Turbo VR6 in 350Z
Old May 8, 2014 | 08:34 AM
  #281
350VRz's Avatar
350VRz
I know I've been so busy on the VR6 DeLorean getting ready for the big DeLorean car show. The owner is coming next week to pick it up and drive back to Ohio.
Old May 8, 2014 | 08:56 AM
  #282
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
What turbo is on that DeLorean and what the achieved or expected power numbers with that setup?
Old May 23, 2014 | 06:52 PM
  #283
350VRz's Avatar
350VRz
Turbo is a T3/T4. Compression was dropped to 9.2:1 and running 5psi for now until phase II which is a auto tranny upgrade. Car made around 200whp on 5psi and can put down 400whp as is. Car makes about 95whp stock. The big holdback is the transmission. The car drove from Florida to Ohio nonstop 15hrs, 1000+ miles with zero issues.
Old May 31, 2014 | 11:30 AM
  #284
350VRz's Avatar
350VRz
I finally have had some time to work on the Z. I got the throttle body installed and cable hooked up. I have a few little things to button up under the intake before it's done on that side. Turbo manifold is all welded up and it looks great, thank you Kiko Engineering in South FL. I need to add a support brake that I'm going to run to the engine mount to help support the weight of the manifold and the turbo. I'm going to have the flanges run on a mill this week to make sure they're are flat and then I can get the turbo installed finally. next will be the fuel system and Megasquirt Pro module install.
Old May 31, 2014 | 11:40 AM
  #285
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
Nice. Yeah, I can imagine that old stock 3-speed auto trans being a major hindrance. Would love to see what a boosted DeLorean can do with a capable transmission.
Old Jun 1, 2014 | 10:49 AM
  #286
350VRz's Avatar
350VRz
I ran low12's high 11's with the 2JZ DeLorean before I sold it.
Old Jun 1, 2014 | 10:51 AM
  #287
350VRz's Avatar
350VRz
I hung the turbo in the car today so I could see how she fit and I'm happy how it turned out. I'm having the machine shop flatten the flanges this week and hopefully get it permanently installed by the end of the week.
Old Jul 24, 2014 | 05:03 AM
  #288
350VRz's Avatar
350VRz
So I'm finally back on the car after getting a few customers cars done. I finished up a lot of little things like the throttle body and waste gate install. I was able to fab up the 3.5" downpipe and started the 3.5" aluminum exhaust. I still have to finish up the dump tube for the waste gate. What's nice is I'm using the original wideband sensors that plug right into the factory harness.
After looking closely at the fuel and EVAP hard lines running from the back of the car to the front, I am going to use the EVAP line as my fuel feed and the original fuel line as my return. I'll just TIG weld AN fitting to the ends. I decided to use them because they are hard lines and they are already neatly run from the back to the front of the car.
Old Jul 31, 2014 | 05:59 PM
  #289
350VRz's Avatar
350VRz
I was able to finish up the exhaust today.
Old Aug 4, 2014 | 07:33 AM
  #290
joshua350z6841's Avatar
joshua350z6841
exhaust looks good. love the flow
Old Aug 13, 2014 | 11:53 AM
  #291
350VRz's Avatar
350VRz
Thank for the compliment, I can't wait to hear this thing run!
So I wanted a simple in tank fuel pump setup for a Walbro E85 416lph pump, so I made my own. This unit uses the factors fuel level sender and low level sensor. I also designed a venturi siphone to pull fuel from drivers side tank as the fuel level drops. It has a AN-8 outlet and AN-6 inlet. I'm going to use a 4 pin Mil spec connector for power and signals.
Old Sep 3, 2014 | 09:45 AM
  #292
350VRz's Avatar
350VRz
I finished up the fuel pump assembly. I used all Teflon wiring and Viton rubber to seal up the terminals. I'm waiting on my $30 a foot in tank fuel hose to finish off the tank siphon and I can close the tank up. Everything will be E85 compatible inside the tank. All the new fuel pump relay/wiring is finished and ready to go. I ran a 12awg wire from the battery to a 40A relay at the tank and will trigger the relay with the original fuel pump wires.
Old Sep 4, 2014 | 07:08 AM
  #293
1BoostedM3's Avatar
1BoostedM3
Wow! this is coming along way better than expected. Awesome craftsmanship!
Old Sep 4, 2014 | 07:40 AM
  #294
Jah70's Avatar
Jah70
Moving along nicely.
Old Sep 4, 2014 | 08:16 AM
  #295
NOLAGG's Avatar
NOLAGG
Awesome so unique can't wait to see it run
Old Sep 6, 2014 | 05:12 PM
  #296
350VRz's Avatar
350VRz
Thanks guys. I'm pushing as much as I can to get this thing running ASAP.
I finished up the tank and pump wiring and was able to put the interior cover back on. I'm moving onto the ECU now.
Old Sep 7, 2014 | 03:56 PM
  #297
phunk2's Avatar
phunk2
did you put the metal access cover back in first?
Old Sep 7, 2014 | 04:31 PM
  #298
e30cabrio's Avatar
e30cabrio
Wow.
Old Sep 11, 2014 | 06:02 AM
  #299
350VRz's Avatar
350VRz
No, I was not able to because of the fittings being so high. I did not want to use the tight bend fittings because of it being a flow restriction.
Old Sep 11, 2014 | 09:10 AM
  #300
350z006's Avatar
350z006
Sorry to OT OP, but is this necessary? I know I didn't install the metal access cover when I installed my twin pump...
