VQ35HR Maf limit
Old Jul 23, 2012 | 08:14 PM
C-unit's Avatar
C-unit
Default VQ35HR Maf limit
I ended up going with the uprev tuner for my twin turbo set up. Anyhow, I would let some suggestion on what I should do with my MAF sensor.
I am running stock VQ35HR, Twin GT2860RS @5-7psi. 550cc injectors. I am just wondering do I need to upgrade my MAF at 350-400whp? I've seen some people with that power without getting the GT MAF. I just want to confirm.
Also the placement of the MAF. Do I need to put it at the cold pipe or the intake? There is no twin turbo HR locally so I just want some advice. Thanks guys!
Old Jul 23, 2012 | 09:01 PM
thisishk350's Avatar
thisishk350
You do not NEED to upgrade them, its the single maf DE setups that top out around 400. I've heard that the uprev mafs have better resolution than oem tho so it would be a smoother tune.
As for placement look at some pictures of GTM TT installs. You want them after the intercooler but before the throttle body.
Old Jul 24, 2012 | 07:21 AM
djamps's Avatar
djamps
HR tops out at 700whp or more because there's 2 MAF's each sharing half the flow. No need to upgrade MAF on any stock block setup.
Old Jul 24, 2012 | 08:11 AM
Duckeee's Avatar
Duckeee
welcome to the crib c unit. havent read your thread on zilvia for a while.
just to clarify for some his HR set up is going into an R32 if you missed his sig.
Old Jul 24, 2012 | 08:38 AM
C-unit's Avatar
C-unit
^ haha..well, you should! lol. Car is almost done and I am just trying to figure out the last pcs of the puzzle.
Old Jul 24, 2012 | 09:28 AM
Duckeee's Avatar
Duckeee
i will check the thread on in a bit. that looks amazing dude.
like ready for formula d amazing. not sure what part of canada you're in but if you're close to Seattle please come for our events.
Old Jul 24, 2012 | 09:31 AM
C-unit's Avatar
C-unit
I am in Vancouver BC!! I'll definitely come when my car is ready!
Old Jul 24, 2012 | 09:35 AM
ace32x's Avatar
ace32x
I made 670 whp 699 tq on the stock mafs and they didn't show any signs of being near the voltage max so you will be fine.
ace32x's Avatar
ace32x
Planning on tuning on c16 here shortly aswell so ill let you know where they max out at
Old Jul 24, 2012 | 10:17 AM
Duckeee's Avatar
Duckeee
hope to see you around then!
and ace, saw your setup again at FD. looks great man im envious. HR n/a is not cutting it for me any longer..
Old Jul 24, 2012 | 10:19 AM
ace32x's Avatar
ace32x
haha Ty man . And I hear ya it wasn't for me ether. F150 is parting his stage 2 gtm kit out you should talk to him. Those turbos are perfect for a stock block set up. 2860rs 's
Old Jul 24, 2012 | 10:59 AM
C-unit's Avatar
C-unit
thanks for the input.
One for question,my cold pipe is 2.5" instead of the regular 3". I just want to make sure it's ok to space out the MAF.
Old Jul 24, 2012 | 11:17 AM
str8dum1's Avatar
str8dum1
as long as you are tuning for the difference in tube diameter and the MAF wire in the airflow, it doesnt matter
Old Jul 24, 2012 | 11:31 AM
ace32x's Avatar
ace32x
The smaller diameter will increase the flow rate and raise the voltage of the maf won't it? Meaning it may max out a little sooner? I don't think in your case it would make a difference though
Old Jul 24, 2012 | 11:34 AM
C-unit's Avatar
C-unit
Good to know because the MAF is actually longer than 2.5" so i will have to spacer it out quite a bit.
Old Jul 24, 2012 | 11:51 AM
ace32x's Avatar
ace32x
why not just make it 3"?
Old Jul 24, 2012 | 12:25 PM
str8dum1's Avatar
str8dum1
^thats how most CAI companies do it, expand/reduce the size of the pipe around the MAF to match stock diameter so that the scaling doesnt change.
you can just use stepped silicone couplers.
liqalu04
Jan 2, 2022 12:58 PM
350Z_Al
Oct 29, 2020 07:44 PM
