Vortech V3 Fluid change help plz!
Old Mar 26, 2013 | 03:06 AM
SkyZ33's Avatar
SkyZ33
Default Vortech V3 Fluid change help plz!
I have 04 350z running on Vortech V3 and run it about 6.5k miles and thought it about time to change the fluid, but then I have no idea how to even take the dip stick out because of the space limited, anyone know any way to change it? Do I need to take out the blower(That going to be complicated.....)? Or should I find a shop in SoCal? Thanks
Old Mar 26, 2013 | 04:00 AM
MUZZY's Avatar
MUZZY
stop whatever your doing! NOW!
based on your questions you are not capable of doing anything with this car.
Please change your oil with synthetic every 3k miles at a nissan dealer.
I cant explain why, it will just go over your head
Old Mar 26, 2013 | 05:06 AM
bmyles's Avatar
bmyles
I am ROFL'ing at his mod list: pulley 3.12", fuel pump 255, and best of all THE PLATINUM SPACER.
Old Mar 26, 2013 | 12:09 PM
SkyZ33's Avatar
SkyZ33
I do change my oil myself every 4k miles.....so thank you.
I'm asking about the oil in the Vortech blower because the V3 is on it own lubricant system and the dip stick is on the side of the blower.....
Lol, thanks for making fun of my list, not sure what wrong with the spacer.....
Old Mar 26, 2013 | 04:01 PM
adgialelis's Avatar
adgialelis
unless it cost thousands of dollars its prolly a plenum spacer and here read this link.
http://www.chargerforums.com/forums/.../t-103305.html
Old Mar 26, 2013 | 04:27 PM
SkyZ33's Avatar
SkyZ33
Lol, sorry for my poor spelling.....
The Charger set up is different than the Z.....lol...
Old Mar 26, 2013 | 04:38 PM
ogiehooker's Avatar
ogiehooker
Default dipstcik
I had the same issue on my old vortech setup...called vortech. The blower is made for a wide avriety of cars, not just th Z so the dipstick can't be taken out on our cars and I relayed this to vortech...they dont care.
Here's what I did....I put an axtended drain SS line to under the bumper and would just drain it and refill with 4.0 oz vortech fluid...no dipstick needed cause you cant get to it anyway...
hope that helps.
Old Mar 27, 2013 | 02:30 AM
SkyZ33's Avatar
SkyZ33
I see, so 4oz the whole bottle is perfect?
You extended the original drain line? How you do that?
Old Mar 27, 2013 | 04:12 AM
Threads's Avatar
hope that helps.
The V3 dipstick is a pain to get to with the blower still on the bracket, however, I was still able to finagle it out.
Old Mar 27, 2013 | 06:00 AM
ogiehooker's Avatar
ogiehooker
Default fluid
according to vortech, 4.0 oz is just right for a fluid change. I just took the old line off the blower, or bolt or whatever the drain was, and attached a longer line that I could access through the bumper opening and capped thee end.
Old Mar 27, 2013 | 05:14 PM
str8dum1's Avatar
str8dum1
^thats what i did with my V3 as well. in the G35, I could actually get the dipstick out though
Old Mar 29, 2013 | 02:47 AM
SkyZ33's Avatar
SkyZ33
Thanks, I'll give a try without the dip stick I guess =\
seagrasser
Oct 11, 2015 03:27 PM
blackend
Nov 9, 2005 07:38 PM
SungNamZ
Aug 24, 2004 07:10 PM
