Race Gas (C16/ VP import) for motor safety??
Old Aug 29, 2011 | 02:31 PM
djtimodj's Avatar
djtimodj
I think what straight is saying is dont use VP import or oxy fuels with out a tune. C16 is non oxy so can be used on my pump fuel tune.
Old Aug 29, 2011 | 04:24 PM
str8dum1's Avatar
str8dum1
Originally Posted by str8dum1
both Q16 and VP Import are oxygenated fuels, so like the guys at Injected have mentioned, those could possibly need a tune touch up. (also need to watch you injectors as the newer high Z bosch's have seals that swell with oxygenated fuels)
C16 is not oxygenated, so a mix would not change the AFRs
Originally Posted by InjectedPerf
Str8dum1, where are you getting your information? You are saying if you mix C16 with 93 octane you won't need to change your tune to compensate for the new fuel mixture?
VP fuels and plenty of logs down the strip.
I said you needed to touch up tune with oxygenated fuels, VP import and Q16, obviously. C16, no you dont.
And here's the math since this thread is looking for semantics
http://www.tpsperformance.com/blog/2...e-on-race-gas/
from the link...
C16 is easy to get and because of its close stoich to pump gas you do not have to worry about mixing ratios
VP C16: 14.77:1
I have changed out Q16 to VP Import (both oxygenated fuels) and AFR dropped by over 1.5 points. You don't think you would lose power with that rich of an AFR?
VP import is a 14.15 stoichio fuel.
Vp Q16: 13.43:1
http://www.modularfords.com/forums/f...8/index11.html
There is NO way you would drop 1.5 going from Q16 to VP import. YOu would barely if even at all get a 1.5 AFR drop if you went from straight pump gas to straight Q16, which is not what we are even discussing here.
Better yet, I've never seen anyone retune AFRs for non-ethanol gas and typical 10% ETOH gas
Pump Gas Non-ethanol: ~14.64:1
Pump Gas E10: ~14.08:1
Old Aug 29, 2011 | 06:52 PM
rcdash's Avatar
rcdash
Well, there's AFR/stoich ratio that is important for fueling but don't overlook the flame speed of the fuel and the octane, both of which impacts the timing adjustments to maximize power without knocking.
I do not know the flame speed and octane ratings for the fuels above, but I expect that a tune would be important to maximize power over a tune with timing designed around the flame speed and knock limitations of pump gas.
Old Aug 30, 2011 | 07:31 AM
str8dum1's Avatar
str8dum1
the discussion is based upon doing a fuel mixture at the track for added knock protection.
not about making more power.
C16+pump gas will do that will no adjustments to the tune. Mixing Q16 or VP Import may need an adjustment in the AFR tables, but probably not.
If he wanted to optimize that higher octane, then ya, you could def retune it more.
Old Aug 30, 2011 | 08:52 AM
binder's Avatar
binder
we do it on the race bikes all the time with no issues. c16 is close to pumpgas in respect tospecific gravity so even after the bike is tuned it doesn't change anything for us to throw race gas in. We do it because the bikes get a lot hotter and see a lot more abuse in a 45 minute moto than when we tune it in practice.
Last edited by binder; Aug 31, 2011 at 11:53 AM. Reason: had to fix my mistake....
Old Aug 31, 2011 | 10:18 AM
rcdash's Avatar
rcdash
ah, gotcha, makes sense...
Old Sep 21, 2011 | 10:07 PM
CTZ860's Avatar
CTZ860
Seems like there are some knowledgeable people on meth/water injection....
Aside from the hp gain and such is meth/water injection seen as making an engine run "safer" in general?
Would it be a good addition on a basic SC or turbod application?>
Old Sep 22, 2011 | 09:39 AM
eltness350's Avatar
eltness350
The Untouchable
u originally said u wanted "around" 110 octane fuel.....y dont u just buy a drum of that and have it tuned for it? plenty of race fuel brands with leaded and unleaded 110 octane for ya
Old Sep 22, 2011 | 12:59 PM
DaveJackson's Avatar
DaveJackson
Master
One company's opinion/resource info is here:
http://www.snowperformance.net/faqs_type.php?type=gasoline
Old Sep 22, 2011 | 01:14 PM
djtimodj's Avatar
djtimodj
Im not bothered by octane as long as im adding det protection! lol..I dont want more power! lol..
110 will have more det protection than 99 octane I normally run thats all..
Old Nov 22, 2011 | 01:59 AM
maXmood's Avatar
maXmood
Under Boost!
didn't wanna start a new thread....
how about using a meth kit to spray c16 instead of meth? nevermind the cost of the c16 compared to the meth. but i'm talking about how would that work?
Old Nov 22, 2011 | 04:13 AM
djamps's Avatar
djamps
I usually mix in a couple gallons of 103-109 octane unleaded to a quarter tank of 93 (because I have cats I can't just dump anything in there). My car made it's best times/traps with the mixture. No issues at all! 110 octane on a 93 tune seems a tad overkill, no? In a standing mile type event I would be more worried about exhaust and combustion chamber temps than detonation -- water/meth injection would do alot more for you than adding more and more octane.
Old Nov 24, 2011 | 10:03 PM
Resmarted's Avatar
Resmarted
well the main difference between pump and race tunes should be your timing and boost, and being a bit richer on pump. If you run less knock on race mixes I'd think you need a better tune more than anything.
Ill go back again to watermeth... the water doesn't really effect egt's (most say nearly no change) so that shouldn't hurt your cats. I'm thinking about running a cat on my setup and I already own a water/meth kit so thar be my 2c
Old Nov 24, 2011 | 10:06 PM
Resmarted's Avatar
Resmarted
I think that wouldn't even work because water/meth pumps were designed for pumping those fluids. race gas i'd imagine is thicker and could damage sh*t. I guess you could do a fuel pump and create a fuel injection kit... But that really would be a waste when meth/water will be easier cheaper and probably more effective (has to do with specific heat of water to reduce detonation).
Also tuning would be hard to pull off. You'd likely run really rich without weird compensations etc.. then if sh*t fails you get focked sooo hard.
Better off just adding it into your tank by miles. plus that sh*ts expensive.
Old Nov 25, 2011 | 04:59 AM
maXmood's Avatar
maXmood
Under Boost!
how thicker would it be?? i mean, it's still a fluid that could be compared to meth. plus, i don't think the pump will have difficulty pushing race gas.
i did mention in my post to never regard the price difference, so i'm not going into that.
if the tune is to pump meth @ certain PSI, then it's gonna be the same with race gas. so, driving anywhere without going into boost is the same case with both, being it meth or race gas.
does that make sense?
Old Nov 25, 2011 | 05:07 AM
Cass007's Avatar
Cass007
In theory the water/meth mix "atomizes" into the charge air. You would have to ensure that the fuel could do the same or it will pool and then BOOM.
Old Nov 26, 2011 | 01:17 AM
Resmarted's Avatar
Resmarted
+1 @cass
If you don't believe us, try and get it to work. Waste of time and money, and eventually a motor.
