Vortech motor build
Old Jul 30, 2013 | 09:50 AM
  #41
350zhp306's Avatar
350zhp306
Any new updates?
Old Jul 30, 2013 | 09:54 AM
  #42
the3kgt2's Avatar
the3kgt2
Originally Posted by 350zhp306
Any new updates?
Still waiting for Rob to start the install. Everything has been extremely slow. The car is just sitting in the sun, waiting for its turn.
Old Jul 30, 2013 | 02:36 PM
  #43
Colombo's Avatar
i feel for ya man! i hope they get u back on the road soon. seeing this and others who went to shops reminds me why im glad i just went ahead and did it myself.. understandable tho some just dont have the time to do it themselves.. best of luck and excited to see this finished!
Old Aug 20, 2013 | 08:32 AM
  #44
the3kgt2's Avatar
the3kgt2
ZCarGarage started the install last night. Once they start they're pretty quick so I'm excited now. I'm hoping the 5 month wait will be worth it.
Old Aug 20, 2013 | 08:45 AM
  #45
jr27's Avatar
jr27
why did your engine blow just gave out after so long or was it a bad tune?? im a little worried because we have basically the same numbers but im only at 7.5psi so hopefully that means its safer than 9psi
Old Aug 20, 2013 | 08:57 AM
  #46
the3kgt2's Avatar
the3kgt2
No clue. It was tuned by ZCarGarage. A lot of timing was pulled up top and my torque curve was very jagged instead of smooth, but I still don't think it was the tune. The motor was boosted for 2.5 years with a few track days and it was well maintained. A couple weeks before the motor blew I bounced the limiter while racing a GTR because I missed the shifter, but I don't think it was that either. I was probably just unlucky, spun a bearing, and snapped a rod. Crap happens, boost adds stress, and you have to pay to play. All motors fail eventually...mine happened with 67k miles on the odometer, 30k miles boosted.
Old Aug 20, 2013 | 09:13 AM
  #47
jr27's Avatar
jr27
thats unfortunate man. but looks like youre in a better set up now. good luck with this one and im gonna save up for sure in case mine craps out. ive only been boosted for about 3 weeks im gonna hit up the track on thursday at irwindale speedway so ill see what the car can do. keep us posted with the new numbers
Old Aug 20, 2013 | 09:16 AM
  #48
the3kgt2's Avatar
the3kgt2
Thanks.
I raced at Irwindale in a stock car last year but not in my Z. Are you doing the 1/8th or the oval?
Old Aug 20, 2013 | 09:30 AM
  #49
jr27's Avatar
jr27
Thanks.
i thought it was a 1/4. but i guess im doing the 1/8 never been to any track. im planning to run on some toyo proxes r888. i didnt know there was an oval at irwindale
Old Aug 26, 2013 | 03:49 PM
  #50
the3kgt2's Avatar
the3kgt2
The Z took its first breath in 5 months. The built motor starts its break-in period today. I should be able to pick it up from ZCG tomorrow.
Old Aug 26, 2013 | 03:52 PM
  #51
gabe3d's Avatar
gabe3d
Congrats on your new born's first step.
Old Aug 26, 2013 | 04:18 PM
  #52
meanz's Avatar
meanz
Nice!! Im just waiting on these bigger injectors to finish my tune to be able to pick mine up.
Old Aug 26, 2013 | 04:34 PM
  #53
the3kgt2's Avatar
the3kgt2
I'm picking my Z up with OE injectors for the break-in period. We'll swap in the Bosch EV14 900cc after 800 miles and then start the tuning process.
Old Aug 26, 2013 | 06:50 PM
  #54
Triji's Avatar
Triji
Sweet! Good luck with it!
Let us know how she is running when you pick her up!
Old Aug 27, 2013 | 10:45 AM
  #55
djhiro's Avatar
djhiro
Nice build Just wondering why you decided to go with OE injectors instead of the Bosch right away? I'm in a similar situation with my G35 being built. I've been trying to decide on the best way to break the engine in and maybe the OE injectors would be a good route for me as well. The only worry I have is that I will be running a CJM Stage 1 fuel return system with an Aeromotive 340 fuel pump. Is there a reason you are not running a return fuel system, as I thought this was a standard upgrade when going FI?
Old Aug 27, 2013 | 10:50 AM
  #56
the3kgt2's Avatar
the3kgt2
Tuner recommendation and I trust my tuner. I need to smog my car right away and it makes no sense to attempt to do that on 900cc injectors. My tuner does not like return fuel systems on the Z and prefers to tune without them. My Aeromotive 340lph pump and 900cc injectors should give us enough fuel control.
Old Aug 27, 2013 | 12:19 PM
  #57
str8dum1's Avatar
str8dum1
your tuner doesnt like steady fuel pressure at the injectors? hmmm.....
Old Aug 27, 2013 | 03:13 PM
  #58
djhiro's Avatar
djhiro
Oh ok....I'll talk to my tuner and see if running OEM injectors with the vortech would be a good option with my built engine as well.
I read that you will be using a Fluidamper pulley. That is the same crank pulley I will be using with my built engine too. I've been reading a bit that the belt size may need to be changed due to the Fluidamper pulley being larger than the OEM crank pulley. Have you run into this issue yet? What size belt and pulley are you going to be using?
Old Aug 27, 2013 | 03:15 PM
  #59
the3kgt2's Avatar
the3kgt2
Same belt. You only need to swap belts when making huge pulley changes. Just adjust the tension as needed.
Old Aug 27, 2013 | 04:31 PM
  #60
- bigc -'s Avatar
- bigc -
^ If its not too late, see if you can get the grooves of the fluidampr sandblasted / scuffed up a bit before install. There's more belt wrap so less belt slip at high rpm, but I always felt that there was a little slip on shifts when the engine speed changed quickly. Could totally be in my head, but its an easy bit of insurance.
