My version of a 350Z single turbo kit
Old Feb 9, 2012 | 06:34 AM
  #61
Boosted Performance's Avatar
Boosted Performance
Vendor - Former Vendor
oops DP.
Old Feb 9, 2012 | 06:35 AM
  #62
Boosted Performance
Originally Posted by Phamspeed
I see, some changes are possible.
A few ounces of oil gets discharged from the turbo after the engine is shut off. This happens over a period of a few minutes. On lower mounted turbos that oil can sit in the bearings and seals and can cause premature failure. A simple solution would be to leave the scavenge pump on for a few minutes after engine shut off. What I did was made a pan that holds this oil. It holds about twice the amount of oil I measured after engine shut off. This should keep the turbo nice and dry.
All of this is great (and an old quote of my), but you forgot to put the actual drain line at the bottom, so the above is void. If the outlet to the pump is at the top of the reservoir, it will always be full, and then you do not have the capacity like you say you do.
There is also a mechanical check valve that can be used. It closes the turbo supply line as soon as the engine is off, so that the turbo gets oil right away on the next startup. I am sure you have seen it in some of my threads.
Old Feb 9, 2012 | 11:05 AM
  #63
Phamspeed's Avatar
Phamspeed
You can clock the center housing a degree and the bung is at the bottom. That is how it is setup right now on my car. So far not a single puff of blue smoke. The car is super quite now with the turbo in. I can definitely feel this car becoming turbo. Hopefully I can finish all the fab this week. For fuel I have a set of 600cc injectors to go along with osiruis. I will more than likely use 255 pumps.
Old Feb 9, 2012 | 04:55 PM
  #64
ace32x's Avatar
ace32x
I have a deatschwerk 300 LPh pump I'd send you cheap if u want one to play with
Old Feb 9, 2012 | 09:06 PM
  #65
Phamspeed's Avatar
Phamspeed
I might have to take that from you. Where did you get your kit installed? Sounds like a nice setup.
Old Feb 10, 2012 | 08:23 AM
  #66
ace32x's Avatar
ace32x
Just let me know (: and intec racing in kent WA installed the kit
Old Feb 14, 2012 | 03:01 PM
  #67
Phamspeed's Avatar
Phamspeed
Here are some updated pics. The car is completely done and all we have to do now is tuning. I installed a 4lb spring in the wg just to get a little taste. With checking afr I was able to at least hit some boost. Car feels like stock and but starts to pull up top. BOV is super loud to BTW haha.
Old Feb 14, 2012 | 04:50 PM
  #68
Phamspeed's Avatar
Phamspeed
Got some titanium parts I am about to work in to the car. Just thought I'd show some pics
Old Feb 18, 2012 | 06:12 PM
  #69
Phamspeed's Avatar
Phamspeed
Here's a video of my first boost. Second gear with a 4lb spring
<iframe src="http://player.vimeo.com/video/36810055?title=0&amp;byline=0&amp;portrait=0" width="400" height="225" frameborder="0" webkitAllowFullScreen mozallowfullscreen allowFullScreen></iframe><p><a href="http://vimeo.com/36810055"></a> from <a href="http://vimeo.com/user6736033"></a> on <a href="http://vimeo.com">Vimeo</a>.</p>
Old Feb 19, 2012 | 12:25 AM
  #70
MI 35th's Avatar
MI 35th
OGPremierMafia
good job.
Old Feb 29, 2012 | 01:40 PM
  #71
Phamspeed's Avatar
Phamspeed
Worked late last night and came up with this header on the driver side. I used the same tubing here as I do on our 1000hp manifolds, schedule 40 304SS 1.5" which has a 1 5/8" ID. I tried to make the manifold as equal length as possible but there just isn't enough room with these runner size. I'm sure I can get it better next time, or at least the passenger side.
Old Feb 29, 2012 | 01:49 PM
  #72
Boosted Performance
Looks good, but the header will be at least 1/4" shorter after you weld it all solid. It is just crazy how heat shrinks metal. I would have left the 3-bolt flange as the last thing to be welded, because this is where you make sure it is a perfect/consistent fit on a jig.
Old Feb 29, 2012 | 06:35 PM
  #73
GreenGoblin's Avatar
GreenGoblin
Looking good
Old Mar 1, 2012 | 01:05 PM
  #74
Phamspeed's Avatar
Phamspeed
Good call, but we pre-shrink and heat treat our tubing before even welding Our tubing shrinks about 0.030"/ft with one weld on each end.
Got it all welded up, ready to do the passenger side.
Getting excited to get this all together to show some numbers. Waiting on a package from Injected Performance
Old Mar 1, 2012 | 01:16 PM
  #75
ace32x's Avatar
ace32x
some good looking manifolds
Old Mar 3, 2012 | 09:18 AM
  #76
binder's Avatar
binder
love those headers
Old Mar 3, 2012 | 02:33 PM
  #77
2004Black350z's Avatar
2004Black350z
Exhaust Whore
what size are headers? As in ID
Old Mar 3, 2012 | 03:42 PM
  #78
Resmarted's Avatar
Resmarted
those headers look incredible man.
Nice work.
Old Mar 3, 2012 | 09:10 PM
  #79
MI 35th's Avatar
MI 35th
OGPremierMafia
this is fantastic work i love it.
Old Mar 7, 2012 | 06:38 PM
  #80
Phamspeed's Avatar
Phamspeed
I came into work with this waiting for me Can't wait to install and get her tuned. As soon as I figure out my fueling, it's going over to Horsepower Freaks for the tune
