Just another SC'd ZR
Old Mar 29, 2015 | 02:22 PM
  #41
Conway_160's Avatar
Conway_160
Looks good!
Old Mar 29, 2015 | 11:18 PM
  #42
tcode's Avatar
tcode
Thanks !
Pre turbo pipes wrapped with DEI:
Oil cooler relocated to driver side, custom bracket, hard lines above IC to help with heat dissipation:
Rear wheel (18x10.5 ET22 wrapped into Toyo R888 275/35/18):
Old Apr 1, 2015 | 02:22 PM
  #43
rcdash's Avatar
rcdash
Just fyi, spacers are readily available so you didn't have to grind down the manifold (would've just raised the manifold 1/4 inch). Good work though on the DIY. If you use -10 lines I don't think the oil cooling will be an issue either btw.
Old Jun 23, 2015 | 12:45 AM
  #44
tcode's Avatar
tcode
Old Jun 24, 2015 | 02:41 PM
  #45
Conway_160's Avatar
Conway_160
I wish I had the Fab skills to do something like this with my long tube headers.
Old Apr 13, 2016 | 12:28 AM
  #46
tcode's Avatar
tcode
There are no darkness as long as there's a fuel in my tank
