Just another SC'd ZR
Old May 1, 2013 | 05:33 AM
tcode's Avatar
tcode
Default Just another SC'd ZR
MY2005 EU market ZR, VLSD, Brembos, ESP etc.
Mods so far:
ATI ProCharger with 9 PSI pulley kit
MTD 5/16 plenum spacer
PMAS HPX-N MAF sensor
DW630 injectors
Walbro 255lph in tank pump
De-cat with Berk test pipes
JWT lightweight clutch kit
Diff Whiteline poly bushes kit
Custom made oil cooler with Mocal sandwich plate
UpRev Osiris Tuner
So far, street tuned by myself. Pulls strong even with very conservative ignition timing. Waiting for CJM fuel return system since injector DC is 100% and AFR still too lean for boosted engine. Once finished, will go to dyno and properly map ignition timing.
Many thanks to all good people on this boards for sharing knowledge and being patient with noobs, especially thanks to guys I bother with internationally shipping and endless questions why and how .
Old May 2, 2013 | 03:37 AM
evilscorp's Avatar
evilscorp
DW630 at 100% duty cycle! Must be putting down some good power. Nice work. Not seen / looked at many procharger setups, piping sure is a lot less than my vortech =)
Old May 2, 2013 | 04:38 AM
tcode's Avatar
tcode
Yeah, it has some good power according to my butt dyno . However, flow of a 630 cc/min on a static fuel pressure with boosted engine drops with boost.
Piping isn't bad, that's true. Thanks!
Old May 21, 2013 | 10:17 PM
tcode's Avatar
tcode
Had to purchase and install fuel return system, injectors DC is around 80% on highest load now.
Yesterday I finished fine tuning of the ignition table and cam advance on a dyno.
All figures are at the crank.
I love this car very much now, so much fun with that extra power. It should come from a factory with that power .
Old May 22, 2013 | 02:20 AM
bmyles's Avatar
bmyles
How is it at the crank unless you strapped your motor to an engine dyno. I'm guessing they're just adding 15% back in, but that's not entirely accurate. Regardless, looks like you're making lots of power. Real jealous. I might be picking up a Vortech kit some time...that much power would definitely be fun!
Old May 22, 2013 | 03:09 AM
tcode's Avatar
tcode
Yeah, it's calculated crank power and it's never 100% accurate for sure. Numbers aren't of big importance to me, but curves tendency are. Engine response is very predictable and overall car is very easy and fun to drive .
Old May 22, 2013 | 10:56 AM
binder's Avatar
binder
I thought I was actually going to see a real ZR. You do know that the ZR is version of a chevy corvette and the Z is a nissan car right?
Old May 22, 2013 | 05:14 PM
ProChargedZR's Avatar
ProChargedZR
Yes, but just about everyone here refers to their 350z Roadster as a "ZR" for short.
Quick question for you. I am running the Procharger kit too. Do you have any internal modifications? You are about the power that I was hoping to get, but I was also thinking about buying a second long block and building it over the next year or so, then dropping it in. Just wondering if it is worth it for me to go through all the trouble to get that done to hit my power goal (450-500 RWHP).
Old May 22, 2013 | 05:36 PM
binder's Avatar
binder
Huge cost increase when going to 500hp with a built engine. The difference in fun between 450 stock block and 500 on a built engine isn't worth the time and money.
And it must be a roadster forum thing because I've never seen anyone refer to it as a ZR and judging by your post count and join date I've been around the block on this platform more.
Who measures horsepower at the crank anyways? Last I checked the dyno is turned by the rear wheels.
Old May 23, 2013 | 08:01 AM
meanz's Avatar
meanz
Nice z, anymore pics? Id like to see some whp numbers..these crank numbers look great and all, but they aren't really worth anything.
Old May 23, 2013 | 10:37 AM
DarkCreep's Avatar
DarkCreep
You must be really fun at parties.
Old Jun 5, 2013 | 10:57 PM
tcode's Avatar
tcode
Sorry, don't have whp numbers. We used to display engine power on crank over here, everyone does it that way, why.
Here are some pics..
With another "muscle" JDM companion
Dirty one..
I apologize for a shaking video, GoPro was in my left hand .
edit: the engine internals are bone stock..
Old Jun 7, 2013 | 05:52 AM
Resmarted's Avatar
Resmarted
I nick named my car the zr71 (z33 roadster 7175) specifically because they call it a 350zr in the roadster section... so yeah it is a roadster section thing. lmao.
Old Jul 11, 2013 | 03:49 AM
tcode's Avatar
tcode
Had cog belt issue @12 psi. Adding two custom brackets helping belt to last now @14psi. So far so good. Will report in two weeks.
Old Jul 11, 2013 | 04:11 AM
suprasam's Avatar
suprasam
^^What engine torque dampener is that?
Old Jul 11, 2013 | 04:15 AM
tcode's Avatar
tcode
Spoon. Bracket is custom made.
Old Jul 11, 2013 | 11:14 AM
ProChargedZR
tcode,
Did you do anything to your PCV system? I have noticed lately that I am getting, what appears to be, some ring blowby above 5500-5800RPM. I have been searching for a way to correct it and thought I had seen somewhere to drill out the PCV line and replace it with a different Nissan line/valve. My next step, though, is to get a compression/leakdown test next time I take the car to the shop and possibly a catch-can.
Old Jul 11, 2013 | 11:59 AM
tcode's Avatar
tcode
PCV valve on the passenger side is drilled and I vent both valve covers to the atmosphere. Will do catch can soon.
Old Jul 11, 2013 | 04:23 PM
Resmarted's Avatar
Resmarted
I see you don't have a front radiator support... if you have a 3" intercooler piping I have a race intercooler from treadstone (brand spanking new) I'm trying to sell (bought it and realized it wouldn't fit like a dumb***). Rated for 1200hp, but would probably really help your setup if you're running higher boost levels. Same side entrance and exit like yours. PM me if you're interested. Price can be negotiated (need $ now lol).
BTW you should just get a breather for your pcv and just drill it out.
Old Jul 12, 2013 | 09:07 AM
Cass007's Avatar
Cass007
May want to get rid of the zip tie holding your coolant hose in place too before it wears through.
