BUDGET Turbo Project- Started
Old May 13, 2015 | 07:00 AM
  #361
iideadeyeii's Avatar
iideadeyeii
No plans to ever dyno it unless it's free. 12.9 on streets
Old May 13, 2015 | 05:50 PM
  #362
ksuberk54's Avatar
ksuberk54
estimated power?
Old Jun 9, 2015 | 10:47 AM
  #363
iideadeyeii
I should be getting a free dyno thursday. I will update a sheet if I am able to do this
Old Jun 9, 2015 | 06:04 PM
  #364
iideadeyeii
5th gear Not very smooth curve. Timing is set to 7.5-11.5 degrees at full boost.. AF/R are around 11.8-12, but I was running open dumps so they couldn't hook up the meter
Old Jun 14, 2015 | 12:53 PM
  #365
ksuberk54's Avatar
ksuberk54
Ouch man. You think it's the turbo? The kit? Bad seals? I was thinking you would be at 350hp or so
Old Jun 14, 2015 | 01:51 PM
  #366
The_Assassin's Avatar
The_Assassin
damn I was thinking you would be at least 300whp. Torque is decent for the type of kit you have tho
Old Jun 15, 2015 | 06:45 AM
  #367
iideadeyeii
My brother who was going to school that had the dyno said it wasn't normal for the car to bounce. They had to kinda ghetto the rear straps because they were so close to the rear tires, but based on my quarter mile time the horsepower seems right for 5psi(I've seen it hit 7.8psi at higher rpms) I'll have to hook my laptop up(no boost gauge in caar) get on the highway and see what it's boosting now, but working on prepping and painting my front bumper(been unpainted for a year and a half)
Old Jun 19, 2015 | 08:59 PM
  #368
OldManZ350's Avatar
OldManZ350
Very Retarded Ignition Timing! On a Vq with about 8psi Timing should be more like 15-18 degrees full advance @ full load and then increase to about 17-20 degrees full advance @ redline. Just ballpark numbers.
Old Jun 22, 2015 | 05:35 AM
  #369
iideadeyeii
I'll start increasing and check for knock when I get a chance or can use the map on the right and fix the 100 column the smooth it out from 70-100 and see how that goes.
With as much experience as you have, any idea how much I'm losing because of the timing.
My map on the left vs an aps 550cc map (both taken from turboxs website)
[img][/img]
Old Jun 22, 2015 | 10:25 AM
  #370
i-break-things's Avatar
i-break-things
Not bad RWHP (power to the ground), Looks like the pull starts about 3k?
Especially, for a small turbo with a .little T-3 hotside, Have you checked turbine back pressure VS boost?
There should be some room for improving. (tune)
Old Jun 22, 2015 | 11:33 AM
  #371
iideadeyeii
It was around 3k. The dyno there went by MPH I'll look it up so see what speed it was. Topped out around 150mph.
Do you mean the back pressure of the exhaust or boost at output of turbo vs manifold boost pressure?
Old Jun 27, 2015 | 12:44 AM
  #372
andybp's Avatar
andybp
hey only just seen your thread good work i started my diy rearmount november 2013 still ongoing haven't blown the engine yet see you had the same problem as me people slating the project because your not using hks garrett etc i found 90% of this was coming from people who cant do the work themselves, have no actual experience of what their talking about and are actually just repeating something they heard and didn't really understand anyway
keep up the good work
if you get the time check out my build.
http://www.350z-uk.com/topic/78039-diy-rear-mount/
Old Jun 27, 2015 | 07:48 AM
  #373
i-break-things
Pre-turbine manifold pressure vs compressor pressure.
It is a great measure of performance. Less than 2 : 1 Turbine - compressor is good.
Old Jun 29, 2015 | 07:09 AM
  #374
iideadeyeii
I have no idea how to test that, but from multiple people I have leaned that my timing is very retarded and I'm losing a lot of whp from it
Old Jul 7, 2015 | 02:27 PM
  #375
ksuberk54's Avatar
ksuberk54
I would go just pay the extra couple hundred bucks and get it professionally tuned man.
Old Jan 8, 2016 | 08:21 AM
  #376
iideadeyeii
Final Costs for turboed350z
$1360 Godpseed Full turbo kit + Utec
$180 550cc Injectors
$50 50mm ebay Wastegate(didnt use)
$50 38mm emusa wastegate
$26 Copper Gasket for wg
$14 Tial 5psi wg spring
$23 oil filter sanwich plate
$20 50mm wastegate piping(didnt use)
$30 RFL BOV(this was optional)
$25 Graphite gasket sheet
$6 furnace cement(not on there anymore)
~$50 misc gaskets(estimating high here)
$134 oil pan spcer
$1968 total. Could of had around $1800, but I bought things that didn't work or I didn't need.
Things added later.
Sold free exhaust I had on car for $500 and bought wider tires and an e-cutout for around $500($414 free mouting/balance because I have the machine)
Old Jan 8, 2016 | 08:40 AM
  #377
350z006's Avatar
350z006
I think one thing to add for any newbies looking at this cost number, you have to put into account your ability to DIY/Improvise/self tune the setup, which is pretty hard to quantify/priceless....
$134 oil pan spcer
Things added later.
Old Apr 25, 2016 | 12:52 PM
  #378
iideadeyeii
Small update. Since I had the turbo installed I have had an engine code for cats(O2 sensors).
Two weeks it started hesitating in boost in 3rd gear/higher after advancing the timing and threw a code for multiple misfires.
I still had oem heat range denso iridiums that were only a few thousand miles old. I went back to old timing and misfires were still there.
I purchased NGK iridiums one heat range colder and installed them. Misfired went away and now I can actually get a sticker(haven't had once since 2013) since the ecu readied even under boost.
I will have to play with timings again
Old Apr 26, 2016 | 07:31 PM
  #379
bealljk's Avatar
bealljk
Dont feel bad...my car hasnt been legal since 2013 ...
how are you tuning timing?
Old Apr 27, 2016 | 05:41 AM
  #380
iideadeyeii
Utec can adjust the timings. It's more going to be highway pulls and logging to check knock. I don't think I am going to go too aggressive but the timing I have listed are very conservative from what I've been told.
I might just upload the aps tt timing map and see what happens.
