help with tuning PLEASE HELP!!!
Old Jan 3, 2004 | 04:10 PM
AgentOrange's Avatar
AgentOrange
Default help with tuning PLEASE HELP!!!
CAN SOMEONE TELL ME WHAT I WANT MY AIR/FUEL MIXTURE TO BE AT ABOUT 10PSI SO I DONT BLOW UP........
Old Jan 3, 2004 | 05:31 PM
swinke's Avatar
swinke
Default Re: help with tuning PLEASE HELP!!!
Its not that simple, you need to stay under 12.5:1@WOT for sure but if you dont correct the timing properly you will still get detonation. Either way you'll damage the engine.
Old Jan 3, 2004 | 05:40 PM
AgentOrange
ok SO I THINK I FINALLY HAVE THE ANSWERS I WANT..........you mean if i stay under 12.5:1 @WOT a/f AND i use that map you gave me for 8+psi........i should run fine with 5.6psi and 9-10psi?
Old Jan 3, 2004 | 06:57 PM
MY350Z.COM's Avatar
AgentOrange, please post in the correct forum, this is getting annoying to move all your posts.
Old Jan 3, 2004 | 07:03 PM
jesseenglish's Avatar
jesseenglish
AgentOrange, If I were you I'd stay around 11.5:1, and you can't use someone elses maps for 8 PSI if you value the life of your engine. You need to get your FI tuned for your car. There are just too many possibilities of differences. Especially if you're planning on running it at 8-10PSI.
Old Jan 3, 2004 | 08:21 PM
rouxeny's Avatar
rouxeny
This is like watching a car stuck on the railroad track. You have a good idea of what's going to happen, and you know it's going to be loud.
Like I said in my other post, education before detonation!
Old Jan 4, 2004 | 12:32 AM
phunk's Avatar
phunk
CJ Motorsports
your frekaing me out man. Do yourself a huge favor, do NOT turn up your boost just yet. Let the pros do some R&D with that kit before you do your own... with time we can show you how to do it, without you showing us how not to.
Old Jan 4, 2004 | 02:24 AM
kudos's Avatar
kudos
Old Jan 4, 2004 | 03:18 AM
swinke's Avatar
swinke
Originally posted by kudos
The only problem I see so far here is he may blow the heads off the car before we and he get any real useful data from his project.
Old Jan 4, 2004 | 06:49 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
Agent orange...you really ar ethe perfect candidate for having someone tune this for you. using someone else's map is a BAD idea. First, they don't have your car...only you have your car. Second, you don';t know if their E Manage is even set up correctly..all you know id that its set up. As you can clearly see from readings post on reflashed ecu's, what works on one car does not always work on another, and can prove disastrous. if you ahve this kind of moeny invested in your car, you would be well served to have someone intimately familiar with E Manage tuning to do this for you, at least from the outset.
Also, you mention A/F ratio...well, using what instrumentation? Here is the probe mounted? Have you datalogged your car eyt to even know where or if it needs adjusting? This is all the type of things you NEED to know before proceding to turn your boost up, especially on a ca that was never desinged for forced induction to begin with.
Adam
2ndchanceZ
Oct 26, 2015 08:03 PM
nanotech
Oct 2, 2015 05:02 AM
KOF
Tuning
Sep 30, 2015 04:09 AM
