Turbo VR6 in 350Z
Old Feb 25, 2013 | 04:36 PM
  #141
350VRz's Avatar
350VRz
Ok update on the cams. to be fair MJM was tring to get info for me. TT had them on back order. They should be showing up this week. I wish they would have just told me that. I would have no issue with that as long as i know what is going on.
Old Feb 25, 2013 | 06:10 PM
  #142
bmyles's Avatar
bmyles
Like I said, didn't have 'em in stock
Old Feb 26, 2013 | 04:13 AM
  #143
350VRz's Avatar
350VRz
If they don't have them in stock, the customer should be notified immediately.
Old Feb 26, 2013 | 06:53 AM
  #144
bmyles's Avatar
bmyles
Totally, but it seems to be a fairly common business practice.
Old Feb 27, 2013 | 07:33 AM
  #145
Wikiwiki's Avatar
Wikiwiki
heres a vr swapped s4, e98 and 35lbs of boost
he has the front diff disconnected awd normally
http://www.audizine.com/forum/showth...sion-yesterday
Old Feb 27, 2013 | 08:48 AM
  #146
350VRz's Avatar
350VRz
Hey guys, here is the schematic I have come up with for installing a VR6 engine in the 350z using the stock harness. It’s nice because the harness is already integrated into the car’s relay, power and grounding systems, you just have to run the signal wires and trigger the relays as you want. You just undo the harness after the coolant temp sensor and knock sensor connector and rewire it to your new engine. You can remove any wires you don’t need. This may also help you guys doing LSx swaps if you want to reuse the 350 harness in your swap.
This is not released yet but will do after the car is wired up. It should be correct. Please let me know if anyone spots any issues and I'll make a rev change, hell I'll make an LSx version if someone feeds me the info they would like to see.
(New schematic Update 3/1/2013)!!!!
Rev X3 is updated to wiring in a megasquirt 3 pro module inside the 350z ECU housing.
For those that do not know, you can zoom in and out on the PDF if you hold down Ctrl and use your mouse wheel.
File Type: pdf
Old Feb 27, 2013 | 08:50 AM
  #147
350VRz's Avatar
350VRz
NICE!! good motor to swap in a 350Z...........
Old Mar 2, 2013 | 06:27 PM
  #148
350VRz's Avatar
350VRz
FYI, I have updated the wiring schematic a few posts up. I will always put the latest Rev in that post.
Here is a shots of the wiring pulled apart. As you can see you have more then plenty to do what you need. This would wire up an RB or LSx too.
This is what you'll see of the wire harness when it's all done. All the rest will be hiden under the intake manifold.
To solve my oil filter relocation, I welded AN-10 fittings to the oil cooler cover. I also added an AN-3 fitting for the turbo and the 350z oil pressure sensor. I also had to tig weld up the holes in the threaded tube that threads into the block.
I should get the cams this week from what Techtonics Tuning told me. They shipped this past Tuesday from the west coast.
Old Mar 4, 2013 | 03:56 AM
  #149
350VRz's Avatar
350VRz
Here is the stock 350z Power Steering line I rotated and welded an AN-6 fitting too.
Here is the oil cooler with the fittings and oil pressure sensor. It turned out better than I thought. I plan to mount the filter near the firewall where it's easy to get to.
Old Mar 6, 2013 | 11:49 AM
  #150
Resmarted's Avatar
Resmarted
You're doing a great job man! Keep it up!
Old Mar 8, 2013 | 02:41 AM
  #151
350VRz's Avatar
350VRz
Thanks!
So the 276 cams finally came in yesterday and I got them installed and the upper timing cover on.
I decided to build my own intake manifold instead of paying $550-$1200 for one. The stock manifold is probably fine for 90% of builds, but for the power level I’m looking to reach it just won't cut it.
As the base, I'm starting with the lower half of the stock intake manifold. I have calculated the volume of the plenum and have a 5" aluminum tube on the way ($36). For the back cover of the plenum I selected a vintage 5" decorative aluminum bowl ($20) and for the transition from the plenum to the TB, I purchased and 5" industrial aluminum funnel I'll cut to fit the TB flange ($9).
To maximize air flow and efficiency, I have turned my drill press into a Milling machine so I can put a velocity stack like edge to the intake ports ($8 for the router bit set). I cut at about 900rpm and it got the job done. Here are some pics of the rough cut; I still need to clean the ports up and smooth everything out.
Old Mar 8, 2013 | 06:01 AM
  #152
djamps's Avatar
djamps
So much win. Keep it coming!
Old Mar 8, 2013 | 02:08 PM
  #153
dikspiel's Avatar
dikspiel
Chestons Toilet
interesting build, thanks for sharing
Old Mar 8, 2013 | 02:28 PM
  #154
Resmarted's Avatar
Resmarted
Another alternative to velocity stacks are carb horn things. You can get them in all sizes and machined real cleanly for not too much. More than machining them into your ports, but it's a thought.
Old Mar 9, 2013 | 04:52 PM
  #155
350VRz's Avatar
350VRz
Here is a video of the starter turning the engine over. Battery was a little low but shows the starter engagement with the flywheel is perfect. Sorry it came out sideways!
http://s40.photobucket.com/albums/e2...ps65fba602.mp4
Old Mar 9, 2013 | 05:05 PM
  #156
350VRz's Avatar
350VRz
Yes but i could not find a size to fit both port diameters they use on this engine to compensate for runner length.
Old Mar 9, 2013 | 08:25 PM
  #157
jerryd87's Avatar
jerryd87
curious what yah did to convert the drill press to a mill and how well its worked? always my understanding bearings wont hold up to the side loading but $300 for drill press vs $1200 or more for a drill/mill is still a huge difference lol
Old Mar 10, 2013 | 05:37 AM
  #158
350VRz's Avatar
350VRz
The drill press had no issues from what I could tell. I had to remove the toothed bar and retainer ring so I could slide the deck up high enough. I flipped the deck upside down so I could run the manifold on the flat side with the bit set just right. Set it for 900rpm and I slowely went at it. Once you get the bit cut in on one side I slowely cut in a rotating fashion. I did not push hard.
Old Mar 10, 2013 | 02:01 PM
  #159
jerryd87's Avatar
jerryd87
hmmmmm very nice i might have to grab a drill press haha
Old Mar 11, 2013 | 02:57 AM
  #160
350VRz's Avatar
350VRz
I thought people would be interested in this. The aluminum funnel I got was way too thin so I found this on eBay.
http://cgi.ebay.com/ws/eBayISAPI.dll...m=261027957773
So my dremel took a dump so I have to wait on new motor brushes before i can finish the manifold. My buddy may loan me his so i can keep going.
