Getting ready to build
Old Nov 4, 2012 | 10:39 AM
  #161
Escobar's Avatar
Escobar
Originally Posted by Cux350z
those are interesting.
To me it looks like one of your wastegates will be relocated slightly. Probably for the drivers side.
Do you know the brand?
they were made by injected performance. the guy I got the kit from had them custom made. Only problem is he didnt include that little piece. Hopefully I dont need it...
Old Nov 4, 2012 | 10:41 AM
  #162
Escobar's Avatar
Escobar
Originally Posted by supraturboman
It looks as though your recirculste back in. Not open dump.
yea definitely recirculate, I'd rather have open dumps but oh well.
Old Nov 4, 2012 | 10:43 AM
  #163
Resmarted's Avatar
Resmarted
idk if his does or not, but id run the relocation just to have access to the gates. an extra couple of feet of vac line is another 5 min of work, might as well make the car a bit easier to work on down the road.
Old Nov 4, 2012 | 10:51 AM
  #164
supraturboman's Avatar
supraturboman
Thats what im planning on doing.
Old Nov 4, 2012 | 03:41 PM
  #165
Escobar's Avatar
Escobar
in for pics..where are you gonna re locate them to?
Old Nov 7, 2012 | 06:42 PM
  #166
supraturboman
I am relocating them towards the bottom.
What exhaust are you running on yours? I have the HKS knock off with the magnaflow x-pipe muffler. Sounds great, however I think I will loose som HP since it is only dual 2.5 piping.So I think I need to find a nice looking 3 inch dual set-up. Not that I want to spend more money, but I think it is worth it.
Old Nov 7, 2012 | 06:51 PM
  #167
Escobar's Avatar
Escobar
yea, I had the hks hi power. But at 60mm (2.36") its not very good for FI. I went with the speed force racing 3" TD with hks carbon mufflers.
http://www.speedforceracing.com/index.php?productID=845
I would definitely get a nice 3" exhaust. It will be worth it.
Old Nov 7, 2012 | 06:54 PM
  #168
supraturboman
WOW. That is a hefty price tag.. Real hefty. I wish I could find something with the twin loop mufflers like the HKS.
The other I head I had was exhaust cut outs.. Running 2 of them. I saw that Sound perfomance had one that was vacuum accuated. So when you get into boost it opens. Kinda of slick..
Old Nov 8, 2012 | 04:50 AM
  #169
Escobar's Avatar
Escobar
yea that would be sweet. I got that exhaust used on this forum so I didnt pay that much but yea, all the new 3" are at least a grand or more. You can have a muffler shop fab you up one for cheaper or just buy a used one...
Old Nov 8, 2012 | 07:28 AM
  #170
Resmarted's Avatar
Resmarted
If you want a badass exhaust that sounds good, get a custom one. For a grand or less you should be able to make a dual 3" to single 4" setup. Hell for maybe 700$ or less you could have a pretty damn nice slip on setup that you make yourself.
IMHO dual exhausts sound terrible. I like the tone of the GTR, and almost all gtr's have a dual to single (and back to dual). That's really where they get their tone (going down to single). Check out how raspy this gtr is with a (xpipe) dual exhaust:
IMO sounds like a ton of TT Z's with dual exhaust. Try going for a single, I bet it will sound better.
Old Nov 14, 2012 | 08:19 PM
  #171
supraturboman
Finally got a chance to work on the Z tonight. Made some progress.
Installed all intercooler pipes and the intercooler itself.
Mounted the front bumper.
All that is really left to do is get the exhaust situated and hooked up, then we can add fluids and pray that it starts.
I have also added a GT spec front strut bar.
The Sparco harness bar came in and am waiting on the Sparco harnesses and the Sparco R100 seats to arrive.
Oh, I also purchased a Brembo brake kit from a member here.. Super cool guy.
Old Nov 14, 2012 | 08:20 PM
  #172
supraturboman
I have also decided to swap out the front bumper for a Nismo V2, and the side skirts for the JDM nismo V1.. I don't know what I will be doing as far as the rear bumper goes yet, but still there is plenty of time to decide.
Old Nov 18, 2012 | 05:09 PM
  #173
supraturboman
Well today sucks.. The New GT spec strut bar will not fit, unless I use a ubsured amount of washers.. That's a minor issue, but bothersome none the less.
BIG ISSUE. The waste gate relocation tubes WILL NOT FIT!!! They hit the transmission and sit way way too low.
SO I at this point need to find a company that makes the tubes. DOES anyone here have any recomendations? Keep in mind that I have 3 inch down pipes. I am not sure what brand they are. I wish I knew, but I don't
PLease can anyone here help? I have used the search button, but came up with no direct answer. There are alot of kits that are similar but they all don't seem to work with the addition of a 3 inch down pipe. The down pipe I am using also bolts directly to the turbo, so it is not using the adaptor thing that Greddy uses.
Old Nov 18, 2012 | 05:25 PM
  #174
Cux350z's Avatar
Cux350z
hatersgonnahate
AAM bolts directly to the turbo and is probably the only people that still make them. They do not relocate the wastegates though.
Old Nov 18, 2012 | 05:27 PM
  #175
supraturboman
So that may have me thinking that they are custom made...
Old Nov 18, 2012 | 05:32 PM
  #176
Cux350z's Avatar
Cux350z
hatersgonnahate
There were other makers back in the day but it seems like they did limited runs. AAM's are not bad. You can install with the engine in the car if you use the right hardware and have the right tools.
Old Nov 18, 2012 | 05:38 PM
  #177
supraturboman
Gaining access to the manifold in order to both the relpcation tubes on is not a issue whatsoever. It is just that the tubes that I have are hitting the transmission really bad. The also make my Tial WG's sit way way to low. I would have aprox. 1 inch of ground clearance if I were to keep it that way.
So, pretty much I need to cut and shorten them, then try to cut and re weld them so they clear the transmission. But I don't have access to a welder.. DAMN!!!
Old Nov 18, 2012 | 05:43 PM
  #178
Cux350z's Avatar
Cux350z
hatersgonnahate
Just went to AAM competition site, they do not have their pipes listed any more.
Old Nov 18, 2012 | 05:53 PM
  #179
supraturboman
Yeah I just went and looked too. Og well. Time to find a fab shop.
Old Nov 19, 2012 | 11:13 AM
  #180
supraturboman
I talked to my shop that will be tuning the car today, they will be fixing the tubes for me. So thats a load off my mind. At this point all I have to do is put some fluids back in her and she is ready to go to the shop. My tuner advised me nor to start the car until he gets a base map loaded. Upon doing that they will check everything over for me and let me know how everything is.
