Who else is running the JWT 700BB kit?
Old Jan 16, 2012 | 08:16 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Default Who else is running the JWT 700BB kit?
Just curious who else is using the JWT 700BB kit?
Old Jan 16, 2012 | 09:31 AM
Eno's Avatar
Eno
Why- what's up?
Old Jan 16, 2012 | 09:34 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Curious to know what some WHP/WTQ numbers are with a built block. I'm in the process of having mine built now; https://my350z.com/forum/texas/54165...ore-boost.html
Old Jan 17, 2012 | 06:38 AM
tonyzS/C03's Avatar
tonyzS/C03
I'm running it, I made 450/410 on 12psi... built motor as well
Old Jan 17, 2012 | 07:02 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Why only 12psi? Figured with the built block you run 16+?
Old Jan 17, 2012 | 09:30 AM
Eno's Avatar
Eno
You can see my numbers already. I'm an AT so take that into account-
I'm currently getting that restriction knocked off the hot side of the turbos (apparently that small elbow looks bigger but is only about 2.25 or so on the inside) and going straight to 3" pipes into a 2.75 exhaust. I suspect that will boost numbers slightly- with stock heads I may be tapped out. I guess we'll see.
I'm hoping reducing this restriction will help bump up my torque numbers a bit.
Old Jan 17, 2012 | 10:20 AM
meatbag's Avatar
meatbag
300zx does around 550whp at 20psi on those turbos
Old Jan 17, 2012 | 05:09 PM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Well I hopping to break 600.
Old Jan 17, 2012 | 05:25 PM
Eno's Avatar
Eno
I presume you mean on pump gas?
Old Jan 17, 2012 | 05:48 PM
Ruthless18x's Avatar
Ruthless18x
eagletangreen ran a 700bb kit didn't he? Granted that was back in 08', he was well over 600whp.
Scratch that, he was running 850's.
Old Jan 17, 2012 | 05:50 PM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Hopping.
red35's Avatar
red35
i am running on 700's as well. I am making 505whp on a stock block. running around 13psi with water/meth.
Old Jan 17, 2012 | 05:53 PM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Nice! I never wanted to push my block pass 10psi.
Old Jan 17, 2012 | 08:35 PM
Blueknight74's Avatar
Blueknight74
Default Jwt530
I’m very interested in the outcome of your build,as i'm thinking of getting the 700 kit. I’m running the JWT530 kit 505hp/532tq @ 16psi.
http://www.facebook.com/photo.php?v=10150344133266452
Old Jan 17, 2012 | 10:17 PM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
I'm assuming you have a built block. If I remember correctly the 530BB kit turbos (GT24?) run out around 16psi. Still 505/532 is good power! :thumb up: I was tossed up on upgrading to the 850 kit but finances wouldn't allow me for the turbo and sleeve upgrade. Think once I'm done with this engine build I'll focus more on some good interior, audio/video and suspension/wheel upgrades. Here is my build thread; https://my350z.com/forum/texas/54165...ore-boost.html
EDIT: Nice dyno lines! I bet its a blast to drive!!!
Old Jan 18, 2012 | 05:55 AM
tonyzS/C03's Avatar
tonyzS/C03
I was in the begining stages of getting it tuned in kill mode at around 20+ psi but something happened with my motor so its in peices in my garage again and i'm waiting on parts to come back... then its game on, shooting for mid-6's on pump and 7 on race gas
Old Jan 18, 2012 | 03:45 PM
meatbag's Avatar
meatbag
600 might be possible on pump but it will be stretching it. The 850s will have to work a lot less to make 600 on pump gas then the 700bb kit.
Old Jan 20, 2012 | 05:45 AM
rcdash's Avatar
rcdash
With stock piping and IC, I don't think 600 whp is possible (DJ STD). 600 wtq is very possible. The turbos are just blowing hot air after 18 psi and the torque drops off too fast above 6k rpms. If you are building the motor you may want to consider a turbo refresh with new GTX compressor wheels as Garrett has finally released the billet versions for the GT28s.
Old Jan 20, 2012 | 04:32 PM
XKR's Avatar
XKR
I think I made 550+ whp on FP dyno....then did some upgrades and made more...
Hi Raj. Robert...thought you sold that car
Old Jan 20, 2012 | 05:22 PM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Nope I still have mine. Robert that has the silver Greddy TT is trying to sell his.
