More turbo kit options (all new kit from BP)
Old Mar 5, 2013 | 02:12 PM
  #201
MI 35th's Avatar
MI 35th
OGPremierMafia
My routing is so non-standard on this exhaust, it's turbo back and is one piece. Ive Sold all my others. I may have to make a custom 3.5" down-pipe to my exhaust I have now.
Old Mar 5, 2013 | 03:05 PM
  #202
Resmarted's Avatar
Resmarted
Originally Posted by Boosted Performance
Just can't fit the 4". The 3.5" DP will be tight, but I think can be done. Plenty large to max out the flow of a 67mm turbo.
A 4" where your turbo dumps would be a pita. If anyone is wondering the bends are the problem really.
3.5" down pipe back purged is the way to go
Old Mar 5, 2013 | 03:38 PM
  #203
jerryd87's Avatar
jerryd87
is it the new kit that it wont fit sasha or all of them? was seriously considering moving to 4 inch downpipe with a vibrant 4 inch ID resonator and dumping out the passenger rocker panel by the gas tank since i dont have the stock tank anymore and all kinds of space right there i could cut through lol. havnt gotten down there to measure anything yet, not sure if i wanna go through the hassle of back purging to build it myself or not but dumping like that would for sure help out with a suspension idea i have for the rear..............and wheel tubs.
Old Mar 5, 2013 | 04:38 PM
  #204
MI 35th's Avatar
MI 35th
OGPremierMafia
Jerry, I am running a 4" DP and Exhaust on his original design.
Old Mar 5, 2013 | 04:59 PM
  #205
Boosted Performance's Avatar
Boosted Performance
Vendor - Former Vendor
With the mid mount kit, you can run whatever exhaust size will fit under the diff. IMO this is they way to go:
That is a dual 3" right off the turbo. It gives you fantastic flow, straight though flow design, and still gives you the option of having a good DD sounding car with resonators and mufflers.
This is the customer that made 610whp at R/T on a 6266 T4 .81 a/r with room to spare (goal was 600whp)
I am confident that I can make a 3.5" downpipe with the twin scroll, all the way to the OEM Y-pipe connection to the axle back. From there, you can go single 4" or dual 3". The dual 3" however has 10% more cross sectional area and should 10% more than a single 4" though....so that is something to keep in mind.
Old Mar 5, 2013 | 06:03 PM
  #206
MI 35th's Avatar
MI 35th
OGPremierMafia
The 10% does not factor into weight. I am down to 13 lbs total exhaust weight Without Ti.
Weight is my largest battle right now for a street car.
Old Mar 5, 2013 | 06:14 PM
  #207
Boosted Performance
True, but you can always go this route:
http://vibrantperformance.com/catalo...1021_1032_1258
Old Mar 5, 2013 | 07:53 PM
  #208
jerryd87's Avatar
jerryd87
yah thats pretty nice but think 4 inch should take care of my needs especially since i wouldnt even go to the pumpkin even
Old Mar 5, 2013 | 08:40 PM
  #209
MI 35th's Avatar
MI 35th
OGPremierMafia
This is true, but aluminum sounds like garbage and it isn't up to the beating I will put down.
Ill make any down pipe you make work with my 4" bud! Welders and Vband.
Old Mar 6, 2013 | 03:01 AM
  #210
bruthaboost's Avatar
bruthaboost
I can't tell from the pic, but is the turbine housing close to the prop shaft? Any long turn data if it is?
Old Mar 6, 2013 | 09:16 AM
  #211
Resmarted's Avatar
Resmarted
The cars I've heard with aluminum actually sounded pretty clean. Made some 4 bangers sound quite nice actually. There are videos of a turbo mr2 with an aluminum exhaust+vibrant race muffler. Sounds similar to what ive heard in person. In person most cars with an aluminum exhaust sound a bit tonally dulled down, imho would probably suit the vq35.
FWIW I've got a 3.5" backpurged dp that goes to a 4" aluminum pipe+vibrant race muffler.
Old Mar 6, 2013 | 10:06 AM
  #212
Boosted Performance
No issues at all...and there is a decent amount of room between the two. The compressor cover is close to the driveshaft, but that it not a big deal since it does not get all that hot.
Old Mar 6, 2013 | 10:56 AM
  #213
str8dum1's Avatar
str8dum1
how does aluminum pipes hold up to antilag?
Old Mar 6, 2013 | 11:46 AM
  #214
Resmarted's Avatar
Resmarted
Hard to say. I think if you have a steel dowpipe and then use a vband to convert to aluminum (as we did, with a flex pipe on either side of that vband) you should be "ok".
Probably would hold up like that if the flexpipes pre turbo can hold up to two step. But i do understand your point. We wanted to do the aluminum for weight, and to test just how strong it will be. The material cost for mine was like 15 bucks i think. If it does break ill just have another made.
Old Mar 6, 2013 | 12:39 PM
  #215
str8dum1's Avatar
str8dum1
aluminum exhaust is an easy place to save weight for sure. thats why I was interested.
Old Mar 6, 2013 | 01:02 PM
  #216
Boosted Performance
I thought about making an aluminium exhaust system for the VQ...but don't know if there is enough interest.
I have a good source for custom aluminium mufflers too, but he is not cheap.
Old Mar 6, 2013 | 01:10 PM
  #217
bmyles's Avatar
bmyles
We talkin Amuse prices or Motordyne prices? haha
Old Mar 6, 2013 | 02:42 PM
  #218
Scrildo's Avatar
Scrildo
Just curious to know if you woukd be willing to make and sell just the hotside of this kit from the header to the turbo with the wastegate flange and turbo flange and if you do whats the price on that.
Old Mar 6, 2013 | 04:31 PM
  #219
jerryd87's Avatar
jerryd87
Sasha your giving me too many ideas wife is gona kill me =p people been complaining how loud my car is though so mayby 4 inch downpipe splitting to dual 3 inch with race mufflers dumping from the rockers lol
Old Mar 6, 2013 | 05:54 PM
  #220
MI 35th's Avatar
MI 35th
OGPremierMafia
I may have a hotside available very soon, including a 6262 setup for a stock block up to 550 whp application on pump gas.
