BUDGET Turbo Project- Started
Old Sep 1, 2014 | 05:29 PM
  #321
Phillip_G35's Avatar
Phillip_G35
Originally Posted by npr350z
330 seems like a quite fine daily number. i feel like after 400 on the z and gs, they just get a bit too rowdy. but thats just me.
F/I setup for just 330WHP?😳
Tha ****kkkk with that!!! 😭
Old Sep 2, 2014 | 12:27 PM
  #322
iideadeyeii's Avatar
iideadeyeii
2k for 90whp? People usually spend that for 15whp. Also I have no idea on WHP(don't care) Just guessing. 1/4 is more important to me
Old Sep 2, 2014 | 04:15 PM
  #323
NOLAGG's Avatar
NOLAGG
Same here I don't think of supra power when I hear Z, but a nice 1/4 is what I'd want as well since I'm going to start piecing a kit together soon.
Old Sep 8, 2014 | 01:11 PM
  #324
iideadeyeii
Car is back together with 6psi spring installed(instead of 5). Car feels slower than before.
Confirmed that car IS slower than before. Hooked up the computer(only boost gauge I have is on my laptop) Boosted only 1-1.9 psi and only above 6500rpm. I did have the hose disconnected on the wastegate(but that would make it overboost) I hooked it up anyways and still same thing.
I need to take wastegate apart and see why it's staying open. I'm in the process of buying my second house and haven't had much time to play around with it. May take some time before I get around to working on it
Old Sep 9, 2014 | 05:22 AM
  #325
NOLAGG's Avatar
NOLAGG
Keep us updated
Old Sep 9, 2014 | 08:50 AM
  #326
ksuberk54's Avatar
ksuberk54
I think the kit could be okay if you upgrade the turbo, wastegate & BOV. At that point, it might just be easier to buy a used kit. Either way, I like that the OP didn't let anyone get him down and went in the direction he wanted. Nice work.
Old Sep 15, 2014 | 11:30 AM
  #327
Z_rican's Avatar
Z_rican
I bought this kit and changed out the wastegate and bov to a tial and I also had boostlab rebuild the turbo using garret internals. My problem is that I can;t get the piping to align correctly. I am about to sell the kit. Props to Op for getting this kit running.
Old Sep 15, 2014 | 11:23 PM
  #328
wannabuy350z's Avatar
wannabuy350z
i think you need to spec a little on quality BOV and WG and you should be ok. you never know with these kits, its a hit and miss kind of deal. so many variable
bov leak
WG bad opening
turbo issues
boost leak
Old Sep 29, 2014 | 09:50 AM
  #329
iideadeyeii
BOV is staying closed(opens when it should at what little PSI I'm building) When I took the turbo out to fix the A/C line I verified the shaft play and that it span flawlessly.
No intercooler piping is off. All clamps are tight.
I did take the top of the WG off and normally you can pull the diaphragm up slightly to reveal the large nut underneath. . .I couldn't move it at all.
So the Wastegate is stuck closed? Which still doesn't explain no boost...this would mean lots of boost. I need to take it off completely or possibly switch it out to a spare that I have
I want to track this before the track closes on OCT31. So expect a timeslip before then
Old Oct 5, 2014 | 04:06 PM
  #330
iideadeyeii
Found the problem. I am not sure how I missed this the first time I looked at the couplers....I'm still kinda impressed I managed 1.9psi at redline even with that off
Bolted back up with "5"psi spring(Tial spring with emusa wastegate). It's doing 7-7.5psi, but not over 8 since that's where my boost cutout is set at.
Took my Kat Matrix 3-axis accelerometer out on the highway(was .1 sec slow from a 15.7 quarter mile vehicle at new england drags)
Ran 13.1 at 111mph. Launch bad. shifts good and this is with the stock exhaust
Old Oct 8, 2014 | 07:23 AM
  #331
danny724's Avatar
danny724
[QUOTE=iideadeyeii;10478637]Found the problem. I am not sure how I missed this the first time I looked at the couplers....I'm still kinda impressed I managed 1.9psi at redline even with that off
Ran 13.1 at 111mph. Launch bad. shifts good and this is with the stock exhaust[/QUOTE
Nice !!,that's good ur still going on with this project 👍
Old Oct 10, 2014 | 12:30 PM
  #332
iideadeyeii
Track day oct 19. Can't go on Wed/Friday street night because of my e-cutout(unless I onlt want to get one run before they kick me out)
I'll be at New England Dragway on Oct 19 with a g37coupe(stock) 2010 WRX (stock) a 565whp 05 GT500 Possibly a stock 370z and maybe a 2010 s4 or a couple of 636 motorcycles and then myself
Old Oct 19, 2014 | 01:58 PM
  #333
iideadeyeii
12.9 best run. I also had the dirtiest car there.(no prize won)
Old Oct 19, 2014 | 03:09 PM
  #334
0jiggy0's Avatar
0jiggy0
Sounds like your not even breaking 300whp
Old Oct 19, 2014 | 05:55 PM
  #335
iideadeyeii
Waaa phhhst
Old Oct 19, 2014 | 05:58 PM
  #336
iideadeyeii
I'm going to install the kinetix v+ plenum back on since I don't even have a spacer installed. Also I'm going to look at my timing map(something I never adjusted since I probably can advance it) but all I was looking for was to hit 12's
Old Nov 3, 2014 | 08:46 AM
  #337
iideadeyeii
3RD best run of the day(only video taped a few because they didn't like the mount on my window so moved it to my side window, but became a pain when I had to grab my slip at the end of every run)
Traction is first was an issue(275's Sumitomo HTR Z II) Deflating tires did not give any better results
. Any launch at lower rpms or riding clutch to avoid spin would yield lower 1/4 times(up to 13.3 worst run)
13.06 run
Old Nov 3, 2014 | 08:49 AM
  #338
terrasmak's Avatar
If you do a lot of drag, just get DR's on dedicated 17's to swap for strip days . Very much needed for good times
Old Nov 3, 2014 | 10:07 AM
  #339
iideadeyeii
I agree, but I more interested in what I can actually do versus only at the drag strip. If someone wants to let me borrow a pair for a couple runs next year I wouldn't mind though Not worth the ~$700 just to have a faster strip time
Old Nov 3, 2014 | 01:21 PM
  #340
Moncef's Avatar
Moncef
What are the choke points with this setup so far? Any boost leaks? Do you have significant pressure drop across your intercooler?
How's your spool? What injectors are you using?
