SI Upgrade with 2.87 Pulley
Old Sep 26, 2012 | 03:42 AM
Threads's Avatar
Originally Posted by 350zhp306
If you had the chance to do it all over again, what horsepower/torque would you have shoot for?
Are you referring to my V3 setup with the 928M Impeller?
Old Sep 26, 2012 | 06:36 AM
binder's Avatar
binder
Originally Posted by meanz
Well i just got an email saying that they were pretty much finished with the dyno tune..But they only took it up to 5900rpms. Said i didnt have enough tire for the power when tuning. Gonna find out tomorrow to see what the deal is. If i have to i will take out some drag radials to their shop. The numbers are at 430/390 11.4psi right now.
I would not be happy with a tuner that cut me 700 rpms short. These engines don't produce significant power (especially on a s/c) in low rpm range so your effective area under the curve is greatly reduced by not using all the rpm you can. You would have a far better power curve if he pulled some timing and extended the rpms to the normal redline so you can hold power longer. Plus what are you going to do when you get the card back? are you going to know to shift exactly at 5900 rpms? no
What tires are on the car? If they said your tires were slipping they didn't strap the car down properly or it's clutch slip they see on the dyno graph and not tire slip. I was able to do pulls up to 540hp/560tq with hard crappy all weather avon 245 tires on stock rims so if you have any performance tires (even in stock width of 245) they shouldn't slip on the dyno. Any later tuning I did with high hp I used my drag radials but the dyno eats drag radials very fast so I wouldn't recommend it.
Old Sep 26, 2012 | 06:57 AM
meanz's Avatar
meanz
Yeah im still waiting for the actual tuner to give me a call. I got the email from the desk guy there. I emailed them again last night and got an email saying " the car was becoming limited A/F range wise" and he would let the tuner explain it more to me. I dont want to be limited to the 5900 at all. I want to rev it to atleast 63-6400rpm like i was before the upgrade. I do know that they are still not 100% finished with the tuning so hopefully they do something about it.
Old Sep 26, 2012 | 08:17 AM
350zhp306's Avatar
350zhp306
Yes. How much torque would you have gone for before your engine gave in?
Old Sep 26, 2012 | 08:28 AM
Threads's Avatar
I made 440/400 before my engine gave in.
Don't want to thread jack, but you can refer to my build thread for further details:
https://my350z.com/forum/forced-indu...-v3-setup.html
Old Sep 26, 2012 | 09:22 AM
350zhp306's Avatar
350zhp306
I wanted to apologize to the OP. I didn't mean to go off topic. Great numbers by the way.
Old Sep 26, 2012 | 10:43 AM
350zhp306's Avatar
350zhp306
Originally Posted by JET MECH
With my SI trim upgrade and 2.87 pulley i am hitting 455rwhp at 6300 rpm and peak 400 rwtq by 5700 rpm. congrats on the numbers.......
Are you still pushing 14psi of boost on your stock block?
Old Sep 26, 2012 | 01:26 PM
JET MECH's Avatar
JET MECH
Originally Posted by unvmyg35
What type of dyno?
Dyno Jet.....
Old Sep 26, 2012 | 03:44 PM
unvmyg35's Avatar
unvmyg35
Dyno Jet.....
just for comparison for OP...
Im on a dynojet also in SAE format on a V2 SI 3.25 pulley with cams, headers, and Art tp's. I just retuned last week because I swapped my exhaust out from Ark Grip to MD TDX2. No more rasp or hissing sound that the Ark exhaust produced becuase of their pos x pipe.
Attached Thumbnails SI Upgrade with 2.87 Pulley-juan-f-md-tdx-vs-ark-dyno.jpg
Old Oct 3, 2012 | 04:57 PM
meanz's Avatar
meanz
Little update, I was finally able to pick the car up on monday morning. Only bad thing was, it rained all day and i had to fly back to Afghanistan the same day. I wasnt really able to get into it, except for a few places here and there. One thing i can say is, its a night and day difference in power compared to before the SI up grade. Third, fourth, and fifth pull like crazy! I wasnt even punching it, but just rolling into the throttle and it pulls like no other. The rev is set to 6400, im making right at 11psi and making around 436/390 right now. Im really happy with the upgrade. She is now sitting pretty in my driveway waiting for me to come back. Car still has a few tweaks to be made via the tuner, but he said he would come to my house to adjust my issues for free. I live about 1.5 hour away from the shop. I want to give a huge shout out to CIN Motorsports in Charlotte, NC. Car has come a long ways thanks to them! Here is a picture of her before i had to leave to catch my flight.
Old Oct 19, 2012 | 09:43 AM
macs350z's Avatar
macs350z
Nice to see everything got worked out, I just hope my numbers look like that, I have the impeller upgrade and changed my pullies I should see- 13 PSI. Car has been down since July 7th, :/ Cant wait for your full review when you get back, BTW White HOT,
Old Oct 20, 2012 | 06:48 AM
meanz's Avatar
meanz
Thanks, im glad the car is finally together and pulling hard. I picked this thing up as a rolling shell and had to put a lot of stuff into it. I cant wait to get home and see what it can do, id be happy just to go home and do a full detail on her. Z is pretty dirty from the transformation. I will be sure to give a good review of the upgrade when iget back, along with some videos.
Old Oct 20, 2012 | 07:59 PM
TSG-Z's Avatar
TSG-Z
Nice numbers, I should be putting down the same numbers but Sharif's heartbreaker keeps around the 420 mark...
Fixxxercask
Nov 9, 2015 11:10 AM
