FS: Stillen supercharger with upgrades for 03-06
Selling my Stillen supercharger kit and supporting mods. This kit comes with the possibility to run it at stage 1 or stage 4. With the utec you can run this with the small or big pulley. So either 4.5lbs of boost or 8.5.
This came off of a 2006 rev-up. So the ss box is programmed for a rev-up with the stage 4 pulley. Has about 16,000 miles on it.
Whats included:
- Stillen supercharger kit - Intercooler system kit with upgraded front mount. (old intercooler will be included) - Seventh injector system (found out this is good for cooling and sealing the rotors as well as adding in the extra fuel) - Split second stillen box - Utec engine management - 600cc dw injectors - Front sway bar ( cant use the old one with this kit)
With the Utec and injectors you can pull about 40 more whp out of this system and the setup can be used on any 03-06 350z or g35. Even you guys in California can use the stage 1 or buy any size pulley youd like.
Asking $2,850 for the works. May part out later.
Whats included:
Dyno with just stillen no mods at 5,300 ft. elevation. Getting 1.5lbs less boost than at sea level. Picked up 25 more on both with mods.
And a baseline to see what the elevation does. Only 207 wheel torque.
Yes it is a turn key kit. Except if you want to use the upgrades then obviously you would need to mount the upgraded IC so it fits good in your bumper and you would need a good tune with the utec and 600's. But if you have a rev-up then you can use the ss box.
Pending sale. The guy says he will buy it when I have it off and I had planned to take it off this past weekend but it was a high of 7 degrees in my garage. Supposed to be in the 40's this weekend so Ill hit it this time.
Ill post up on here Monday.
Well the guy that was going to buy the Stillen kit, upgraded IC, sway bar, utec, and DW600's had a deal. Now that its off I told him ill drop it off and he said he is $200 short now.
So...What are your offers?? You pay shipping.
Yes, the utec will work for your '05 and you could run this setup.
MY INBOX IS FREE"D UP NOW...so whoever tried PM'ing me can try again.
When I took it off both belts are in perfect condition. I mean to the point I could say I included brand new belts. Those gates belts are 100x better than the crap they used first. I have about 6,000 on them and they could go for 30,000 easily by the looks of them.
350Z_Al
Oct 29, 2020 07:44 PM
