Motor Rebuild Now I Know
Old Dec 20, 2012 | 04:21 AM
graffkid732's Avatar
graffkid732
I don't know what I would do if I found out this happened to me. Good luck with the rebuild and sorry to hear about this.
Old Dec 20, 2012 | 04:59 AM
tonyzS/C03's Avatar
tonyzS/C03
Man, that sucks brother. I had a similar situation and I know your pain, hope that you get everything worked out and back on the road soon.
Old Dec 28, 2012 | 08:03 PM
fklentz's Avatar
fklentz
Final result:
Arias pistons but not arias Extreme duty as alleged, rods were pauter as stated. EVERYTHING else stock. Head gasket, head bolts, injectors, valves, valve springs, cams.
The build will be done in a few weeks and it will be built as originally stated.
Old Dec 28, 2012 | 08:12 PM
Triji's Avatar
Triji
Oh dang that sucks, sorry man... Are they comping you anything for the build or will you be totally out of pocket for it?
Old Dec 29, 2012 | 04:33 AM
Resmarted's Avatar
Resmarted
Well 77k miles... That's a lot of miles for any built engine.
So...... IDK.
Probably because you were running power levels stock injectors could make LOL. Lol stock injectors... what a joke!
Old Dec 29, 2012 | 06:32 AM
binder's Avatar
binder
Yep, I found out the first built engine I had did not have the expensive billet crank in it that I paid for. After a head bolt pulled out and I was gutting the block for another block I found that I was ripped off. I checked everything else out but never thought to question the billet crank.
I don't trust any shops to do work without me visually seeing anything....which is why I do all of my own work now. This is also why I return all oem parts and aftermarket part boxes to the people that I do work for just so they know I'm not screwing them over.
Old Jan 9, 2013 | 09:44 PM
o__O's Avatar
o__O
How is everything coming together? In for the results.
Old Jan 9, 2013 | 09:59 PM
bealljk's Avatar
bealljk
a sorta-built engine…
to the OP - rebel-in-the-fact that karma is a ****en *****! and what goes around comes around…you can only screw over a handful of people 'til one comes back with a revolver and high blood pressure...
Old Jan 11, 2013 | 06:44 AM
fklentz's Avatar
fklentz
The build:
New pistons Arias ED this time
Pauter rods (no problems with the rods I had)
ACL bearings
Heads are Ported and Polished oversized valves all Supratech hardware (purchased from a member on here)
Cams Cosworth 272
HR head gasket
ARP L19 head studs
600cc Siemens injectors flow matched
Also replacing the SS box with a Haltech EMS and re-doing the air piping for a better fit.
Should be done in a week or two.
Old Jan 11, 2013 | 07:40 AM
rcdash's Avatar
rcdash
Are those 2618 zero silicon aluminum pistons? I would not run those again. Too much piston slap on cold start ups resulting in quicker wear over time.
350Z_Al
Oct 29, 2020 07:44 PM
