New setup in the works
Old Sep 17, 2013 | 06:59 PM
  #121
meatbag's Avatar
meatbag
Originally Posted by Recklezzz
i was looking for somthing bigger than a 3431. I have gt28'son my car now that i maxed out for a couple years now. I want to be around 750-800whp. I was wanting to find a pair close to 20g's. I might end up just getting gt3076 with the tiaL vband housing. Fast intentions said they fit on there 370z turbo kit. No reason it shouldn't fit on the 350z. I just cant decide what to do yet. what ever i decide to do i want to match my power goals, so i can be done with switching turbo's for a while. Everything else on my car is ready to go big power. I have always been limited on my turbo's.
You can also go up to a 35r with the GTM manifolds. If you go that route then you have the option to go up to any of the HTA turbos.
Old Sep 17, 2013 | 07:01 PM
  #122
meatbag's Avatar
meatbag
Got the front end finished up finally and everything welded up. Was hoping to have the car running this week but I am still waiting for all my plumbing to show up from BMRS. Back to the daily grind.
Old Sep 17, 2013 | 07:04 PM
  #123
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
What size turbo do you think would work for a side mount application? I read your post stating that you tried to fit the 5858's but would have to move the alt and etc..
I am starting a custom side mount project and was going to order some mach up turbo's from precision but wanted to get rough idea of where to start.
What turbo manifolds are you planning to use?
Old Sep 18, 2013 | 06:07 AM
  #124
graffkid732's Avatar
graffkid732
Looking good
Old Sep 18, 2013 | 06:55 AM
  #125
Highway Riding's Avatar
Highway Riding
Holy f dude..... Serious everything! GL
Old Sep 18, 2013 | 07:01 AM
  #126
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
Beautiful fab work.
Old Sep 18, 2013 | 09:10 AM
  #127
Recklezzz's Avatar
Recklezzz
Just going to fab some up. I am friends with charlie at CJM and we been talking about making greedy replacment manifolds for a while. Charlie made a jig i can use and moddifly to what ever i want. I was just going to use sch10 stanless and have some flanges cut for what ever turbo i end up getting.
Old Sep 18, 2013 | 09:17 AM
  #128
Recklezzz's Avatar
Recklezzz
I want no part of GTM lol. I am not a fan of there manifolds. There new set for the 370z looks cool thoe. There also using 20g's now. I really hate on there manifolds because of the stuppid 4 bolt flange they use for exsternal wastegates.
Old Sep 18, 2013 | 11:33 AM
  #129
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
Nice. I look forward to seeing a thread on that with some pics.
Old Sep 18, 2013 | 11:36 AM
  #130
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
OP,
I'm curious... What are you doing now for a tow hook since the front crash bar is gone?
Old Sep 18, 2013 | 04:55 PM
  #131
Resmarted's Avatar
Resmarted
OP,
That's what the orphan slaves are for... right?
JK
That's a pretty crazy looking front end support!
Old Sep 18, 2013 | 08:18 PM
  #132
MonkeyMagic72's Avatar
MonkeyMagic72
That is one menace and evil looking turbo setup. The twin turbos sit up front are all business. Hope you are running filters for the turbos, because if not, squirrels and cats would be very afraid, if you know what I mean, lol. In for update.
Old Sep 19, 2013 | 07:08 AM
  #133
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
Auto is still a ways off since I bought the Infinity box but the car should be up and running next week finally.
BTW... Don't know if this would be compatible with the AEM Infinity, but it's worth looking into...
http://proefi.com/info/transmission-control-module/
-Control up to 8 gears
-Converter Lock-up with slip
monitor for seamless gear change
-Line pressure control
-Accumulator Backpressure control
-Converter slip monitor
-Trans Temp Pre and Post cooler inputs
-CAN communication with all other ProEFI modules! You don’t have to hook up an RPM signal, speed signal or throttle Signal if you are using a ProEFI computer!
-RPM input
-Driven wheel speed input
-Throttle Input
-2 Fan control outputs for Trans coolers
-Trans line pressure input with safety monitor and warnings
-Manual Shift mode
-Paddle shift capability
-Malfunction indicator light output
-Shift light output
-Alternate tire size switch input for proper wheel speed calibration for shifts
-Torque Reduction request output!
-Up to 6 shifter lever position inputs (Only 5 available if alternate tires size switch is used. (This applies to manual LEVER shifting only!)
-All tables and calibrations are LIVE calibratable! No flashing necessary!
Retail Price will be $1199 for the TCM, and a plug and pin kit. Harnesses for certain applications*
Old Sep 19, 2013 | 08:22 AM
  #134
meatbag's Avatar
meatbag
Was planning on doing a manual valve body anyways
Old Sep 19, 2013 | 09:09 PM
  #135
Resmarted's Avatar
Resmarted
Like Meatbag said... not necessary! You can run it manual and not even have a computer. A nice bonus is that without the computer this transmission runs full line solenoid pressure. Which for meat's powerlevels will be necessary.
Edit (From the youtube page):
"Here's how the shifting works:
Sol A: grounded, Sol B: off = First Gear
Sol A: off, Sol B: off = Second Gear
Sol A: off, Sol B: grounded = Third Gear
Sol A: grounded, Sol B: grounded = Fourth Gear
Lockup Solenoid grounded = Lockup active"
Would be SOOOO easy to set this up.
Old Sep 19, 2013 | 09:31 PM
  #136
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
I know you can get them with a manual valve body. When meatbag said that the auto was still a ways off since he bought an AEM Infinity, I assumed it was because he was going with full electronic control.
Old Sep 20, 2013 | 05:11 AM
  #137
meatbag's Avatar
meatbag
Nah its more of a budget thing. I know some people think since I work at a shop I get everything for free but thats just not the case.
Old Sep 20, 2013 | 06:34 AM
  #138
graffkid732
Nah its more of a bidget thing. I know some people think since I work at a shop I get everything for free but thats just not the case.
If only that were the case, things would be great.
Old Sep 20, 2013 | 07:42 AM
  #139
djamps's Avatar
djamps
Pretty cool with the manual mode. I'd wire it up to some sort of **** or lever instead of two switches though.
Old Sep 20, 2013 | 08:29 AM
  #140
meatbag's Avatar
meatbag
What your thinking of is not a true manual valve body setup
