Boost Gauge help? Not reading boost
Old Apr 1, 2012 | 05:56 AM
Phil Klepka's Avatar
Phil Klepka
Default Boost Gauge help? Not reading boost
The gauge I have currently reads vacuum only. I have a vacuum line coming off of the plenum and no boost is read. However, when I put an air hose from a compressor to that vacuum line, it reads that air. What could be the problem? I'm currently on a vortech SC kit.
Thanks
Phil
Old Apr 1, 2012 | 03:30 PM
jerryd87's Avatar
jerryd87
which guage do you have? it shows the engine pulling a vacuum? if thats the case i would say you have a leak somewhere so the guage isnt reading what never makes it there.
Old Apr 11, 2012 | 07:55 AM
Phil Klepka
Its a glowshift gauge... just something cheap I got for free. It doesn't leak though, as I use the same line from the bay with the air compressor.
Old Apr 11, 2012 | 07:59 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
Are you revving in your garage or testing it
O the street.
Vortech bpv bleeds boost until you get into heavy throttle.
Digital gauge? May be lagging some.
Old Apr 11, 2012 | 08:07 AM
Phil Klepka
O the street.
Ive always been under the impression that you don't make boost until your under a load, so I've driven it on the street. Its a digital gauge, but it never reads boost. 2k, 4k, 6k, nothing.
Old Apr 11, 2012 | 08:10 AM
djamps's Avatar
djamps
Maybe you're not making any boost.
Old Apr 11, 2012 | 08:42 AM
OMERTAITALIA's Avatar
OMERTAITALIA
what he said^^^, or if your driving around boosting and your gauge isn't showing boost its probably cuz you bought a cheap boost gauge.
Old Apr 11, 2012 | 09:09 AM
Phil Klepka
What would cause me to not make boost with the SC though confused.
Old Apr 11, 2012 | 09:22 AM
djamps's Avatar
djamps
If you make 414whp like in your sig then you should def. know if you're making boost or not. Are you saying it still pulls like it always has?
Old Apr 11, 2012 | 09:45 AM
Junkster's Avatar
Junkster
^THIS
or maybe the line is getting pinched somewhere under throttle?? far fetched idea but its something easy to check...
Old Apr 11, 2012 | 09:51 AM
phunk's Avatar
phunk
CJ Motorsports
the only vacuum check valve in the car that i can think of is inserted into the brake boost vacuum line that connects from the passenger side of the plenum to the pipe on the side of the firewall... so unless your boost gauge is T'd off the brake booster line... its too hard to say from here, unless you just arent making boost. Are you positive that the car is supercharged?
Old Apr 12, 2012 | 05:40 AM
Phil Klepka
Pretty positive but yes, it still pulls like before. Dunno what the problem is? Maybe I'll have to take it over to tach motor works when I get my AF and have them hook it up as well.
apex locator
Jul 23, 2021 02:27 AM
codek
Sep 28, 2015 03:03 AM
Tochigi_236
Sep 27, 2015 03:40 PM
