vortech Z-G really upset about dyno results/ anyone have any opinions
Old Sep 14, 2012 | 01:42 PM
drifter23's Avatar
drifter23
Originally Posted by Calinismo350z
nice results, yeah that's the same thing I say I should be making easy 400whp. where is that located?
Rob at ZCG is located in San Jose, CA. his address is listed below. And a link to his website is listed below as well.
ZCARGARAGE:
140 Archer Street
San Jose, CA 95112
(408) 452-0350
ZCG Website:
http://www.zcargarage.com/
Old Sep 14, 2012 | 02:01 PM
ColombianoG35's Avatar
ColombianoG35
OP. where are you located?
Old Sep 14, 2012 | 02:24 PM
Calinismo350z's Avatar
Calinismo350z
Originally Posted by djamps
Seems like a boost leak.. the tuner would have had to pull a metric crap ton of timing to get results that much lower than usual.
well actually took 8 hours to get it tune. I wasn't quit comftable the way he tune to me it seems like he could of got more out of it.
Old Sep 14, 2012 | 02:53 PM
Calinismo350z
I'm locat in palms springs CA. about 2 hours away from LA
Old Sep 14, 2012 | 06:52 PM
binder's Avatar
binder
Every engine is different. That's just below 100hp increase on that car depending the condition of your motor. I'm going to guess being a 2005 it probably has higher mileage than most. On top of that if you have belt slip then the boost would be lower. For 7psi in that heat and humidity your HP number is spot on with 91 octane fuel. Normally it should be around 9psi so with a 2 psi bump you should be mid/upper 300's. Could be a belt slip or a leak somewhere. Also, make sure he is revving the engine out. You make max boost at max rpm and that is also where max HP is. If he is stopping at say 6300 instead of 6600 then it will lower the boost and peak numbers considerably.
Post a dyno sheet so we can see what is going on.
Old Sep 14, 2012 | 10:37 PM
- bigc -'s Avatar
- bigc -
you're not that far from GTM. you really do want to have your tuner nearby for when stuff inevitably pops up.
Old Sep 15, 2012 | 05:33 PM
Calinismo350z
sooty guys haven't been hable to upload a pic of the dyno I don't have a resource to a computer I've been using my phone to log in. so far I found a crack on my kinetix V+ intake pletnum (don't ever buy it it's not worth the 300) so I replaced it with my oem on and now I've been seen close to 10psi on my gauge and the weather it's been around 110 degrees since I live in the desert but so far my car feels better even though I'm gonna have to get re-tune since I'm getting more psi. tomorrow in gonna be working on the custom idler pulley for the belt slip I don't think I have one but just in case I do.
350Z_Al
Oct 29, 2020 07:44 PM
wanderingstuden
Jan 28, 2016 07:03 PM
seagrasser
Oct 11, 2015 03:27 PM
samansharif
Sep 25, 2015 12:31 PM
