Ultimate Racing Turbo Kit SNEAK PEAK!
Old Mar 23, 2004 | 09:48 PM
  #121
03_ppw350z's Avatar
03_ppw350z
where can i find a diagram to hook the ignition harness to the emanage for the 350z ill take the chance
Old Jul 1, 2004 | 04:54 PM
  #122
ChrisMCagle's Avatar
ChrisMCagle
Default eManage Wiring for 350Z
Where can I find the general eManage unit wiring install for the 350Z? I just bought one for my Z, but the instructions that came with it only go up through the 300ZX. I called GReddy, but they said they didn't have any type of diagram or instructions for the 350Z (which is a load of BS if you ask me). Does anyone have the wiring diagram for the eManage unit and Injector harness for the 350Z?
-Chris
Old Jul 2, 2004 | 02:18 PM
  #123
accordfreak's Avatar
accordfreak
any updates on the final kit/ fuel setup?
Old Jul 9, 2004 | 05:59 AM
  #124
ether's Avatar
ether
Default Re: eManage Wiring for 350Z
-Chris
ou can download the turbo kit instructions here which has the emanage wiring instructions, best to go by the pin locations not the color codes
http://www.greddy.com/dir_tech.htm
if you going NA post up some info on how it goes, interested to find out how much it helps in an NA setup
Old Jul 9, 2004 | 09:48 AM
  #125
ChrisMCagle
Default Re: Re: eManage Wiring for 350Z
THANK YOU THANK YOU THANK YOU!!!
I got the eManage and injector harness on Tuesday, the RPM signal adapter on Wednesday, and the Clone Cable yesterday. Looks like I'll be tackling the install tomorrow. I'm not sure how I'll be able to tune it yet though because although I went and got a bung welded in, I still haven't gotten the wideband commander. I guess I can just install the eManage and not adjust anything yet so that it will still be using the ECU settings.
Who knows... if I get everything installed in time, I might swing by the dyno and get checked. I'd imagine that my A/F has gotten better since I took off the KINETIX plenum and put the stock one back on. Sadly, My car feels no different with the stock plenum over the KINETIX. Although it could be due the the fact that the KINETIX was cracked and therefore was hurting my power?
-Chris
Old Jul 9, 2004 | 11:05 AM
  #126
ttzofutah's Avatar
ttzofutah
Originally posted by Z1 Performance
Show it to me.......
I also have not any (that I recall) 1000 HP Honda B18's...not even the Pro series guys are making that much power yet last I checked.
Have you seen the heads yet? It's not going to happen unless a totally different casting is used.
I'm not being a naysayer here, just a realist I think.
Anyway, I am done...we can start another thread for this....back to Daryl's nice looking tubro kit
Lets put it this way, We have a 2.0 Honda pushing out 740whp on 26psi, and another 1.8 doin 690whp on 24psi. but 10.3@143, daily drivers. Aluminum blocks sleeved. So you are sayin that a 3.5 ltr motor will not do 1000whp? Look at Steph Papadakis, 3.2ltr V6 aluminum block, stock heads, and he is pushing out 1500whp.
so think about what you are sayin,
Danny
Old Jul 18, 2004 | 12:56 PM
  #127
TXSTYLE's Avatar
TXSTYLE
Whatever happened with this TT kit in the 1st post?
Old Jul 18, 2004 | 03:59 PM
  #128
shiva's Avatar
shiva
aalzuhair bought it
Old Aug 16, 2004 | 01:41 PM
  #129
Durrr's Avatar
Durrr
bumpage for some info
Old Aug 17, 2004 | 04:44 AM
  #130
aalzuhair's Avatar
aalzuhair
I will update you guys on the new TT and exhaust system and the twin carbon clutch and flywheel as soon as the car finish and tuned.
I should be ready by next week; I had the rear emblem place blocked so that had a bit of a delay. I had one try on the new exhaust system (Its the dual 2.5" pipes made by UR) it sound good.
Az
Old Sep 27, 2004 | 07:45 AM
  #131
ihatethatbobbarker's Avatar
ihatethatbobbarker
Originally posted by Mike Wazowski
hahahah.....i knew you guys were going to switch to twins
there's no way single will fit, so tight.....
UNTIL NOW bum bum bum
Old Feb 7, 2006 | 05:53 PM
  #132
Diesel350's Avatar
Diesel350
So what is the pricing with this kit? And can you use the UTEC with it?
Old Feb 7, 2006 | 06:11 PM
  #133
Acree's Avatar
Acree
Old Feb 7, 2006 | 06:27 PM
  #134
Vq.turbo.DremZ's Avatar
Vq.turbo.DremZ
wow this thread is old
Old Feb 7, 2006 | 08:58 PM
  #135
leeboyNY's Avatar
leeboyNY
Kimchi Eater
Old, but interesting however. So, I guess this TT kit never went into a production...
Old Feb 7, 2006 | 09:15 PM
  #136
manny007's Avatar
manny007
True that!
UltimateRacing any updates?
Old Feb 7, 2006 | 09:39 PM
  #137
manny007's Avatar
manny007
First pic there was a Equal length Turbo outlet joined into a Y
Second pic with K&N filters
Last mention you were useing the Greddy E-Manage
"350Z Twin Turbo Kit @ 8.5psi tuned with HKS F-CON V Pro
466.27 WHP - 463.72 FT.LBS"
I guess there has been some changeings.
Still impressive #'s
Old Feb 8, 2006 | 07:44 PM
  #138
Irb Digital's Avatar
Irb Digital
I checked the website, and it still claims that this kit is under development. I was going to go with UR when I had my S2000, and if this kit has a decent price and a release date in the near future, I'd be highly interested.
UR????? SOUND OFF!!!!
Old Feb 8, 2006 | 07:55 PM
  #139
NissanBlack350Z's Avatar
NissanBlack350Z
NICE
Old Feb 8, 2006 | 08:30 PM
  #140
kalima275Z's Avatar
kalima275Z
