walbro mod needed?
Old Jul 3, 2012 | 03:25 AM
evilscorp's Avatar
evilscorp
Default walbro mod needed?
Just about to start installing my new fuel pump and aam basic fuel return system, Do I need to do the fuel pump hanger mods if I have the aam basic? I know the pressure will be higher in the lines but will I be able to lower it using the frs? Reason im asking is im doing my vortech install in stages, i wont be installing my dw 600cc until i get the vortech so I dont have to do multi trips to my tuner.
Old Jul 3, 2012 | 03:48 AM
evilscorp's Avatar
evilscorp
had a look about and seems you need to do the mods no matter what. Does the ecu take the fuel presure reading/sensor before the FRS?
Old Jul 3, 2012 | 06:10 AM
binder's Avatar
binder
if you have an AAM fuel system i would install it just like the instructions say. I'm not familiar with them but each system is designed to work in its own way.
Old Jul 3, 2012 | 06:57 AM
str8dum1's Avatar
str8dum1
the stock ecu has no way of knowing what the fuel pressure is. thats why you have a aftermarket regulator so you can set it to 50psi, like stock.
Old Jul 3, 2012 | 08:56 AM
evilscorp's Avatar
evilscorp
Yes I understand that but to fit the walbro (which I have no instructions for)
you need to increase the diameter of some pipes and do a few other things to the carrier to reduce the pressure (I presume) but why does this need to be done if I have a AAM FRS?
Old Jul 3, 2012 | 10:24 AM
str8dum1's Avatar
str8dum1
because the stock basket has a FPR in it already. You cant use both.
And the AAM FPR does nothing to control the pressure inside the basket which is why you need to drill out the yellow venturi.
Old Jul 3, 2012 | 05:27 PM
StaceyAnthon's Avatar
StaceyAnthon
Old Jul 3, 2012 | 09:08 PM
evilscorp's Avatar
evilscorp
Thank you, I understand now why it needs to be done.
Dsowe
Feb 17, 2021 10:38 AM
dcains
Nov 11, 2015 11:36 PM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
codek
Sep 28, 2015 03:03 AM
