APS Boost controller dranining battery, normal?
Old Oct 18, 2011 | 01:04 PM
aln's Avatar
aln
Originally Posted by slc-350z
Because I don't smoke? jk. Is that switched or constant?
Mine is switched, not sure it differs between japanese and us vehicles.
Old Oct 18, 2011 | 02:27 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
why not use the second pin on the haltech plug?
Old Oct 18, 2011 | 10:52 PM
aln's Avatar
aln
Since I found out that the Haltech unit doesn't have any internal fuses I rather try to power things from another source then risking doing something wrong and blowing my haltech up
Old Oct 19, 2011 | 07:56 AM
str8dum1's Avatar
str8dum1
so you dont want to wire up the solenoid correctly, then complain it draining your battery?
Odd way of doing things over there in Dublins.
Old Oct 19, 2011 | 08:01 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
Guess the idea of putting the fuse between the haltech and solenoid never crossed your mind? But running a fused wire directly to the battery did?
Old Oct 19, 2011 | 09:06 AM
aln's Avatar
aln
Was told to wire it in the way it's wired, never thought I'd drain the battery, thus posted here. I'd rather avoid finding out which of the cables to use coming out of the haltech and use another switched source, what's so wrong with that?
Old Oct 19, 2011 | 09:08 AM
aln's Avatar
aln
had a hard time finding out which cable of the 3 to use for the bcs, the APS solenoid comes with the fuse. Again was told to hook it up that way so didn't question why... What fuse would you stick in between the + (whichever that might be) and the Haltech? 5amp,10amp,15amp...
Old Oct 19, 2011 | 01:45 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
I would put the smallest fuse possible that does not cause nuisance trips.
Maybe 2 amp?
Old Oct 20, 2011 | 02:33 PM
binder's Avatar
binder
http://www.injectedperformance.com/h...structions.pdf
that's how it is wired. When the car is off the haltech is off so now drain on the battery.
about putting a fuse on it, i have no idea. Put a fuse on both of them i guess. I hope it doesn't cause interference with the solenoid though.
sales@czp
Sep 23, 2019 03:30 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
codek
Sep 28, 2015 03:03 AM
