see what i'm saying guys! more and more kit's are being installed without issues.
@Hal! did you guys replaced the plastic bosch bypass valve? looks different from my old kit
I didn't see it?
Here is the Bosch Bypass seen here with the kit:
I don't like em..had one in my 944 Turbo..they have internal rubber diaphrams that can crack and leak boost.
Here is a Forge unit that I would replace it with:
I didn't see it?
Has spring kit to adjust range:
hey, go back and look at Hal's picture. look at the charge pipe and it's right at the middle of the pipe. underneath it is where the bypass valve is located and it's definately different from my old setup. i think they got the Vortech bypass on there
Ok..just checking. Sounds good. I really think the Forge billet Bypass is a good alternative, since GTM SC also had problems with the Bosch unit as well.
yeah, the GTM S/C did have the fluttering issue with the plastic Bosch bpv. now they're using the Turbosmart bov/bpv. it sound's pretty good!
Actually..it's been out for 2 months.
CARB approved. Dyno chart shows 375WHP, but I've seen 370 Osiris tuned Stillen SC at 420WHP, so HR *should* hit 400 with Osiris.
