View Poll Results: Which kit?
Vortech
80.00%
ProCharger
20.00%
Voters: 10. You may not vote on this poll
Which kit ??
Old Mar 20, 2012 | 12:22 PM
ehsan's Avatar
ehsan
Default Which kit ??
Ive done most of the research and have narrowed it down to two kits....
Opinions and reason why i should choose one or the other in this scenario.
As of now i am leaning torwards to procharger.
Some info:
04 base, exhaust, intake, plenum spacer, i believe 1 or 2 degree colder plugs(will double check), test pipes, will purchase a walbro as well.
Stock block. Looking to make somewhere around 390-400 hp.
I already have a license for Osiris on my Ecu. Will probably get a tune after installation.
1.Like it because its vortech, dont like because gold colored bracket, oil spacer needs to be tapped. i will probably end up buying a pretapped spacer,
$3100 firm plus shipping
Vortech Supercharger w/ 8psi pulley
* Comes w/ GTM pulley mod
* Gold powdercoated bracket
* Polished blower & intercooler
* Cerami-chrome powdercoated upper intake pipes
* T-bolt clamps
* RC 440cc injectors (probably would need a better fuel pump and ECU to use)
* OEM injector wire harness w/ RC pigtail clips soldered in
* FMU and inline fuel pump from Vortech (bought from another member)
* Split Second Box (bought from another member)
* Speedhut Temp Gauge, Oil pressure gauge, boost gauge, 3 gauge pod (bought from another member)
* Oil pressure/temp sensor adapter
* Oil Pan spacer(needs to be tapped)
2. Like it because of all the extras it comes with, dislike color ..will def be changed, a complete kit is what i like...
Polished C2 blower, bracket and intercooler
-GReddy Type S BOV
-Pulley @ 7 psi
-Piping is painted custom House of Kolors purple
-18,000 easy miles - this was a show car, not a race car.
-Extra belt
-Extra ProCharger oil
-ProCharger syphon for doing oil changes
-6ea. 550cc RC injectors
-6ea. 750cc RC injectors
-ProCharger FMU
-K&N air filter
-All required hardware needed for installation; hose clamps, spacers, nuts,bolt, ect.
-3 gauge a-pillar pod
-DEFI boost gauge
-DEFI fuel pressure gauge
-DEFI link box controller
-AEM wideband O2 sensor
-Any other misc parts I have laying around...
If you want everything listed above I will do it for $3500
Old Mar 20, 2012 | 01:46 PM
ace32x's Avatar
ace32x
depends what you want out of the car. you have a little more room to grow with the vortech.
Old Mar 20, 2012 | 01:51 PM
ehsan's Avatar
ehsan
ah, ok.
I know i will be changing out the pulley to accomplish the 390 to 400.
as far as "growing" are you talking about the blower? or other parts
Old Mar 20, 2012 | 02:02 PM
Ruthless18x's Avatar
Ruthless18x
I'm not a fan of prochargers, go Vortech.
Old Mar 20, 2012 | 02:03 PM
Flo-ridaZ33's Avatar
Flo-ridaZ33
Vortech
Old Mar 20, 2012 | 03:00 PM
nismonian's Avatar
nismonian
Vortech br0.
Old Mar 20, 2012 | 03:07 PM
konrad's Avatar
konrad
Why not used turbo? Less stress on the engine , might need a custom Y if u got dual exhaust , but in the end it gives a bigger kick and much more fun
Old Mar 20, 2012 | 03:29 PM
PRuane's Avatar
PRuane
Still more expensive.
Old Mar 20, 2012 | 04:00 PM
str8dum1's Avatar
str8dum1
prochargers just break expensive belts. thats a deal breaker right there, no pun intended
why not just wait until there's a V3 vortech for sale. then you dont have to tap anything. Tax time is when people swap stuff out.
If the gold bracket isnt what you want, then wait 2 weeks and what you want will probably come up for sale.
Old Mar 20, 2012 | 06:10 PM
ebadai98's Avatar
ebadai98
vortech, but i would look into turbos instead
Old Mar 20, 2012 | 06:39 PM
ehsan's Avatar
ehsan
Well superchargers are much easier to install. Safe if setup correctly ..as this is a daily as well. Just like I thought everyone is saying vortech. The only reason I liked the procharger was because of the extras and nicer guages.
Str8 the gold bracket isn't something that will break a deal. That can be powder coated easily.. I thought the v2 was better because of it being lubricated with the oil that's already there? Also I'm sure it's gonna cost more significantly ?
Old Mar 20, 2012 | 08:45 PM
konrad's Avatar
konrad
nothing is easier to install than the BP single turbo kit ,
Old Mar 20, 2012 | 09:23 PM
Shizzmaster2k's Avatar
Shizzmaster2k
Vortech.
Old Mar 21, 2012 | 09:28 AM
Z33Garage's Avatar
Z33Garage
I have done some searching and the majority of people seem to have iffy experience with procharger. Like some of the dudes have been posting ^.
I would venture my opinion and go with Vortech. I also have helped some of my friends install these in their shop in Miami, and it can be done at home if you have enough basic tools, which I would imagine most people on this forum have. Especially since there are pic by pic instructions on the installation.
GL
EnjukuRacing
Sep 30, 2015 06:55 AM
