jan 9, 2004 | 10:02 AM
  #51
RBMotoring's Avatar
RBMotoring
Undue care during installation could cause premature plug failure, but still....after reading these posts, it almost seems like Denso Irridium plugs cause too much of a liability risk. Eeeks...they gotta be good for something.... =) Maybe I can sell these SARD plugs to methanol burning drag cars.
Old Jan 9, 2004 | 12:18 PM
  #52
12SecZ's Avatar
12SecZ
Well thanks Victor!
I said they cracked but hey who am I. That is why it sort of gets old just speculating.
I have heard *several* stories of them cracking but hehe nobody listens to me. So from now on I will leave the answers to the experts and do what I do best, drive!
My track is OPEN! First run for me is Feb 4th!
Thanks for the pump, injectors and all of the support. I reccomend your Company to anyone needing go fast goodies!
You Da Man in m ybook, if it wasn't for you my setup wouldn't be right so the props works both ways!
Peas!
Old Jan 9, 2004 | 01:09 PM
  #53
RBMotoring's Avatar
RBMotoring
Thumbs up
Well thanks Victor!
Peas!
Same here Max. Thanks for being such a great customer!
Old Jan 9, 2004 | 03:49 PM
  #54
AgentOrange's Avatar
AgentOrange
well from reading this i called rb and im waiting to see which pumjp im going to use....i really respect rb for not selling me a defective product (walboro pump) but im hoping for a pump soon because i really want to go ointo the 8+psi
Old Jan 9, 2004 | 07:48 PM
  #55
12SecZ's Avatar
12SecZ
My stock pump today flowed very well Hehe, *BEG*
That was post flash to 380cc's, more than 51 at idle for sure. Where are these numbers coming from like 290cc and 210L? Is there a link to graphs on that? I was quoting someone else on the numbers. Chebost flowed the stock injectors, where did the 210L number originate at? I'm curiuos?? Anyone?
I have spoken to Victor today, we are gonna meet in person next week about this and have some fun. He is 30 minutes from TS! Road Trip!
A booster is also an option. I think out stock fuel pump is more than 210L or I got lucky that is why I want Victor to check out my setup in person (plus he has cool cars in his shop, Skylines, EVO's etc all SEMA show quality.)
When you call Victor ask about his injectors, stock is four very tiny holes (as in you can't see them.)
Try and count them (these are stock)
http://home.surewest.net/mailmax/injectorbest640.jpg
kyin
Oct 15, 2015 05:54 AM
