JWT 700BB Engine Build Results
Old Nov 2, 2012 | 06:38 PM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Default JWT 700BB Engine Build Results
Car finished out at 551whp/558wtq peaking at 18psi in the midrange and dropping to 16.5-17.
http://youtu.be/KUCJW6UfWLw
IPP Custom Stage 3 Long Block:
~~ Cosworth Rods, CP 8.5:1 Pistons w/ PolyDyn's Ceramic/Moly coating on the piston tops & skirts
~~ ACL Trust Washers, Main & Rod Bearings
~~ ARP Main Studs & Rod Bolts, L19 Head Studs
~~ ATI Street Damper Crank Pulley
~~ Heads Redecked, Ported Intake/Exhaust Runners, 5-Angle Radius Cut Valve Job
~~ JWT C2 {261* w/ .456 (11.58mm) lift Intake & Exhaust} Cams
~~ JWT Heavy Duty Springs & Shims
~~ Viton Valve Seals
~~ OEM Gasket kit with Cometic Head gaskets
~~ OEM VQ35 "Rev-Up" Oil Pump
~~ OEM VQ35 Pathfinder Rear Cooling By-Pass
~~ Nismo Low Temp Thermostat
Fuel:
~ CJM Stage 2 Return Fuel System w/ Blue Billet Fuel Rails
~ CJM Twin In-Tank Fuel Pumps
~ Injector Dynamics 1000cc Injectors
EMS:
~ HalTech Plug-In Pro ECU Replacement EMS
~~ HalTech Boost Control Solenoid
~~ HalTech Dual Wideband Kit w/ 2 Sensors
~~ Dual Wideband Gauge
Drivetrain:
~ Nissan CD009 (2004+) 6sp Transmission
~~ Carbonetic Twin Disc Carbon Clutch w/ Carbon/Steel Flywheel
~~ Quaife Helical LSD
~~ 3.3 Nissan Auto Final Drive Gearing
Exhaust:
~ Greddy RS Cat-Back Exhaust
~ APS 2.5" PolyDyn Coated Downpipes
~ PolyDyn Coated Manifolds & Turbine Housings
You can read the full build thread here; https://my350z.com/forum/texas/54165...ore-boost.html
Old Nov 2, 2012 | 07:05 PM
Escobar's Avatar
Escobar
sick car man, nice numbers.
Old Nov 3, 2012 | 04:03 AM
graffkid732's Avatar
graffkid732
Very nice.
Old Nov 3, 2012 | 04:10 AM
supraturboman's Avatar
supraturboman
Awsome results. Congrats on getting it finsished. Your car is truely a inspiration to us all.
Old Nov 3, 2012 | 04:11 AM
NA&CH's Avatar
NA&CH
Very nice results!! Congrats.
Chris
Old Nov 3, 2012 | 05:05 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Thanks guys! Can't wait to get home and enjoy it!
Old Nov 3, 2012 | 08:46 AM
rcdash's Avatar
rcdash
Congrats. Great looking car and great numbers for the street. By the way, I think you technically now have a stage 3 CJM fuel system
Old Nov 3, 2012 | 08:53 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Thanks! And I guess your right. LOL
Old Nov 3, 2012 | 09:00 AM
CRIDDA's Avatar
CRIDDA
Very nice Robert. She looks like she is going to be a fun little girl. Hope you enjoy it.
Old Nov 3, 2012 | 09:16 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Thanks Cridda! Can't wait to get home and take her for a spin!
Old Nov 3, 2012 | 10:16 AM
Zivman's Avatar
Zivman
seems like a lot of boost for that power. I would think you could make that power at ~15 psi...?
Old Nov 3, 2012 | 10:39 AM
taywan's Avatar
taywan
Gota to be fun to play with!! Aweswome man!!! Me want more boost!!! ;/
Old Nov 3, 2012 | 11:10 AM
BornSlippyZ's Avatar
BornSlippyZ
Congrats on your car being completed Robert!
Old Nov 3, 2012 | 01:04 PM
djamps's Avatar
djamps
It's not what you might expect because the kit is out of breath and making peak power at 5krpm.
Looks fun, enjoy OP.
Old Nov 3, 2012 | 04:17 PM
Zivman's Avatar
Zivman
the 700 should have similar sized turbos... maybe even slightly bigger than the standard aps turbos. GT28/86 vs GT28/71. my car made about the same power at 15 psi with the aps kit. Obviously different dynos and my car is 9:1
I am not up to date with recent parts, but cometic doesn't have a good rep from the research I have done. Is it a specialized spec?
Old Nov 3, 2012 | 04:21 PM
djamps's Avatar
djamps
Turbos might be similar but everything else is different -- the piping, manifolds, downpipes, everything is different than the APS which breathes far better than the JWT kit. You've also got a bump in compression ratio which adds almost 10% more power given ideal conditions. That said the OP has put down solid numbers for that kit and it looks like a blast to drive.
Old Nov 3, 2012 | 06:12 PM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Thanks guys! Looking forward to coming home and enjoying it.
Old Nov 3, 2012 | 06:49 PM
taywan's Avatar
taywan
Man I really miss my cf sills man. Lmk if u don't want them if pay shipping bk to me. :-(
Old Nov 3, 2012 | 07:00 PM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
LOL! I'm still in Iraq and haven't even seen them! If I don't I'll let you know first!
Old Nov 3, 2012 | 10:57 PM
wannabuy350z's Avatar
wannabuy350z
congrats Robert,
i have very similar results. i just tuned my car last week and except i have BC 272 cams.
JWT 700BB
BC 272 Cams
581rwhp on a Mainline Dyno 18psi drops to 16 psi. i think my haltech solenoid is not working as i was trying to bring boost up but didnt work.
