View Poll Results: Greddy Install, pull engine or not
Pull Engine
44
95.65%
Leave In
4.35%
Voters: 46. You may not vote on this poll
Greddy Install...engine in or out?
Old Feb 2, 2015 | 01:12 PM
  #141
Escobar's Avatar
Escobar
can anyone help me out with where this plug goes? It comes off the horns. I cant find anything close. also, those of you who deleted the washer tank, did you just ziptie up all those connections or what? will I have a light on the dash now telling me the water is low all the time?
Old Feb 2, 2015 | 03:25 PM
  #142
Cux350z's Avatar
Cux350z
hatersgonnahate
most likely your ac condenser pressure sensor. Its a ***** to plug in after everything is back in place. I did the same thing.
Old Feb 2, 2015 | 05:20 PM
  #143
bealljk's Avatar
bealljk
yeah...if its not AC, it could be power steering or oil pressure, possibly crank position sensor if you have some length on it...
Old Feb 2, 2015 | 05:40 PM
  #144
Escobar's Avatar
Escobar
thanks guys! Cux, do I need to take off the fans and radiator to get to it?
Old Feb 2, 2015 | 06:09 PM
  #145
Cux350z's Avatar
Cux350z
hatersgonnahate
its on the passenger side between the front core support and ac condenser
See the cylinder on the right...thats it.
Old Feb 3, 2015 | 04:52 AM
  #146
Escobar's Avatar
Escobar
Got ya...thanks alot man. I think if I take the intercooler off I should be able to get to it.
Old Feb 3, 2015 | 09:39 AM
  #147
Cux350z's Avatar
Cux350z
hatersgonnahate
hope you got little asian hands. Its a pita to hold the plug, get mauled by the condenser fins and plug it it.
Old Feb 3, 2015 | 11:31 AM
  #148
str8dum1's Avatar
str8dum1
the wiper fluid light is off by default, so removing the tank keeps it off.
Old Feb 3, 2015 | 01:35 PM
  #149
Escobar's Avatar
Escobar
sweet. thanks
Old Feb 3, 2015 | 01:36 PM
  #150
Escobar's Avatar
Escobar
haha, I found that out! I'll get my girlfriend to do it. I had her put the plug on top of the rear transmission on last night too. She has little ninja hands
Old Feb 4, 2015 | 02:58 AM
  #151
Resmarted's Avatar
Resmarted
Pics?
Talking bout said gf... nuder the better
Old Feb 4, 2015 | 06:25 AM
  #152
Escobar's Avatar
Escobar
lol
Old Feb 4, 2015 | 09:17 AM
  #153
Cux350z's Avatar
Cux350z
hatersgonnahate
so does her freakishly small hands make anything look big?
Old Feb 14, 2015 | 02:36 PM
  #154
Escobar's Avatar
Escobar
so back on track lol. FINALLY got my wastegate relocation pipes to fit. Had to re weld them 3 F'n times to make it work. What a nightmare. Also got my gauge pod (thanks CUX) and wires ran....turned the key a few times and fuel pressure shot up to 40 psi and has been holding for a few hours...no fuel leaks!
Attached Thumbnails Greddy Install...engine in or out?-img_4992.jpg   Greddy Install...engine in or out?-img_4989.jpg   Greddy Install...engine in or out?-img_4987.jpg   Greddy Install...engine in or out?-img_4984.jpg
Old Feb 14, 2015 | 02:47 PM
  #155
Escobar's Avatar
Escobar
question, with open wastegate dumps, as the spring is compressed with boost, it will crack and start to dump exhaust out of the dump. If I install a boost controller, it will keep the wastegate closed until it reaches the set psi and then will open and dump 100%? Is this correct? I elected not to get a boost controller because I dont want or need to increase boost, but if the above is true, I think I will need one to make the turbos spool faster. What do you think??
Old Feb 14, 2015 | 02:54 PM
  #156
Conway_160's Avatar
Conway_160
You should get a boost controller it will be more accurate then just a spring; Also you can run less or more boost than just the springs.
Old Feb 14, 2015 | 04:02 PM
  #157
Escobar's Avatar
Escobar
yea, im thinking something real basic, since im not going to be changing it. Im thinking the hallman mbc.
Old Feb 15, 2015 | 04:34 AM
  #158
str8dum1's Avatar
str8dum1
manual BC is just a spring with a tiny ball as well. The only way to hold the gate shut is to use a solenoid with a programmable duty cycle table.
Old Feb 15, 2015 | 04:50 AM
  #159
Escobar's Avatar
Escobar
so the hallman wouldnt really do much for me then? The only way would be to get a EBC?
Old Feb 17, 2015 | 12:51 PM
  #160
str8dum1's Avatar
str8dum1
its no different than the wastegate spring. it just let you run more boost. it doesnt control teh gate below the spring pressure.
you have to get an EBC
