Vortech motor build
Old Apr 12, 2013 | 04:08 PM
the3kgt2's Avatar
the3kgt2
Originally Posted by Colombo
just saw this. best of luck man im interested to see the number difference with the SI and my 928m impeller, ill also be running the 2.87 pulley with my setup, do you ever plan on pushing the blower harder with a smaller pulley?
Thanks Colombo. Your IPP block will be 8.8:1cr while mine will be 9.5:1cr so it won't be a perfect comparison. My 3.12 pulley will already be overspinning my Si's maximum 52,000rpm by over 1,000rpm. I'm thinking a 2.87 pulley would overspin it way too much. I was previously predetonating with my 3.12 on my stock block so my tuner had to pull back a ton of timing up top. I may even drop down to a 3.25 like unvmyg35 did if I start pinging. Remember I'm tuning for California 91 octane only. My slightly lower cr and ceramic-moly coating should help a bit with the pinging.
Old Apr 12, 2013 | 06:31 PM
350z006's Avatar
350z006
Well, the good thing with bigger pulleys is more belt wrap so you'll have less slippage to worry about
Old Apr 12, 2013 | 08:07 PM
TSG-Z's Avatar
TSG-Z
I'm having my 928 impeller and 2.62 pulley hopefully installed in the coming weeks.
Old Apr 15, 2013 | 04:04 PM
the3kgt2's Avatar
the3kgt2
Some junk came in that I'll be dropping off at ZCG:
Old Apr 19, 2013 | 05:38 PM
the3kgt2's Avatar
the3kgt2
More parts. ATP Garret intercooler and a bunch of massive intake filters. The best way to find the largest intake that will fit is to try them all!
Thanks 350zhp306 for the idea. I'm thinking only the two smaller filters have a chance of fitting above my crash bar though.
Old Apr 19, 2013 | 07:20 PM
OldManZ350's Avatar
OldManZ350
This one will fit above the crash bar.
K AND N RC-4630 Product Specifications
Product Style: Round Tapered Universal Air Filter
Base Outside Diameter: 5.5 in (140 mm)
Top Outside Diameter: 4.5 in (114 mm)
Flanges: 1
Flange Inside Diameter: 3.5 in (89 mm)
Flange Length: 1.25 in (32 mm)
Flange Type: Centered
Height: 6.5 in (165 mm)
Old Apr 19, 2013 | 10:15 PM
- bigc -'s Avatar
- bigc -
<ominous voice> That's too much filter for one man. </ominous voice>
Old Apr 20, 2013 | 08:02 AM
the3kgt2's Avatar
the3kgt2
Flanges: 1
Thanks. If RU-1785 and RE-0920 don't fit then I'll go for the smaller RC-4630. I currently use a RX-4140 but need bigger.
Old Apr 20, 2013 | 10:17 AM
meanz's Avatar
meanz
meh, who needs a crash bar..
Old Apr 20, 2013 | 06:09 PM
350zhp306's Avatar
350zhp306
No problem. Your build will come out great.
Old Apr 20, 2013 | 07:31 PM
herrschaft's Avatar
herrschaft
That pathfinder cooling mod, did it come with the straight coupler when you bought it? Or did you have to source it yourself?
Old Apr 20, 2013 | 09:05 PM
the3kgt2's Avatar
the3kgt2
Comes with the straight coupler when ordered from IPP.
Old Apr 20, 2013 | 09:17 PM
herrschaft's Avatar
herrschaft
Thanks. Received mine a couple weeks ago from ConceptZ and apparently they don't sell them with that piece.
Old Apr 24, 2013 | 08:26 AM
str8dum1's Avatar
str8dum1
all everyone is doin is just marking up parts ordered from nissan. nissan doesnt sell that straight coupler, thats why places like CZ dont include it.
a few mins looking up part numbers saved me quite a bit of money over ordering a "kit" from one of those vendors.
Old Jun 24, 2013 | 08:35 AM
the3kgt2's Avatar
the3kgt2
Latest update is that there is no update. Rebello still hasn't finished the motor. The car has been sitting at Z Car Garage for over 3 months and have been told 3 times that the motor will be done at the end of the week...that was almost a month ago. I can understand delays and I'm sure it'll be worth the wait...but I just wish I could have been given an honest ETA from Rebello. Nothing I can do now except keep waiting.
Old Jul 5, 2013 | 04:51 PM
the3kgt2's Avatar
the3kgt2
On a positive note, I received TimRod's Radius Rod Strut Kit
Old Jul 5, 2013 | 08:50 PM
OldManZ350's Avatar
OldManZ350
You put it together Backwards.....
The Two 1/8" thick small diameter spacers go on the shock tower side between the suppled metal brackets.
The 5/16" thick large diameter spacer goes on the Blower side.
Old Jul 5, 2013 | 10:08 PM
  #38
Triji's Avatar
Triji
Looking good, going to have to put my order in for one of those radius rods here soon. My build is starting to come along at a better pace now and she will be getting her new engine dropped in soon.
Hope your build gets some love and attention, I can definitely relate with the anticipation.
Old Jul 6, 2013 | 07:48 AM
  #39
the3kgt2's Avatar
the3kgt2
I know. I just threw it together to take a picture. I immediately took it apart, boxed it up, and will give it to ZCG to install.
Old Jul 12, 2013 | 07:37 AM
  #40
the3kgt2's Avatar
the3kgt2
The engine was completed and dropped off at the shop on 7/10
Now we wait for Rob to start putting it back together.
