Vortech v3 Supercharged HR engine build
Old Dec 11, 2012 | 11:12 AM
germanguy818's Avatar
germanguy818
Default Vortech v3 Supercharged HR engine build
Old Dec 11, 2012 | 11:33 AM
str8dum1's Avatar
str8dum1
you'll get even more answers here.
personally id do
eagle rods
arias extreme pistons 10:1
jwt valve springs
jwt c2 cams
ATI crank pulley
and biggest/smallest supercharger pulley combo to run the most boost it will make.
Old Dec 11, 2012 | 01:33 PM
350z006's Avatar
350z006
I managed to fit a V7 YSi trim in my Vortech kit, but it's the DE kit; the Stillen kit uses a SC trim blower which is a slightly smaller version of the YSi, so hopefully it's fit no problem, or at least with minor work needed.
I also re-built the stock SC trim blower on my setup with a 928 Impeller to generate ~500whp as well (I actually pushed it to ~600whp but I don't recommend overspinning it that much)
Old Dec 11, 2012 | 02:40 PM
germanguy818
Old Dec 11, 2012 | 03:08 PM
OldManZ350's Avatar
OldManZ350
No!!!!!! Stock is 10.3 to 1, If I build I will go to 11:1
Originally Posted by germanguy818
Thx for the feedback - does anybody here have a supercharged HR with a built engine?
I think 10:1 compression pistons are too high don't you think..
Old Dec 11, 2012 | 03:23 PM
Elperuano's Avatar
Elperuano
Good question, does anyone have a built motor and is running a SC?
Old Dec 11, 2012 | 04:57 PM
Classy's Avatar
Classy
Gab3d, and there are a few others, I want to say all are at 500+hp
Old Dec 11, 2012 | 06:59 PM
Elperuano's Avatar
Elperuano
Yea I just remembered Gabe got it running
Old Dec 11, 2012 | 11:09 PM
germanguy818
Old Dec 11, 2012 | 11:35 PM
NateZ08's Avatar
NateZ08
Are you in Spring, TX or is that where the shop is located?
Old Dec 11, 2012 | 11:36 PM
OldManZ350's Avatar
OldManZ350
I sure that was not the cause. It was most likely do to a combination of things.
What was your setup details.
I blew my piston rings due to compression this high. Lol
Old Dec 12, 2012 | 12:04 AM
germanguy818
Old Dec 12, 2012 | 12:09 AM
germanguy818
Old Dec 12, 2012 | 06:41 AM
str8dum1's Avatar
str8dum1
that was from detonation, which i guess is technically high compression (explosion) LOL
Old Dec 12, 2012 | 08:58 AM
OldManZ350's Avatar
OldManZ350
Ya, So Bad tuning and/or Bad Gas.
Too much ignition timing and too lean AFR's @ some point in the Tune.
Don't know how the car was driven or taken care of, miles, oil, ect.
All of these things can play a part.
Still need detals of your build, tune, Ignition timing and AFR's, and Boost
Question: so your motor only lasted 4-5 months with the Vortech?
Old Dec 12, 2012 | 10:02 AM
germanguy818
Old Dec 12, 2012 | 10:21 AM
ace32x's Avatar
ace32x
I had it boosted oct 2011. 5months ago I changed out the pulley and added an extra lb of boost. I had just changed my oil a week prior to the pass and ran on 91 oct as usual. The work as done over at Stillen. The tune shouldntve had much to do with it since I had the car dyno'ed at another shop where I was told the tune was one of the best the guy had ever seen...
did you retune after the pulley swap?
Old Dec 12, 2012 | 10:22 AM
OldManZ350's Avatar
OldManZ350
So you had it tuned before or after you added extra Boost? Specs !!!!!!
What is "tune was one of the best the guy had ever seen" What does that Mean?
This means Nothing, need Specs !!!!!!!!!! Details, Details, Details.......
The TUNE has EVERYTHING to do with IT !!!!!!!!!
Old Dec 12, 2012 | 12:32 PM
Buster-here's Avatar
Buster-here
10.6 on an HR.
350Z_Al
Oct 29, 2020 07:44 PM
seagrasser
Oct 11, 2015 03:27 PM
Calinismo350z
Sep 14, 2015 04:04 PM
