My version of a 350Z single turbo kit
Old Jan 30, 2012 | 07:37 PM
MI 35th's Avatar
MI 35th
OGPremierMafia
I have fairly certain evidence it is almost impossible to break the 450 mark on stock headers.
Old Jan 30, 2012 | 07:47 PM
KingBaby's Avatar
KingBaby
Hardest Setting
Mind sharing 'certain' with us?
Link?
Old Jan 30, 2012 | 08:21 PM
MI 35th's Avatar
MI 35th
OGPremierMafia
Similar setup from BP, on a built motor at 14PSI after momentum headers. Plenty of room just needed more fuel.
Similar setup
TN setup, maxxed out on pump with stock manifolds.
Old Jan 30, 2012 | 08:36 PM
KingBaby's Avatar
KingBaby
Hardest Setting
Thanks for sharing!
Old Jan 30, 2012 | 08:44 PM
MI 35th's Avatar
MI 35th
OGPremierMafia
the turbo kit looks great but think about getting a set of headers on there and it'll make boost faster and pull better up top
Old Jan 30, 2012 | 11:53 PM
Phamspeed's Avatar
Phamspeed
We are testing limits of parts as we go. I'm sure stock exhaust manifolds are limited and we'll find out what it will actually do. I hope it's more than 450.
Old Jan 31, 2012 | 07:25 AM
MI 35th's Avatar
MI 35th
OGPremierMafia
Call Hal @ Dynosty, he has a lot of experience with the BP mid mount turbo kit, momentum kit, and tn as well. From what Ive been told on his dyno 450 seems to be the magic number on DE manifolds. Thats why during my build i went with a set of Momentum headers.
Old Jan 31, 2012 | 07:30 AM
Ruthless18x's Avatar
Ruthless18x
Definitely some quality welding there.
Old Jan 31, 2012 | 07:44 AM
abushong504's Avatar
abushong504
Yeah, stock headers seem to be a major choke point.
Anyways, awesome work so far man. Funny, I'm following your pics on instagram, you do some great work! Def sub'd for this. Good luck man!
Old Jan 31, 2012 | 08:39 AM
str8dum1's Avatar
str8dum1
^ot, but ashton where did your build thread go?
Old Jan 31, 2012 | 11:02 AM
Phamspeed's Avatar
Phamspeed
I worked on the Intercooler last night and it turned out to fit very well. The core is from ETS which are the only cores. They are quite heavier than regular cores and can make serious power. With 3.5" thick this fmic will handle 700hp no problem. On to some pics. As you can see, I made a whole new bumper support and the intercooler is part of it. I felt it would make things way easier in the future if I just made it as one piece. Plus it makes the intercooler super rigid. Bumper cover needs no cutting at all.
These next pics shows the inlet and how tucked up the pipe is after the bumper is on. Pipe does not hang lower than the bumper I'm starting to love my car all over again!!
Old Jan 31, 2012 | 12:10 PM
ITOzann's Avatar
ITOzann
MOAR!
Awesome thread
Old Jan 31, 2012 | 01:31 PM
abushong504
I am going to let Hal create the thread. He has taken many HQ pics through the process and can better explain everything that was done, etc. It should be coming up soon. Did run into one issue. The tranny that I had went out on me after tuning on pump. Engine was making great power. We had just bought the e85 to go in, then the tranny started making noises. Got a new CD009, dropped motor, put in tranny, engine going back in. I promise results will be here soon!
OP, keep up good work man! You're welding is amazing
Old Jan 31, 2012 | 04:28 PM
str8dum1's Avatar
str8dum1
nice integration with the intercooler. Id love to get my intercooler rebuilt on my car.
Old Jan 31, 2012 | 05:39 PM
dsm25psi's Avatar
dsm25psi
nice, ets is good stuff
Old Feb 1, 2012 | 07:08 AM
binder's Avatar
binder
Nice setup. Have any more pics of the turbo placement? it looks similar to the APS single area.
The only downfall i see so far is for people running a large return system. That cross over pipe is right where all the fuel lines run for a dual rail setup go. You can re-route the lines elsewhere but if you already have a setup that means you have to buy new custom lines which is expensive.
Old Feb 1, 2012 | 07:35 AM
thatv35guy's Avatar
thatv35guy
That’s not true… I made just over 450 whp with stock manifolds and Saad’s 350Z made 620+ whp with stock manifolds and a 1.06 35R PowerLab kit.
Old Feb 1, 2012 | 07:38 AM
  #38
Vivid Racing's Avatar
Vivid Racing
Vivid Racing
Looks great so far! Any idea when you'll be done?
Old Feb 1, 2012 | 07:50 AM
  #39
binder's Avatar
binder
on 93 octane pump?
Old Feb 1, 2012 | 07:53 AM
  #40
thatv35guy's Avatar
thatv35guy
Originally Posted by binder
on 93 octane pump?
I was on 91 octane, we stopped because my injectors were at 85% duty cycle and I don’t have a RFS.
The 620 whp run was on E85 BUT he made just over 520 whp on 91 octane gas.
