PLEASE HELP! g35 from Hell!
Old Feb 15, 2012 | 05:58 PM
  #61
danielsg's Avatar
danielsg
Originally Posted by bjmax
And when you disconnect a coil does it change in rpm?
i havent tried that yet, but i will tomorrow. i will post when im done.
Old Mar 7, 2012 | 07:09 PM
  #62
danielsg's Avatar
danielsg
heres an update.
i brought it to danny aka greengoblin. and he did a leak down test. we found something very supportive to my origional theory. bank 1 was perfect showing normal leak measures however bank 2 showed something a bit differant. all the cylinders at TDC were leaking slightly-when pushed a bit passed the mark for TDC for each cylinder, the leak will stop indicating that bank 2 is off timing. possible causes.
the machine shop decked my head to much? the small timing chain on bank 2 is off a tooth, the valve lash can be off on that bank only. this explains why the bank is lean even when the injectors are pushed to 80 % duty cycle on that bank. when boost kicks and the heads become pressurized, the pressure sends all the fuel past the exhaust valves before it can be ignited....
Old Mar 7, 2012 | 10:32 PM
  #63
bjmax's Avatar
bjmax
Jwt does have a template Under manuals so you can easily check if the timing is right.
Old Mar 8, 2012 | 01:43 AM
  #64
bjmax's Avatar
bjmax
http://www.jimwolftechnology.com/wol...c_template.pdf
Here it is
Old Mar 8, 2012 | 08:01 AM
  #65
djamps's Avatar
djamps
Originally Posted by djamps
bank2 cams aligned wrong, engine build issue
Probably off a tooth.
Old Mar 9, 2012 | 07:35 AM
  #66
thatv35guy's Avatar
thatv35guy
Check out my thread, I think we’ve got the same problem.
Old Mar 10, 2012 | 08:06 PM
  #67
danielsg's Avatar
danielsg
I pulled the car apart and the timing was spot on. I think its a decking issue, I have the head off and the valve lash clearance is very low .241-.279 on intake side and exhaust.
.279-.305 Everything is in the low side and bellow desired spec. Some were in spec but barely. Now I know that decking wouldn't mess with valve clearance but it's defiantly off. I'm replacing both heads and hopefully it will be back in order.
Old Mar 20, 2012 | 09:44 AM
  #68
danielsg's Avatar
danielsg
i put the new heads in and am awaiting a tune friday... i hope i have a fast car again... im so tired of this... what a pain....
JjL
East Canada
Jun 12, 2019 03:04 AM
HoBrahYouStink
Jun 24, 2016 10:58 PM
seagrasser
Oct 11, 2015 03:27 PM
