Is this normal for a vented catch can system? Please see video...
Old May 13, 2012 | 08:44 PM
350Z400rwhp's Avatar
350Z400rwhp
Default Is this normal for a vented catch can system? Please see video...
I was running this line back into my intake manifold. I decided to vent to the atmosphere instead and put a filter on the end of the hose. I have both the driver's side and passenger's side valve covers tee-ed together before it goes into the catch can and then out the small air filter in the video. I capped off the intake manifold and kept the catch can system separate. I am also getting "oil mist" around the area of this air filter and some drops of oil on my garage floor after parking the car. I have since ran this into another catch can to collect the oil but I may be considering just running this line into my downpipe so all of this just goes out my exhaust. My main question is the fumes and oil smell is pretty bad at stoplights (smoke coming out the cracks of my hood and my a/c blowing the smoke through my vents as it sucks this air into the cabin) and such the way it is in the vid, is that normal or does my smoking seem excessive? Thanks in advance.
Vid: http://www.youtube.com/watch?v=S1QSZ...1&feature=plcp
Old May 14, 2012 | 05:21 AM
VQpwr03z's Avatar
VQpwr03z
that does not look good at all, thats exactly what happened to alex gallardo at road atlanta when i was with him. im still a newbie so the only advice i can give you is to ask him for some help.
Old May 14, 2012 | 08:05 AM
str8dum1's Avatar
str8dum1
yes, open filters will smoke a good bit.
the smell drawn into the car is why people tie the catch can into a vac source
djamps's Avatar
djamps
I'm not exactly sure what you should expect... but I've never seen a vented can smoking that much.
Old May 14, 2012 | 08:13 AM
Vivid Racing's Avatar
Vivid Racing
Vivid Racing
Doesn't look that bad to me.
Old May 14, 2012 | 09:24 AM
MUZZY's Avatar
MUZZY
that is bad, also the way you described the hook up, you definetly do not know how the valve coveres breath. You should not vent the can, the can should be to manifold vac.
sequence
Air inlet > driver side cover > pass cover > catch can > manifold
Old May 14, 2012 | 09:34 AM
binder's Avatar
binder
sequence
seriously?
don't listen to this. running open breathers vents just fine and used extensively on race cars with no issues. The only reason for a recirc system on cars is to eliminate the smell.
Old May 14, 2012 | 10:29 AM
MUZZY's Avatar
MUZZY
Originally Posted by binder
seriously?
u do know this is a boosted setup and he is venting the calves in parallel and not series.....
say what you want. Do what I said above, thank me later.
Old May 14, 2012 | 11:00 AM
binder's Avatar
binder
You can run all the vent lines to a single catch can then run that open breather without issues. It does not have to be hooked up to a vac source. Quite a few people run them without any vac source. Vac source is gone under boost anyways so it only helps during vac (cruise) to remove the gases and smell.
Old May 14, 2012 | 11:07 AM
jpc350's Avatar
jpc350
Why in the world would you ever allow oil vapors and oil smell into the car settling on your engine and needless to say oil drops on your garage floor when there is a simple fix to avoid it all?
Old May 14, 2012 | 09:24 PM
350Z400rwhp
sequence
I had this setup but I was blowing boost into my catch can system and who knows but I was getting oil spraying out of this filter. I was considering a one way catch valve right off the manifold to only allow vacuum and close off under boost. I then decided to just cap off the manifold and keep things separate. After seeing the vapor and oil, I would rather not run that back into my motor anyway. I see the best option as just having a bung welded on my downpipe and run this all out my exhaust, problem solved. Thanks for all of the advice guys. The one thing I have learned over the years on this topic is there are many ways to do this and everyone will have their reason as to why one way may be better than another, the venting to the downpipe will be my method.
Old May 15, 2012 | 02:23 AM
suprasam's Avatar
suprasam
^^^ I did that! Works great!!
Old May 16, 2012 | 07:42 AM
djamps's Avatar
djamps
^ +1 if/when I need venting I'll definitely be running it to the exhaust. I have bad enough allergies/asthma as it is and is the main reason I still run cats.
Old May 18, 2012 | 02:20 PM
binder's Avatar
binder
i would vent to my exhaust if it wasn't such a long way back to the post turbo exhaust. Too long for me to mess with running a hose. It would have to be 3/4" to keep resistance down as well due to the long length.
open breather keeps my crank pressure down and that's all i care about at this point.
sales@czp
Sep 23, 2019 03:30 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
