HKS S/C Belt Tension
Old Mar 15, 2012 | 11:36 PM
pez1111's Avatar
pez1111
Default HKS S/C Belt Tension
Hey I just had both my cooling fan motors expire and in the process of changing out i had to remove the Blower belt for the HKS GT kit.
The fan motor replacement went ok but i'v just had made an educated guess on the belt tension as i dont have the proper tension tester.
Any tips on how much deflection on the lower/longest stretch of the belt.
One observation i have made is the belt significantle tightens with heat!@!
Thanks in advance.
'06 revup
Old Mar 16, 2012 | 07:17 AM
str8dum1's Avatar
str8dum1
1/4 turn when pressing on 1 finger is pretty tight, so somewhere around there
Old Mar 16, 2012 | 07:25 AM
Flo-ridaZ33's Avatar
Flo-ridaZ33
Sam@GTM told me "tight as ****"... That's what I did.
Old Mar 16, 2012 | 10:41 AM
str8dum1's Avatar
str8dum1
^good way to ruin your alt and power steering pump in no time
Old Mar 16, 2012 | 07:55 PM
Flo-ridaZ33
My bad... I thought he meant the supercharger belt.
Old Mar 18, 2012 | 05:01 PM
pez1111's Avatar
pez1111
Apologies for not elaborating, the belt i'm referring to is the blower/super charger drive belt. I havn't overtightened as i thought i may do bearing damage to the blower. Tight as sh*t , i havn't gone that far, i can move it about 1/4 inch with one finger. Can you explain why Sam said "as tight as"
I didn't touch the belt driving the alternator power steering pump.
Thanks again.
Old Mar 18, 2012 | 07:47 PM
Flo-ridaZ33
Thanks again.
Mine doesn't move at all.
Old Mar 19, 2012 | 06:23 AM
4SHIZZIL's Avatar
4SHIZZIL
Belt issues are a known SC issue.
Better gripping pullies means less "tight az shizzil" requirements.
good luck... im still searching for the best set up, but im running Vortech.
I go with the half inch finger pull, push test also, but this is the BELT COLD setting.
once its warm it will be pretty tight.
Old Mar 19, 2012 | 11:17 PM
pez1111's Avatar
pez1111
Thanks guys i'm gonna go with a bit of movement when cold ( about 1/4 inch ) as the belt gets tighter as it heats up.
lapham3
Oct 7, 2022 03:15 PM
Fixxxercask
Nov 9, 2015 11:10 AM
