View Poll Results: Greddy Install, pull engine or not
Pull Engine
44
95.65%
Leave In
4.35%
Voters: 46. You may not vote on this poll
Greddy Install...engine in or out?
Old Sep 13, 2012 | 12:53 PM
Escobar's Avatar
Escobar
Originally Posted by Dave 90TT
To give some idea, I am making 391 rwhp at 9 psi, on a pretty conservative tune. 400 rwhp is possible at 9psi, but definitely not at 5.5 psi.
interesting, thanks for the info I'll run the small blue springs then, they are 8.7 psi. I dont want to run a boost controller because I will just end up turning it up and blowing something up haha.
Old Sep 13, 2012 | 01:19 PM
Dave 90TT's Avatar
Dave 90TT
350Z 2+2
Originally Posted by supraturboman
Do you have the greddy tt kit? If so any videos?
JWT, and sorry, no videos.
Old Sep 13, 2012 | 01:21 PM
Dave 90TT's Avatar
Dave 90TT
350Z 2+2
You probably already have this planned, but I HIGHLY recommend a tune with an advanced engine controller if you are going to run anything above 5 PSI.
Old Sep 13, 2012 | 01:56 PM
Escobar's Avatar
Escobar
yea I would like to run the new haltech plug and play system but I dont have 2500 for it. I have talked to a local shop(sohomotorsports) here in charlotte and they said they would do the uprev reflash and upgrade the MAF for around 1000 with dyno time. They are running this tune on their 550whp track G35 with no issues.
Old Sep 13, 2012 | 02:02 PM
supraturboman's Avatar
supraturboman
Uprev will bw perfectly fine on your set-up.
Old Sep 13, 2012 | 02:19 PM
Escobar's Avatar
Escobar
sweet. thanks
Old Sep 13, 2012 | 08:29 PM
Resmarted's Avatar
Resmarted
I would buy an older haltech if I were you.
Even on low boost I shudder at the thought of maf on turbo applications. Although plenty of cars (gtr etc) run maf, map is just a better place to start. Ontop of that something like the haltech is really designed for boosted applications. Considering you're staying stock block, you should really want every safeguard you can get. AEM, hydra, motec, etc all are expensive for good reason. But an old red box shouldn't be hard to find for a little more than the 1k they want for your uprev. Mind you, you'll have to fork out for tuning, but you'll have a much better ecu system to build off of.
And on regards to pulling the engine, if I could, I would have dropped the sub-frame with the engine, slapped my crap on, and dropped the car back on that bish. My install wasn't the same as everyone else's, but that's the easiest way by far. Pulling out sucked at home but there's no way you can install a turbo kit without pulling that lump out. In car installation would be a mental suicide. Awful.
Old Sep 14, 2012 | 05:33 AM
Escobar's Avatar
Escobar
Yea I talked to Hal and really want to go with a Haltech but the price was just so high. He warned me about the uprev and if a wastegate line breaks I would have uncontrollable boost and instantly blow my engine(not good) but the haltech can prevent that. I also agree with tuning off map not the maf, that is a much better way of doing it. Thats what I want to do but im just trying to keep my costs down so I can get this thing running. The $1000 they quoted me for uprev was including a upgraded maf and dyno time. I'll keep my eyes open for a haltech still, Im far from being done, still need tons of stuff. Thanks for the input guys
Old Sep 14, 2012 | 09:09 AM
ace32x's Avatar
ace32x
I have a haltech I'm selling cheap if your interested. I uave a for sale thread up in the engine privates. I would let it go for 1250 haltech platinum unit.
Old Sep 14, 2012 | 12:32 PM
Escobar's Avatar
Escobar
yea I saw that. Not a bad price. Not ready to buy yet but I'll let you know. ECU will be last.
Old Sep 14, 2012 | 01:17 PM
ace32x's Avatar
ace32x
keep me in the loop, trying to blow it out before sema, i want some table money for when i go down XD
Old Sep 17, 2012 | 01:03 AM
accordfreak's Avatar
accordfreak
I installed mine on jack stands with the engine in. took about 3 weeks. couple hours a day. i don't want to touch it ever again.
i've been running the stock clutch for about 10k now on 8psi 369whp.
Old Sep 17, 2012 | 10:00 AM
Escobar's Avatar
Escobar
cool deal, thanks for the info. Hows it holding up?
Old Sep 17, 2012 | 02:44 PM
accordfreak
so far so good.
no slip on the clutch so far.
solid tune on the haltech.
drives/idles/cruises like stock but with more power
I had an oil analysis after 5k miles and it came out normal.
Old Sep 17, 2012 | 03:20 PM
Escobar's Avatar
Escobar
sweet, i think i'll use the money for the clutch toward my haltech then
Old Sep 17, 2012 | 03:54 PM
Sylvan Lake V35's Avatar
Sylvan Lake V35
If you're pulling the engine to do it I would do the clutch while everything is out. It's enough of a PITA that it is a good time to do it and it won't be if but when you need a new clutch. Lots of people run 400+whp with a reflash. If I did it again I would use up-rev until I decided to build my engine.
Old Sep 17, 2012 | 04:10 PM
Eno's Avatar
Eno
Hmmmmmmmm. Interesting!
Old Sep 17, 2012 | 04:41 PM
  #38
Escobar's Avatar
Escobar
that is very interesting, can you elaborate sylvan. Good point about the clutch, it certainly wont last forever.
Old Sep 18, 2012 | 05:59 AM
  #39
str8dum1's Avatar
str8dum1
on a stock block you cant run a boost controller, just ~8-10psi wastegate springs, so Uprev is all the tuning you need.
The additional features and controls for a Haltech etc are just overkill. On a built block, you need the additional safeties, so a better EMS is needed.
Old Sep 18, 2012 | 09:24 AM
  #40
Sylvan Lake V35
^^ Rich covered it for me, I feel the same way.
