Advice on fuel management for turbo setup.
Old Feb 26, 2013 | 02:01 PM
Doug Fab's Avatar
Doug Fab
Default Advice on fuel management for turbo setup.
hello,
fellas
i have an 03 350z auto. its completely stock and i am currently fabbing up a turbo kit. im not looking to do anything crazy. t3 single turbo 5-7 psi.
the setup is more for show and sound then for performance.
my question is what would it take for fuel and ignition management.
i will be upgrading inj and pump.
what would you all suggest for a ecu?
is there anyone who does a reflash?
just throw some ideas at me.
Thanx,
Doug Fab
Old Feb 26, 2013 | 02:19 PM
tonyzS/C03's Avatar
tonyzS/C03
Flux capacitor?
But in reality you'll want a 1:1 fuel pressure regulator, 440cc or better injectors, 255lph or bigger fuel pump, and at least a stg1 type fuel rails.
Old Feb 26, 2013 | 03:00 PM
superchargedg's Avatar
superchargedg
Damn Noobs
Rails would be overkill for 5-7 psi
Old Feb 26, 2013 | 03:25 PM
jerryd87's Avatar
jerryd87
iirc the inside diameter of aftermarket rails are actually smaller then stock or close to the same size, the advantage is setting up your lines however you want with an fittings. osiris and done but your going to spend several thousand more fabbing your own stuff then to just buy premade.
Old Feb 27, 2013 | 03:44 PM
Doug Fab's Avatar
Doug Fab
thanx for the advice guys.
im not new to turbo cars just new to the turbo Z.
i do alot of SR20 performance work.
ive seen that GTM has a turn key kit. injectors, pump and ecu reflash.
http://www.gtmotorsports.com/product...cat=260&page=1
anyone have experience with this reflash?
is it worth the money or is it over kill for what i am trying to accomplish?
Old Feb 27, 2013 | 04:56 PM
Resmarted's Avatar
Resmarted
I'd go with 5XXcc injectors, cjm stage 0, osiris uprev reflash, and 255 pump. No need for anything more than that stuff on low boost.
Old Feb 27, 2013 | 05:06 PM
ReStylin's Avatar
ReStylin
In a few weeks Im upgrading the fueling in my car
Ill be selling
DW 600CC
Uprev Osiris Tuner + Cable
Walbro 255L
HPX MAF
If you want them, let me know and ill do the whole photo and name thing and we can figure out a price.
Old Feb 27, 2013 | 05:11 PM
Doug Fab's Avatar
Doug Fab
Ill be selling
DW 600CC
Walbro 255L
HPX MAF
sounds good.
im putting a kit together for a customer. im trying to give him a price on the whole job.
pm me with a price
Old Feb 27, 2013 | 05:39 PM
Ruthless18x's Avatar
Ruthless18x
Best bang for the buck would be as mentioned, dw600's, walbro, fuel return and osiris.
If you want to do anything with fuel pressure you'll need the return.
Old Mar 1, 2013 | 04:25 PM
Drako_MDx's Avatar
Drako_MDx
Originally Posted by Doug Fab
hello,
fellas
Thanx,
Doug Fab
For your current goal...
450cc to 550cc Injectors
Walbro 255
Osirus Tuner or Get Tuned at a reputable Osirus place and just pay for the License.
No need to spend money on MAF Upgrade or Return Fuel System.
Old Mar 1, 2013 | 07:23 PM
Doug Fab's Avatar
Doug Fab
awesome. thank you all
